Old November 1st, 2010, 10:05 AM   #1
RyanJames
2010 250r
Motorcycle(s): 2010 250r
Help. Idle Adjustment Knob cable came off.
I have a 2010 250r that has an idle adjustment knob cable not connected to anything. As a result the idle speed is low so that the bike does not run without the choke on. Where does this metal cable screw into? I am talking about the threaded end not the knob.
Any responses are appreciated.
Thank you
Ryan
*http://www.ninjette.org/forums/showthread.php?t=46093 Found this seconds after posting. Thank you forum and kkim for the fix.
Last futzed with by RyanJames; November 1st, 2010 at 10:15 AM. Reason: Found similar thread that covered the same thing.
RyanJames is offline   Reply With Quote
Old November 1st, 2010, 11:12 AM   #2
Thank you
Ryan
so, was yours off at that end and did reattaching it fix the problem?
Old November 2nd, 2010, 06:16 AM   #3
RyanJames
2010 250r
Yes I was able to screw it back in without having to take anything off the bike. I am missing the spring but the idle adjustment knob is functional and I am able to increase/decrease the idol speed. Again thank you for the pictures in the other thread. They showed me where the cable goes exactly and I could not find them anywhere else online.
Ryan
Old November 2nd, 2010, 11:22 AM   #4
cool... I suggest you replace the spring when you have the chance, though.
Cable adjustment perch hole stripping indr 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2013 05:25 PM
HELP! idle adjustment screw came out! str8t six 2008 - 2012 Ninja 250R Tech Talk 5 March 21st, 2012 10:30 AM
idle screw adjustment headshrink 2008 - 2012 Ninja 250R Tech Talk 6 February 5th, 2012 08:46 PM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
Clutch cable adjustment SteveL 2008 - 2012 Ninja 250R Tech Talk 2 August 17th, 2009 12:39 AM
