Old December 26th, 2020, 06:42 PM   #1
Tommygriffin
Motorcycle(s): 2010 Ninja 250j
全uuup?
New guy here....and iii知 Fiiifty! (SNL season 42) Been trolling the site for years, just registered. I ride a 2010 250. Currently with 58k miles. It痴 my 3rd 250. Had an 89 VTR 250, and this is my 2nd ninja. Best bike ever. 10 years in for this one. Happy to be a part of the .org finally!!
Tommygriffin is offline   Reply With Quote
Old December 26th, 2020, 06:53 PM   #2
Tommygriffin
(Replying to my own post) I知 not sure where to post questions, but I知 replacing my cylinder cover gasket, and I壇 like to know if the gasket is supposed to be flat on the top? It just looks odd considering the cover is grooved. I値l be using silicone where it goes per the manual, but should I put silicone on the top of the gasket too?
Old December 26th, 2020, 09:34 PM   #3
Hi Tommy! Welcome to Ninjette !!!
Yes, flat where it meets cylinder-head. Grooved on cover side.
Don't use silicone, it doesn't stick very well when there's oil around. Also on newer bikes with EFI, it tends to sneak through to exhaust and foul up O2-sensors. Use FIPG material such as Toyota 00295-00103, Yamabond-4 (not 5), Permatex The Right Stuff Grey.
Apply where manual instructs. If you want, apply just tiny bit on flat side, a fishing-line sized bead. Top side not needed due to groove and labyrinth sealing. Also don't over-tighten valve-cover bolts. They bottom and stops pressing on gasket after certain point. More torque will just snap valve-cover bolts.
Last futzed with by DannoXYZ; December 26th, 2020 at 11:23 PM.
Old December 27th, 2020, 08:21 AM   #4
Tommygriffin
Interesting, the gasket I have is flat on top where it meets the cover, which is grooved, and is grooved on the bottom where it meets the head, which is flat. I know it痴 oriented right because the half moons are down. The old gasket seems to be shallowly grooved on both sides. Willy the new gasket create it痴 own grooves when torqued?
Old December 27th, 2020, 09:58 AM   #5
Welcome!
Old December 27th, 2020, 11:43 AM   #6
Tommygriffin
Every gasket that I see online is flat on top, grooved on the bottom, so I have to assume it is correct and I’m installing it
Old December 27th, 2020, 07:35 PM   #7
NinjaPony
New rider
NinjaPony's Avatar
Motorcycle(s): 2021 Ninja 400 (abs), 2004 NinjaEx (2007 motor)
Welcome!! Happy Holidays!!
NinjaPony is offline   Reply With Quote
Old December 28th, 2020, 11:42 AM   #8
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old December 28th, 2020, 01:15 PM   #9
Snake
Snake's Avatar
Hello and welcome!
Old January 2nd, 2021, 11:19 PM   #10
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
Welcome aboard!
GAU-8 is offline   Reply With Quote
Except where otherwise noted, all site contents are ゥ Copyright 2022 ninjette.org, All rights reserved.
