Old April 7th, 2009, 06:23 PM   #41
randomwalk101
self wrencher
randomwalk101's Avatar
Originally Posted by Sloppy2nds View Post
Ok got mine installed tonight. No DIY and pics since its a fairly simple install, but ill cover some things to look out for to save you all some pain and time.
1. I used all the stock hardware from the OEM signals except for the locking nut that comes with the protons which I used.
2. This is fairly obvious, but when you cut the wires that go to the OEM signals the black is always your ground and the green is your hot.
3. You will need resistors, or even better get a new relay from autoparts store should be like $10-$15. why? because these are LEDs and there is not enough load. Therefore your OEM relay thinks theres an open and the rear blinkers wont flash. If youre getting resistors get 8-10 ohm. There are also load balancers that other places sell but I recommend a new relay.
Hope this helps and feel free to ask if you have any more questions.
No pics..it didn't happen
Old April 7th, 2009, 06:27 PM   #42
kazam58
Sarcasm: Yea that'll work
kazam58's Avatar
Motorcycle(s): '08 Ninja 250R
kazam58 is offline   Reply With Quote
Old April 7th, 2009, 06:34 PM   #43
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Holy crap John, what flushmounts?!?!?
All I see is one sexy bike.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old April 7th, 2009, 06:37 PM   #44
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Motorcycle(s): '06 R6/'08 250R
ehhhh.....too lazy and cold to take pics. I was wiring that thing up like a mad man in the garage with my hands freezing trying to crimp everything together.
Sloppy2nds is offline   Reply With Quote
Old April 7th, 2009, 06:42 PM   #45
kazam58
kazam58's Avatar
Quick question. I hate electricity and know little about it (besides what I learned in Physics...) If you buy a new relay would it still work with the stock rear signals or would those have to be LEDs too?
Old April 7th, 2009, 06:48 PM   #46
randomwalk101
self wrencher
yup, swap out your stock flasher relay will work...i swapped mine out a year ago when switching to LED signals... no resistor = no heat
Old April 7th, 2009, 06:50 PM   #47
kazam58
kazam58's Avatar
Cool.
Man, now that my wrist is semi-functional again my to-do list doubled...
Old April 8th, 2009, 07:41 AM   #48
Buffalony
Buffalony's Avatar
Cool.
+1
I cant believe these require another purchase. F^ck.. for the price!!!!!
I swear it said they were internally balanced for use right outta the box..These r bs. Look good though
Old April 8th, 2009, 08:23 AM   #49
Rynownd
Rynownd's Avatar
Originally Posted by Buffalony View Post
+1
That's exactly what I was thinkin' when I saw Sloppy talkin' about resistors! The description on NewEnough definitely says you don't need resistors. WTF!?
http://www.newenoughhp.com/parts/tur...n_signals.html
"Internal load balancer prevents the Proton LED’s from “fast flashing” – No resistor’s necessary!"
Mine should be in soon. I'm wiring them without resistors to check first. If that doesn't work NE is gonna be hearing from me!
http://www.southparkstudios.com/clips/224099
Rynownd is offline   Reply With Quote
Old April 8th, 2009, 08:36 AM   #50
Buffalony
Buffalony's Avatar
Yeah ya know. "WTF" $100!!!! Get out of here maniacs....they're two little f-ing lights!
Post back if you wire these up W/O flasher relays and they work.
If they don't then please gently inform NE so they know then send a nasty Email to high tech speed telling them they sould include the frickin resistors or advertise if they're needed or not. crap. but they still look good f-ers
Last futzed with by Buffalony; April 10th, 2009 at 02:45 PM.
Old April 8th, 2009, 09:16 AM   #51
Rynownd
Rynownd's Avatar
Post back if you wire these up W/O resistors and they work.
That's the plan.
Old April 8th, 2009, 02:45 PM   #52
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
I agree....the site should get rid of the "no resistors necessary" part of the description. Heres why, they need resistors or new relay per Mike at HTS. "The Proton lights have a timing circuit that measures the blink rate of the OEM flasher and will adjust their blink speed to compensate. They don’t actually add load so the flasher will generally still speed up when the Proton lights are installed."
Which is a problem on our bikes because almost on every other bike in the entire world an open in the flasher circuit constitutes a faster flash. Well in Kawasaki's infinite wisdom they changed the relay for the 250R so it will be steady instead. Im pretty positive the other Kawis have the "fast flash if open circuit" thing too.
Lastly, If you guys decide to go with these blinkers I really recommend getting the new relay instead of going the resistor route.
I feel your guys pain....I was pretty pissed off myself when I had to go for a relay run to the autoparts store. I felt the same way wondering what was going on and why it wasn't working but, then it all made sense after experimenting a little. I didnt mind getting the relay since I plan on getting the CA integrated tails and that will cause the same problem so I would have had to replace the relay anyways.
Last futzed with by Sloppy2nds; April 8th, 2009 at 07:33 PM.
Old April 8th, 2009, 03:03 PM   #53
randomwalk101
self wrencher
So how is the fitment? Visibility from the front???? Any review, feedback??????
