Old October 21st, 2014, 09:32 AM   #81
Originally Posted by M42 View Post
Well, it's been at @Finesse 's shop getting tapped... they finished the tap, fired it up, and it sounds awful. Either a shaving fell in or the piston slammed the plug or somesuch. Rip bike.
Incidentally, who wants a rolling chassis
make sure they measured the bolts for stretching. any time you remove those head bolts -- especially older ones-- if you don't replace them with brand new ones you run basically a 50/50 chance of stretched head bolts which will throw everything out of wack and make this terrible loud ticking noise.
if this is the case, simply replacing the head bolts with fresh ones can fix the issue. if its just stretched bolts there might not really be any damage.
i mean. honestly they would have been able to tell if it had a blown crank bearing when they had the head off... so if its not that its probably the head still.
my money is on stretched bolts.
Old October 21st, 2014, 09:53 AM   #82
Ninjinsky
Ninjinsky's Avatar
Did they tap oversize and use a different reach plug or was it coiled?
Aluminum shavings shouldn't do much, just blow out the exhaust after a coupleof cycles
Try turning it over by hand (socket on the alternator bolt) and see if you can hear anything knock, if not it might be a shaving under a valve seat which a compression tester will show.
Old October 21st, 2014, 10:36 AM   #83
and if it is a shaving that has damaged the valve seat, a re-lapping isn't that big of a deal.
Old October 21st, 2014, 11:31 AM   #84
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
I know it's possible to fix it, but I'm completely out of patience for working on this bike, and I've been jonesing for something peppier for the whole season. I can't do the engine stuff myself, and it's not worth it to pay someone else even more money to do it for me, so yeahhh.
M42 is offline   Reply With Quote
Old October 21st, 2014, 12:07 PM   #85
i'm all for buying more bikes... but maybe i'm on a different line of thinking. if its already broken and you've given up on it, what worse could you do to it? maybe its worth messing around with it just to learn about engines so you can take better care of the next one? best case, you fix it and have another engine. worst case, it's still broken.
Old October 21st, 2014, 12:26 PM   #86
M42
Wrench wench
M42's Avatar
If I had a garage, perhaps. I'd be tearing it down in a parking lot, so I can't leave it lying torn apart out there day after day. Everything needs to be buttoned back up at the end of the day. I don't own any engine lifts/bike stands/etc either, just ratchets and a torque wrench.
Old October 21st, 2014, 01:13 PM   #87
you don't need fancy stands or lifts. and this is what kitchen tables are for!
Old October 21st, 2014, 01:22 PM   #88
nbleak21
Motorcycle(s): '09 Ninja 250r
I need some parts, may be interested in rolling chassis if it's cheap enough where abouts are you located?
nbleak21 is offline   Reply With Quote
Old October 21st, 2014, 01:30 PM   #89
M42
Wrench wench
M42's Avatar
Pretty far from you, in the DC metro area. If I decide to sell it, I'll post it on ninjette of course.
Old October 21st, 2014, 01:47 PM   #90
Old October 21st, 2014, 02:03 PM   #91
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Come on guys, leave her alone lol. She doesn't want to mess with it any more, I understand not wanting to mess with it after a certain point. Just toss it up on craigslist and call it a day.
RIP 248
Maybe save up for a different bike? Keep us updated on what you decide to do.
Be careful. Remember you are
invisible
Old October 21st, 2014, 02:49 PM   #92
MrAtom
MOTM - July '15
That sucks so much to hear about your bike. Just curious, how many miles did it go before it got to this point?
Old October 21st, 2014, 03:19 PM   #93
M42
Wrench wench
M42's Avatar
Just a hair under 15k. :\ I treated it well and took good care of it while it was in my possession, too. Or at least I thought I did.
Old October 21st, 2014, 03:22 PM   #94
nbleak21
Yes, that Is indeed a bit far! If you decide to part it out, I'm looking for handlebars & controls, and front and rear tires/wheels for a side project of mine.
Old October 21st, 2014, 03:28 PM   #95
MrAtom
MOTM - July '15
What are your plans for your next bike?
Old October 21st, 2014, 03:57 PM   #96
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Sucks to hear it couldn't be saved.
Old October 21st, 2014, 04:08 PM   #97
M42
Wrench wench
M42's Avatar
Well... there IS a really good deal on an SV that I'm going to see this weekend
Old October 21st, 2014, 04:19 PM   #98
is it finesse's? After she killed your bike, you're buying hers?!?!?
Old October 21st, 2014, 04:31 PM   #99
MrAtom
MOTM - July '15
That's evil genius material right there!
Old October 21st, 2014, 05:32 PM   #100
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
RIP little ninja, join my 88 and 99 in ninja heaven.
There is a loud knocking noise at idle that quiets down when it's revved. It's hard to start, won't idle without choke and has low compression in the right cylinder, rides okay but I'd say it's pretty much toasted.
