November 2nd, 2013, 02:29 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): gsxr 750, sv650, 250 ninja Posts: 110
weight of new gen 250 rear wheel?
does anyone know how much the rear wheel wieghs minus disc and sprocket carrier on the new gen 250
December 4th, 2013, 08:38 PM | #2 |
Did you find this? If not, I have one off the bike with no tire that I can weigh for you.
December 4th, 2013, 09:12 PM | #3 |
yes, please weigh it, thanks
December 8th, 2013, 05:53 PM | #4 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
A little less than 14lb with 1 ounce of wheel weights still on it. Everything else but bearings removed.
MCRA.com |
Just installed new gen rear wheel, brake problem? | Zombarian | 1986 - 2007 Ninja 250R Tech Talk | 6 | August 2nd, 2014 09:26 PM |
Fitting a new gen front wheel on a pre gen? | thumper64 | 1986 - 2007 Ninja 250R Tech Talk | 13 | November 6th, 2013 02:44 PM |
Stock rear wheel, gauge cluster, windscreen, new gen parts FS | jman511115 | Motorcycle-related | 15 | November 13th, 2012 03:50 PM |
new gen rear wheel | eddiekay | Free stuff! | 6 | April 10th, 2012 11:21 PM |