Posted via Mobile Device
Old April 8th, 2009, 03:19 PM   #54
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Fitment and finish quality are top notch. Visibility is excellent, with the rider off these can be seen from front, side, and rear of the bike. I didnt expect anything less from these guys on overall quality since I've owned their blinkers and know a lot of people that have the same on many different bikes. I am a little dissapointed in the fact that it does need something additional to complete the install and their website says no resistors needed. For the 250s I think they need to remove that part in the description since I dont think they will change the circuitry from the way it is now.
Pics are attached on first post so they dont get lost in this thread. They are from my phone so theyre not the greatest.
Old April 8th, 2009, 04:42 PM   #55
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
hi guys,
i'm new here (rookie rider) and looking to get an 09 250 soon.
they are very nice. how much do they run for?
i've seen the color on the rims of a lot of bikes. are they painted on or tape?
thanks,
tn
tinng321 is offline   Reply With Quote
Old April 8th, 2009, 07:04 PM   #56
Rynownd
Rynownd's Avatar
Lookin' good Sloppy, just realized you posted pics on the first post. OK, so at this point I'm hopin' I can wire the resistors from my rear signals into the same parallel as these... already bummin' 'bout this.
Old April 8th, 2009, 10:02 PM   #57
miks
I'm lovin' it.
miks's Avatar
Originally Posted by tinng321 View Post
hi guys,
thanks,
tn
Can't answer your price question, but as for the colour on the rims most people get rim tape, the only painted rim I know of is Beast's bike. Heres a picture, hope he doesn't mind.
And the flushmounts are look good mate.
Old April 9th, 2009, 04:43 AM   #58
tinng321
tinng321's Avatar
wait i'm confused. isn't rim tape goes inside your tire to protect the tubes?
Old April 9th, 2009, 05:17 AM   #59
Rynownd
Rynownd's Avatar
No, rim tape or rim 'stripes' are a cosmetic modification. Some can be considered a safety mod because they are reflective. But, in general, they are just a colored strip that goes around the wheel between the spokes and the tire.
Here's one of the first google image hits:
http://image06.webshots.com/6/5/81/9...6GOaXHz_ph.jpg
Old April 9th, 2009, 06:05 AM   #60
miks
I'm lovin' it.
miks's Avatar
Pretty much what Ryne said, Rim tape is for looks but reflective ones can help a rider be more visible at night time.
Old April 9th, 2009, 08:09 AM   #61
Rynownd
Rynownd's Avatar
Ok, so back to the point.
I just spent about 40 minutes on the phone with New Enough as well as the ‘Proton’ guys. NE had called me because my shipment was lost. They promptly refunded my money for shipping, and assured me they would be here soon. I took that opportunity to ask Nate what the situation was with this whole ‘do the Proton Flushmounts require resistors thing.’ He admitted that his electro-mechanical knowledge was minimal. He also said that due to bikes being different, even within the same manufacturer AND model, he is constantly arguing with customers about this issue because there isn’t just one fix for everything. He put me in contact with the people that manufacture these lights.
So I got in contact with Mike ‘the Proton guy’ and started asking him questions. We were talking specifically about my bike and, as some of you may know, I have LEDs in the rear and a resistor from eBay that I’m using to compensate the load and correct the flash rate. So I asked him if I would need resistors for the front, if I could wire the resistors I have in the back to the front also, or if they would just work without any extra? He told me this: the Proton Flushmounts do not have resistors on the circuit board. They do, however, have some means of sensing the flash rate and compensating for it. Mike told me that they MIGHT work for the front, but would probably cause the rears to flash at a different and faster rate. He then suggested I do what Sloppy said and replace my flasher relay with one from Pep Boys/Auto Zone. I then asked him what the difference was. He told me that our bikes/bikes in general have a mechanical relay and these replacement ones from the store are electronic and intuitive, and would therefore correct flash rate for both the front at the rear.
OOOK that was long… sorry
At this point I have a question for Sloppy: Did you replace your signal relay BEFORE you got the Protons? If so, did you still need resistors? What is your entire signal setup (types of lights all around), resistors, relays etc.?
PS My lights will be here no later that Saturday, hopefully I can get them installed and get a real answer to all this soon. I will keep you guys updated.
Old April 9th, 2009, 12:45 PM   #62
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Talking
My setup:
-No resistors
-changed to new relay
-proton front flushmounts
-Stock Rear for now
Ryno, for your specific bike I recommend replacing the relay and removing that resistor you already have for the rear LEDs. The only reason you put resistors on a relay is to put load on the circuit so the stock relay thinks the entire circuit is good and close or fine and dandy. Ideally you probably should have changed your relay when you changed your rears to LEDs. Once the stock circuit senses an open nothing flashes. Which is what it is designed to do so you know that a bulb is out. Technically you could also add more resistors to your circuit when you install the protons to add more load. The problem with resistors is the heat. A few bucks more and you will have a new relay that will work great and you can remove all the crappy looking resistors (less work). Hope this helps and somewhat easy to understand I explained the best I can.
