Old October 6th, 2014, 01:37 PM   #1
mrudich
mrudich's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
Missing piece to my master link?!
I was lubing my chain this morning and as per usual I looked for the master link so I knew what a full rotation of the chain was, but I couldn't find the master link.
I eventually found that this was because the master link clip was gone..
I'm assuming this is very, very bad?
mrudich is offline   Reply With Quote
Old October 6th, 2014, 01:43 PM   #2
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
No more riding till you get another link and safety wire it. Make sure you put the open end away from the direction of travel (is this correct?). Or get a masterlink that can be riveted.
Old October 6th, 2014, 01:44 PM   #3
^^^ yea
Old October 6th, 2014, 01:52 PM   #4
mrudich
mrudich's Avatar
I think I'm gonna go with a riveting master link this time.. Those are better, right?
Old October 6th, 2014, 01:54 PM   #5
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Varies. I think if I knew I'd be taking the chain off or whatever often, I'd use a clip style. If you over flare the rivet style, you will need to start again. You basically need no special tools to remove and install a clip style.
Old October 6th, 2014, 01:54 PM   #6
Better? Sure, if the install is done properly. Otherwise, they are worse.
Old October 6th, 2014, 02:01 PM   #7
mrudich
mrudich's Avatar
Hmm I might go with a clip style again then.
Is there a tutorial of some sort that shows how to properly safety wire a master link?
Old October 6th, 2014, 02:07 PM   #8
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Google.
Old October 6th, 2014, 02:57 PM   #9
Ninjinsky
Ninjinsky's Avatar
I would be concerned about where the link went. Even if it as on the wrong way it is not likely to come off in normal use, suggesting it was stolen ( or that you are ahead of someone in the office promotion race )
Old October 6th, 2014, 03:19 PM   #10
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
They come off.
Old October 6th, 2014, 03:42 PM   #11
no safetywire means its not staying on.
i use only clips now. if i don't remember to safety wire it shut, it is gone in a day. usually only happens if i forgot and get above 80mph... i think its the speed that the chain takes the corner of the front sprocket at that does it.
Old October 6th, 2014, 03:46 PM   #12
There are many... but you decide what you trust.
Exhibit A
Exhibit B
Exhibit C
Up to you, other have zipped tied them as well.
Old October 6th, 2014, 03:47 PM   #13
C.
pick option C.
Old October 6th, 2014, 04:49 PM   #14
Ninjinsky
Ninjinsky's Avatar
Weird I have had clips only since 1968 and never had one come off. Maybe it is something about putting them on? I get everything lined up flat in the grooves and snick it in with a pair of slipjoint pliers between the pin and the back of the clip. That minimizes any stretching and zero twist.
I also clean the chain in situ so they generally only get used once
Old October 6th, 2014, 04:56 PM   #15
well theres the problem! i thought you were supposed to install clips using bubblegum and tweezers?
seriously though,
how else are you supposed to install a clip? you put the link wall on the pins, push it as far as it goes with the grips, then install the clip and snap it on using the grips again. i have had a few clips last longer. but when i safetywire it, it does not come off. one way you are trusting the spring of the metal clip to hold tight. the other way you are trusting a piece of metal not to snap in half. i would rather push the limit to it snapping rather than the limit being it gets a little bit loose and falls off.
Old October 6th, 2014, 04:58 PM   #16
salcuta88
salcuta88's Avatar
Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat)
Just don't get a bicycle chain like someone did and then it broke.
salcuta88 is offline   Reply With Quote
Old October 6th, 2014, 05:12 PM   #17
Ninjinsky
Ninjinsky's Avatar
seriously though,
Oh I have seen people put the closed end on and try to pry the open end over the pin and try to take them off with a screwdriver under the middle of the prong trying to "unhook" the open end from the groove.
Not everybody works the way you and I do
Old October 6th, 2014, 05:26 PM   #18
... but the clip comes with instructions!
haha. i guess there are no bounds to human stupidity
Old October 6th, 2014, 05:29 PM   #19
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I have a clip. I used pliers to put them on and followed DID instructions. Reached above 120. Clip still there.
Old October 6th, 2014, 05:31 PM   #20
i wonder if it is actually hard downshifting that pulls untied clips off... i do that a lot.
Old October 6th, 2014, 05:32 PM   #21
also i'm going to hit you, nick.
Old October 6th, 2014, 05:43 PM   #22
Ninjinsky
Ninjinsky's Avatar
You train one of these to use pliers and he refits the clip on the move.
Last futzed with by Ninjinsky; October 7th, 2014 at 02:01 AM.
Old October 6th, 2014, 07:20 PM   #23
https://www.ninjette.org/forums/show...618#post563618
I just got no faith in them. I have some that stayed on, others that when mia after some time, and others that vanished into thin air the next day. YMMV
Old October 6th, 2014, 10:05 PM   #24
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
<3
Old October 10th, 2014, 07:29 PM   #25
mrudich
mrudich's Avatar
I got a new clip for now and plan on safety wiring it as soon as I can (afford to purchase the necessary wire/tool)
Riveting new master-link headshrink 2008 - 2012 Ninja 250R Tech Talk 13 December 17th, 2011 06:39 PM
Watch your master link clips!!!! bdavison General Motorcycling Discussion 42 October 7th, 2011 08:07 AM
[hell for leather] - Found: the missing link Ninjette Newsbot Motorcycling News 0 January 7th, 2011 01:50 PM
[topix.net] - Motorcycling's missing link Ninjette Newsbot Motorcycling News 0 June 26th, 2010 02:02 AM
[hell for leather] - Motorcycling's missing link Ninjette Newsbot Motorcycling News 0 June 25th, 2010 08:00 PM
