August 9th, 2014, 12:30 PM | #1 |
Join Date: Nov 2012 Motorcycle(s): 2009 ninja 250 blue Posts: 31
Wife wants a bike.
Title pretty much says it. The questions I have is is there a way so safely lower a ninja 250? The problem is she is only 5'0" so in order to get a foot on the ground she has to lean the bike way over. She's worried that if she has to lean it over that much one time it is going to fall over. I have read that lowering a bike messes with the way it handles and performs. Is this true?
Thanks so much |
August 9th, 2014, 12:38 PM | #2 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
August 9th, 2014, 12:38 PM | #3 |
Hey Stefan, lower it as needed. You may hear all kinds of crap about not lowering it. Truth is, if she doesn't need the clearance, it don't matter if its there. In time, her skill may warrant raising it back up. Until then, no real worries. The secret is to not put one's self into the situation where you need the clearance until it's time.
Lowering links are what you're after, and what you do to the rear... balance it out in the front as such. It's just nuts and bolts that can returned to stock height or higher when the time comes. Good luck to your wife!
August 9th, 2014, 12:39 PM | #4 |
There's a good wiki article here about how someone lowered their new-gen 250:
https://www.ninjette.org/wiki/Lowering Yes, it obviously affects ground clearance and available lean angle, but for newer riders it might be an appropriate tradeoff.
August 9th, 2014, 12:52 PM | #5 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
Yeah, just throw on some lowering links. I had pro-tek lowering links (model LL-120) when I got the bike. Over time, I got used to the height, and replaced them with the stock ones. It's a really simple job.
Also, keep this in mind - you have to buy a shorter kickstand if you lower the bike. It took me forever to figure out why it was impossible to park my bike on anything but a completely flat street... it was because the PO lowered it, but kept the stock length kickstand. |
August 9th, 2014, 04:43 PM | #6 |
Thanks guys I'll look into lowering links. Looking at probably an 09 and up 250
August 9th, 2014, 04:59 PM | #7 | |
antiant
MOTM - Oct '14
Also, look into some boots that add height, like the Daytona Lady-Star GTX Boots. Yeah, they are expensive, but they can help those that are inseam challenged and they also provide protection.
August 9th, 2014, 06:19 PM | #8 | |
August 9th, 2014, 07:34 PM | #9 |
antiant
MOTM - Oct '14
You're welcome.
August 9th, 2014, 07:48 PM | #10 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
You guys might consider a Honda Rebel. And an MSF class.
August 10th, 2014, 07:49 AM | #11 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Every time a wife/ girlfriend says she want a bike I turn into my father.
I feel vaguely hypocritical worrying but you can't help the protective instinct. Once they have been out a few times alone and come back ok I feel better Usually we start with a low custom like the el250 or a Honda stepthrough with Jen who was 6ft something and all wrong on a low bike. Upright is important for control, particularly here in the UK with its emphasis on compulsory "round the cones" tests and training. (That was the hardest part for me learning to ride the bike in what seemed to be 8ft full lock circles) |
August 11th, 2014, 12:29 PM | #12 |
The handling of the bike will change IF you don't lower the front and rear by the same amount.
- Rear is lowered using links on the shock. - Front is lowered by sliding the fork tubes up in the triple clamp. Because the 250's handlebar mounts cover the tops of the forks you'll need to either get riser blocks or clip-ons and mount them on top of the triple clamp (@LittleRedNinjette did this and has photos) - Don't forget the kickstand. If you lower the bike the kickstand will be too long. Not a problem up to a point... that point being when the bike no longer is stable when on the kickstand. Options are to cut and reweld the existing part or buy an adjustable kickstand. That is all....
Wife not that cool with the bike | egb1108 | General Motorcycling Discussion | 45 | June 22nd, 2011 11:51 AM |
wife's bike almost ready | stang65pony | 2008 - 2012 Ninja 250R Farkles | 28 | February 21st, 2011 12:08 PM |
wife went down last night.......on the bike that is | stang65pony | !%@*#$%!)@#&!%@ I crashed! | 18 | September 26th, 2010 11:11 AM |
Wife's first bike | cb61 | New Members | 15 | October 31st, 2009 01:42 PM |
Pics of my wife's bike | Ducati916Senna | Pictures | 13 | December 3rd, 2008 07:21 AM |