Old April 9th, 2009, 01:07 PM   #63
Rynownd
Rynownd's Avatar
My setup:
-No resistors
-Stock Rear for now
Thanks for the info! I totally know what you're saying. I've been reading a lot about this lately, not to mention it's a pretty big part of my studies for the MS degree.
I went out and bought a flasher. I just bought the first 2 pin one I saw... so I'm not totally sure it will work, but I was bored and needed some where to ride. I'll compare it to the stock one before I open the package so I can take it back if I need.
Protons will be here no later that Saturday, so I'll find out if all this works soon.
Here is a picture of it:
If you can't read it, it says: FL32, Electronic Flasher, Truck and RV, Variable Load, HEAVY DUTY
Old April 10th, 2009, 06:49 AM   #64
randomwalk101
self wrencher
Protons for the fronts...do you guys swap out LEDs signal for the rear too?
Old April 10th, 2009, 07:27 AM   #65
Rynownd
Rynownd's Avatar
I have LEDs in the rear: http://www.ninjette.org/forums/showthread.php?t=16648
Sloppy does not.
Old April 10th, 2009, 07:48 AM   #66
randomwalk101
self wrencher
Talking
Sloppy does not.
ahh..resistors...becareful, those suckers get hot..plastic melting hotness
Old April 10th, 2009, 07:49 AM   #67
Rynownd
Rynownd's Avatar
Yeah, I'm lookin' to get rid of them.
Old April 10th, 2009, 08:37 AM   #68
randomwalk101
self wrencher
do you know how?
Old April 10th, 2009, 09:21 AM   #69
Rynownd
Rynownd's Avatar
do you know how?
Joke? If you read this thread, we've been talking about it. I know I need a new, electronic, signal relay. I bought one, but I don't think it's the right one. Any idea if it is? If it's not, which one should I get? Not trying to mail order any more stuff... lookin' to shop locally now.
Old April 10th, 2009, 09:43 AM   #70
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Im 99% sure that relay you have in the pic will work. If not take your stock one off take it to any autoparts store and ask for one.
Old April 10th, 2009, 09:44 AM   #71
randomwalk101
self wrencher
no joke I'll let you have fun figure things out
I'll give you a hint..it's all in the search button but may be kkim may be able to help you out
Old April 10th, 2009, 09:47 AM   #72
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
What are you talking about dude? Why all the hush hush?....just help the man out.
Old April 10th, 2009, 09:51 AM   #73
randomwalk101
self wrencher
awwee..u no fun
Old April 10th, 2009, 09:51 AM   #74
Rynownd
Rynownd's Avatar
I've been searchin'. I'm sure I'll figure it out eventually. Unfortunately for me, the weather is so ****** right now, I can't try anything. Tomorrow is another day...
Old April 10th, 2009, 09:55 AM   #75
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
awwee..u no fun
eh youre right......I've been on the other forum :ahem: kawiforums :ahem: too much lately I guess....where the ass hatness outweigh the help.
Old April 10th, 2009, 10:02 AM   #76
randomwalk101
self wrencher
oh you're right...the info was on the other forum..not this one Opps, my bad.
Anyways, that elec relay is okay for 2 LED signals. But in order to have four LEDs, you need to add a couple of diodes to the bulb/signal indicator. Kawi (and some others like Aprila) combines both right/left signals into one...so you need to put the diodes in to prevent backflows. This is true with the case of putting four LEDs in, when you hit the signal, all four signals will light up solid. Diodes solves this issues...Elec flasher corrects the flashing rate.
Yes, resistors will do but will heat up if you forget to turn off the signals..may cause wires or plastic to melt. Heat will eventually kills the resistors too...not the best route.
Old April 10th, 2009, 10:08 AM   #77
Rynownd
Rynownd's Avatar
Ok, I'm now even more 'confused', an LED IS a diode. So, WTF mate?
Old April 10th, 2009, 10:26 AM   #78
randomwalk101
self wrencher
LED is a type of diode.. Look at the attached pictures.
Old April 10th, 2009, 11:20 AM   #79
Rynownd
Rynownd's Avatar
I see those. At this point, it all depends on how early I get up tomorrow. If I'm up early enough to try any of this stuff, I will. Otherwise, I'm headin' out to Muncie to see my sis.
Old April 10th, 2009, 02:53 PM   #80
randomwalk101
self wrencher
i have carefully calculated your feng shui...June 16th is a good day to do it LOL
Ordered the Proton Flush Mounts today Old Guy on a '08 2008 - 2012 Ninja 250R Farkles 5 September 10th, 2012 03:32 PM
DIY: Proton Flush Mounts Momaru 2008 - 2012 Ninja 250R Farkles 66 June 24th, 2012 09:58 PM
Shinto Clip-ons, Bike Monkey Integrated Tail and Proton Flush Mounts Mac Motorcycle-related 9 November 21st, 2010 02:52 PM
Proton Flush Mounts Jerkson Motorcycle-related 6 September 23rd, 2010 05:23 PM
cheaper Proton flush mounts istreefitty 2008 - 2012 Ninja 250R Farkles 8 July 19th, 2009 08:47 PM
