Old January 16th, 2014, 06:41 PM   #1
lrmlrm
Motorcycle(s): None Yet
Which bike should I buy?
Hey everyone,
Two bikes are up for my consideration and i can't choose between them. It will be my first bike.
1. 2010 Ninja 250R - Approx. 20,000 K's - Good condition (No aesthetic damage) - Rego expires in a month
OR
2. 2008 Ninja 250R - Approx. 4,000 K's - Visible scratches on left side (Only aesthetic damage) - Rego expires halfway through this year
Same price for the both of them. Re-sell value does come into my decision slightly
Thanks in advance,
Lachlan
lrmlrm is offline   Reply With Quote
Old January 16th, 2014, 06:51 PM   #2
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded)
Have you had a chance to visually confirm the condition of either bike? If the 2010 is truly in good condition and has been taken care of, than I'd lean towards that. The 2008 is 2 years older and saw much less use, which could be a good or bad thing.
Last futzed with by Sykes92; January 17th, 2014 at 02:14 AM.
Sykes92 is offline   Reply With Quote
Old January 16th, 2014, 06:54 PM   #3
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Personally I'd go for the '08 with low miles, the scratches don't matter as much since a lot of first time riders don't really care if a bike already has scratches. you may be low balled a bit but nowhere near as much as you would be for a super high mileage machine. If you want a pristine machine and you hold that belief that you'll never drop your bike ever (rather optimistic view really) then the 2010 is still a good shot. I don't see why either of them would fail updating their rego so the only real concern there is when you budget for it (don't know the australian prices to know if this is a big deal or not)
Old January 16th, 2014, 07:11 PM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
the 2010 is probably better taken care of, the 2008 screams neglect.
TEAM ALFALFA
www.apexassassins.com
Old January 16th, 2014, 07:13 PM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
It is possible that the '08 has been neglected due to it's miles, but that's something that can be figured out when inspecting the bike. make sure to check the chain, that's usually my tell if you're trying to sell a bike with a filthy chain then you're really f*cking up and saying that you haven't maintained it.
Old January 16th, 2014, 07:15 PM   #6
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Honestly i would go for the lower mileage (kilometerage??) bike. The higher one should have had one major service done already and is almost due for its second. The lower one still has a bit to go for the first service so you can get used to riding it before the maintenance schedule rears up and demands attention.
12k miles in 3 years sounds about right, while 2500 miles in 5 years is low. But as long as their owners maintained them and kept them in good condition, either should be good.
<-- Linky
Old January 16th, 2014, 07:16 PM   #7
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
^ What they said.
Also would be good to find out the last time each bike was ridden. If the 08 hasnt been ridden in a long while and not properly stored, it's going to need some carb work.
Old January 16th, 2014, 07:18 PM   #8
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Originally Posted by Sykes92 View Post
^ What they said.
a bike needing carb work isn't necessarily a bad thing though, you can talk the price down incredibly easy by saying a shop would need to fix it and then just clean the carbs yourself.
Old January 16th, 2014, 07:23 PM   #9
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
That's true. I was just talking for convenience sake. Most new riders (including myself) just want a bike to ride immediately. But if he's down to using some elbow grease and learning some mechanical aspects of the bike right off the bat, it's a win-win.
Old January 16th, 2014, 08:01 PM   #10
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I'd go for the higher mileage, newer, better condition one. But only if you had a good feeling it was serviced fairly regularly and well cared for.
Old January 16th, 2014, 08:42 PM   #11
Brian
Brian's Avatar
Motorcycle(s): 08 250R
Why? Just because of the scratches? 250's are usually everyone's first choice of bike so they're bound to have bruises in some spots.
Brian is offline   Reply With Quote
Old January 16th, 2014, 08:47 PM   #12
1
Old January 16th, 2014, 08:51 PM   #13
1 +1 = 2, no... wait
Old January 16th, 2014, 10:32 PM   #14
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
If it were me and I was satisfied with the acceptable condition of both bikes I would see which one I was able to get the better deal on and get that. Having multiple options gives you leverage to further lower the price . If the prices were still the same after all the wheeling and dealing I'd probably give the nod to the #1 ( 2010) moto; 2 years younger, reasonable mileage , no blemishes, better resale value.
Do a thorough exam and test for both bikes and get a look at their service histories. If they don't have any documentation, it probably didn't get done. Good luck!
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old January 17th, 2014, 02:14 AM   #15
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
It's more or so the mileage more than anything. If the 2010 went 12k miles in 3 years, and didn't explode, it was probably well taken care of. The 2008 saw less than 500 miles a year. Putting 500 miles on a bike in one month just commuting or the occasional weekend ride is nothing.
Last futzed with by Sykes92; January 17th, 2014 at 05:44 AM.
Old January 17th, 2014, 03:14 AM   #16
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
What dose the registration have to do with them?
Old January 17th, 2014, 06:34 AM   #17
lrmlrm
Thanks guys, I really appreciate your help. I am leaning towards the 2010 model. I checked it out today and only small blemishes, front tire might need replacing in a couple months but thats alright.
Good luck!
I totally agree with you. They are all the reason im telling myself to get it aswell.
Checking the other one tomorrow morning and will update you guys on what i decide if you're interested.
Also,
It matters because registration in Australia costs me about $500 and because im still a teenager, its a fair bit of extra money to pay.
Old January 17th, 2014, 02:19 PM   #18
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
Keep in mind both need new tires, one due to wear and the other to dry rot.
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old January 17th, 2014, 02:42 PM   #19
fishdip
fishdip's Avatar
It must be different for you guys. In the area I live if you buy or sale a vehicle you have 24h to put new plates on it you cant use the old plates.
Old January 17th, 2014, 02:55 PM   #20
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
In CA, plates stay with the vehicle. Maybe it works the same way there.
Old January 17th, 2014, 06:29 PM   #21
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Miles, Miles, Miles. Chances are if you are not putting time on the bike, you are not taking care of the bike. if my bike sits too long, i have to run a full tank before it runs good.
TEAM ALFALFA
Old January 17th, 2014, 09:23 PM   #22
Brian
Brian's Avatar
There's 100 sides to that thinking though. If he drove it and put so many miles on the ninja then it could have more problems. Someone who maybe would have used it as a daily driver wouldn't treat it like it's $100k, instead, as a daily driver.
Less miles is better unless you're looking at a vintage car.
Old January 18th, 2014, 05:44 AM   #23
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
You havent been around bikes long have you? Motorcycles tend to be crashed before they tend to have mechanical problems. people that put miles on bikes taker care of their bikes. They are meant to be rode.
TEAM ALFALFA
Old January 18th, 2014, 06:12 AM   #24
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
He's right, bikes are often either wrecked or sold before they accumulate that many miles. My 2010 had 4900miles on it when I bought it. I've had it for 2 months and put 550miles on it. That's just commute with occasional exploring.
A neglected bike would never see 12k miles without an issue. With bikes you want something that was babied, not ignored. Your priceless BMW S1000RR, sure maybe not something to daily commute on, something for special occasion other than track days. But a Two-Fiddy? Ride the crap out of it, haha
I want to buy bike qicko General Motorcycling Discussion 12 July 7th, 2014 05:33 PM
How to buy a used bike? iSpeed General Motorcycling Discussion 4 June 11th, 2012 01:02 PM
Why did I buy this bike?!?! solo440 New Members 16 July 28th, 2011 01:42 AM
Help me buy a bike with less power 00v_Lucky Off-Topic 6 April 21st, 2009 05:12 AM