Instagram: @katie.baden
Finesse is offline   Reply With Quote
Old October 23rd, 2014, 07:20 AM   #101
M42
Wrench wench
M42's Avatar
I went and put it up on CL, just to see if I get any responses. Doing an experiment - two ads, one wordy and one succinct. Gonna see what gets more responses.
https://washingtondc.craigslist.org/...727515029.html
https://washingtondc.craigslist.org/...727516067.html
Old October 23rd, 2014, 04:08 PM   #102
Ninjinsky
Ninjinsky's Avatar
Not sure how a stripped plug thread could achieve all that
Old October 23rd, 2014, 04:14 PM   #103
maybe putting carb cleaner on it would help :P
Old October 23rd, 2014, 05:02 PM   #104
Ninjinsky
Ninjinsky's Avatar
I know exactly where I would like to put the carb cleaner right now
Old October 23rd, 2014, 05:03 PM   #105
Skullz
Skullz's Avatar
I have a question to ask, did you pull the plug back out after the helicoil to see if that was hitting the piston?
If the plug is hitting the piston they make indexing washers to shim the plug so it points toward one of the valves for a better burn, but you could use those to shim the plug out to prevent it from hitting the piston.
http://www.summitracing.com/search?S...xing%20washers
Old October 23rd, 2014, 06:51 PM   #106
M42
Wrench wench
M42's Avatar
It's still at the shop, imma see it saturday. I don't think a mechanic would have put the plug in so bad that it was hitting the piston. I probably let some metal shavings fall in when I pulled that threadpiece out with the new plug, before it went into the shop.
Old October 24th, 2014, 12:02 PM   #107
Ninjinsky
Ninjinsky's Avatar
I don't think the coil is wide enough to affect plug reach but I have seen the coils themselves turn with the plug, usually coming out but maybe being fresh machining here turning into the cylinder, just a thought.
Old October 25th, 2014, 12:18 PM   #108
M42
Wrench wench
M42's Avatar
Hahaha, alright, scratch all that - I just rode it back home. The threads were so gone that the helicoil didn't work perfectly, so the plug's not fully sealed around the edges and there's a little blowby. Bossman said it would feel like a 175 cc, but I spent 40 minutes at the highway at 65, at normal rpms. I think maaaaybe it accelerates a little slower, and it won't idle without choke/idles really high, but it's nowhere near as destroyed as I thought.
Old October 25th, 2014, 12:26 PM   #109
This statement confuses me. When I had mine repaired, they put the head on a drill press, drilled out the old threading, tapped it so it had clean threads (note that the hole is now bigger than before) and installed a helicoil that worked with the stock size spark plug.
In other words, the existing condition of the stock threads should have nothing to do with how effective the helicoil is, because they're going to be drilled out to a larger diameter and tapped to another thread any way.
soooooooooo did the shop muck up and give you a BS excuse for why the repair didn't work as advertised? or are you just confused at how a Helicoil works? I don't mean to be blunt, but something in this whole situation rubs me the wrong way.
Old October 25th, 2014, 01:30 PM   #110
M42
Wrench wench
M42's Avatar
I have a notoriously awful memory so I'm paraphrasing. I remember they did say they tapped it and it was bigger now, but for real, I will forget something you tell me about 30 seconds later. All I know is that the right cylinder doesn't have full compression. Whatever, I'm still selling it, I'm just glad I could ride it home.
Old October 25th, 2014, 01:33 PM   #111
I see a note pad and pen in your future for note taking.
Old October 25th, 2014, 01:55 PM   #112
M42
Wrench wench
M42's Avatar
That would require me to remember to use it
Old October 25th, 2014, 02:06 PM   #113
Ninjinsky
Ninjinsky's Avatar
Sounds like they went for the larger plug size option I suggested. Though that shouldn't leak
Perhaps Finesse can backfill on what they did.
Do you have an invoice that says
tapping
coiling
or whatever
yadda yadda
new plug to fit
Old October 25th, 2014, 04:51 PM   #114
Finesse
ran when parked
Finesse's Avatar
I don't think the spark plug threads being stripped was the main problem. I think it's probably a symptom of whatever went on inside the engine. I didn't work on it myself so I don't know. I think diagnosing the actual problem would require pulling the motor and seeing what's going on down there, and we'd have to charge actual money to do that and will probably still find that it's ****ed beyond feasibly paying to fix at a shop or buying new engine parts. **** happens, bikes blow up sometimes, for a Ninja 250 it's easier and more cost effective to just buy a new motor or, even better, buy a new bike...
Old October 26th, 2014, 05:16 AM   #115
Wait, yall didn't even pull the motor?! Errrrmmm
Old October 26th, 2014, 05:25 AM   #116
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I can personally say that a couple of slivers of aluminum dropped into the cylinder should not screw up the engine. Ask me how I know.
Old October 26th, 2014, 07:05 AM   #117
M42
Wrench wench
M42's Avatar
I wouldn't even be able to pay for something that involved. Hell, I wouldn't want to, bike was barely worth 1200 when it was running 100%. They did me a huge favor and barely charged me, so I'm not gonna be a huge sourpuss. I'll sell it to somebody looking for a project, end of story.
Old October 26th, 2014, 07:31 AM   #118
Fair enough, I can respect that. Keep us posted with what you replace it with!!
Blew a chain! codestp202 General Motorcycling Discussion 39 July 7th, 2013 05:03 PM
Blew a corner today soggybottom Riding Skills 59 June 5th, 2013 04:28 PM
I blew my knee cuong-nutz Off-Topic 10 April 30th, 2013 02:54 PM
Blew Something in the Engine... Scattcatt 2008 - 2012 Ninja 250R Tech Talk 43 October 29th, 2012 10:59 AM
New Headlight Blew EsrTek 2008 - 2012 Ninja 250R Tech Talk 14 August 21st, 2011 07:10 PM
