Old May 27th, 2016, 04:22 PM   #1
redranger08
Motorcycle(s): 2008 250r
tire size question....
im looking to get new tires for my little 08 250r and was thinking about getting the shinko 006 podiums. will running 110/70 in the front and running 140/60 in the rear cause any problems? what about running 120/60 in the front and 140/60 in the rear? thanks!
redranger08 is offline   Reply With Quote
Old May 27th, 2016, 04:25 PM   #2
In order to help you out, we will need to know what type of riding you do the majority of the time. The tire options are much different if you are a commuter vs a canyon carver. As far as a 110 & 140 rear, there should not be any out of the gate problems as many of us run those sizes with success.
Let us know please.
Old May 27th, 2016, 04:27 PM   #3
/moved to new-gen tech
Old May 27th, 2016, 04:38 PM   #4
redranger08
sorry i didnt know where to post this tire question and thanks for moving it alex.. as for the riding style, its mostly a weekend canyon carver. right now i have 110/140 supercorsas on it but, they are 70 series and they run fabulous.flicking the bike is very easy and turns in very well! i was just concerned about the height differences of the tires and the effect of the steering thats why i threw in the 120/60 vs 110/70 front tire so that the height of both tires are the same. plus i like matching tires =D
Old May 27th, 2016, 06:47 PM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
The short of it is.
1. Radials are best for fun
2. Matching doesn't matter in the least
3. No one on here will suffer or benefit from minor changes in ride height with different aspect ratios, your simply nowhere near fast enough
4. The larger the aspect ratio on the front tire the better and more even it will tip into the corners, this is a good thing.
5. stay with the 110 on a stock width front wheel
6. 140 rear should be fine but if you change gearing make sure you drop the rear as opposed to going to a 15t front. this will ensure you maintain clearance to the front of the swingarm.
I'll let the other explain the details
metric thread size question mikedabike64 General Motorcycling Discussion 7 March 26th, 2014 06:57 PM
Tire size question sidekick10121 1986 - 2007 Ninja 250R Tech Talk 5 March 11th, 2014 06:39 PM
Track Tires and size question tooblekain Ninjettes At Speed 33 August 20th, 2013 08:22 AM
New Owner - has different size tires than factory, tire pressure question 94fiveohvert 2008 - 2012 Ninja 250R Tech Talk 5 November 16th, 2011 04:37 PM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
