Old September 18th, 2012, 08:58 AM   #1
gogiburn
Motorcycle(s): have 24
15 41 sprocket change
did my first full tank since changing sprockets got 445.3 on the tank with 4.7 gallons to fill rpms now 1000 rpms per 10mph 5500=55mph
gogiburn is offline   Reply With Quote
Old September 18th, 2012, 09:19 AM   #2
EMSRacer07
EMSRacer07's Avatar
Nice. Good going that puts you over 90mpg . I have my gearing at 15/42 and im just right above 10mph per 1000rpms. Last tank i couldnt get over 83mpg, but then again I hit the highway and was doing 80mph so that probably hurt it.
How do you like riding with the new gearing?
Old September 18th, 2012, 10:28 AM   #3
I normally run 15/42 and find that I don't shift as much for the twisties but dip sub 8k from time to time. Freeway comfort is better for me but lacks in passing speed without a downshift. Even ran it on track to keep the bike more in the sweet spot of 8k+ rpm in the back half of the corners and was successful. And it totally sucks with a good stiff headwind.
How on earth do you get those mpg. I am lucky to get 60mph. I am 190lb, fully geared up.
Old September 18th, 2012, 10:40 AM   #4
EMSRacer07
EMSRacer07's Avatar
anything beyond 7k rpms will use up more gas. im about 165lbs all geared up though. and I have lightened and taken stuff off that i didnt need, ie pass pegs, cables, stock exhaust. But yeah it lacks somewhat on the freeway but drop one gear and your gold
Old September 22nd, 2012, 02:05 PM   #5
Solunatic
Solunatic's Avatar
Motorcycle(s): 1990 Ninja 250 "Jolene"
Holy crap! I thought I was doing good with my 65 mpg..
i don't know that that gearing setup would work well for me though, with the hills i ride in daily just going to a 15 tooth was a big adjustment.
How was your mileage affected with the aftermarket exhaust? Usually i hear of mpg going down because of increased airflow, but that seems not to be the case here?
Solunatic is offline   Reply With Quote
Sprocket Change? csmith12 2008 - 2012 Ninja 250R Tech Talk 17 April 9th, 2014 03:20 PM
Sprocket size change mrudich 1986 - 2007 Ninja 250R Tech Talk 1 April 2nd, 2014 06:27 AM
Sprocket Change W.Roworth General Motorcycling Discussion 10 November 5th, 2012 08:03 PM
sprocket change sacreyc Help 3 July 12th, 2011 05:11 PM
Rear sprocket change red 2008 - 2012 Ninja 250R Tech Talk 16 November 20th, 2010 07:30 AM
