Old April 20th, 2022, 09:12 AM   #1
Dizzy
Motorcycle(s): 250r
Question 2001 ninja250 response/fuel/spark?
Alright guy check this out I'm believe it is a carb problem it sat a while before that brother road it and had no noticeable problems day he parked it ran fine now acting weird doesn't sound broke gears and clutch work posting a video lmk what yall think I was thinking carb or bad spark or plug..
Dizzy is offline   Reply With Quote
Old April 20th, 2022, 10:48 AM   #2
Dizzy
Motorcycle(s): 250r
Need other opinions 90% think it's the carb stuck got better after drained both of them tapped on it with a wrench too but I'd throw choke on I would kill it with it the choke 1/3 it was running and the video Turn it all the way up guide
e carb
Old April 20th, 2022, 07:50 PM   #3
Yeah, any time sitting for more than 3-months at time will cause carb problems due to dried petrol. Try using some fuel-system cleaner with large dose of PEA.
Old April 21st, 2022, 06:24 AM   #4
I'm a firm believer of using stabilizer prior to anticipated winter storage, riding at least a few miles to assure mixture has penetrated carbs..... followed by bowl drainage.
There is also a "fake starting" procedure (while varying throttle positions) to fully clear all jets after bowl drain is done (petcock turned to OFF)
Also suggest not "warming bike up" over the winter storage season as not riding, (thus not bringing bike up to full temp) creates perfect conditions for invisible condensation damage. So once winterized, suggest to leave it be.
Last futzed with by ducatiman; April 21st, 2022 at 10:30 AM.
Old April 21st, 2022, 01:40 PM   #5
Coincidentally, just woke my older carbed Ducati 900SS up today from its long winter break (put away last Dec 1 )
Using the same exact storage before-after procedures described above, it lit up perfectly, running exactly as it did last year. The procedure flat out WORKS.
Last futzed with by ducatiman; April 21st, 2022 at 05:32 PM.
Old April 21st, 2022, 01:56 PM   #6
Ghostt
Ghostt's Avatar
I am also I firm believer in preparation of winter, and/or not riding the bike for awhile.
The product pictured in the above post is what I use all the time.
As I own multiple bikes, I add some to the tank, and take it on a short ride to make sure it's in the carburetors 💯, if I don't plan on using it for a couple of weeks.
violente et ignorantia
ZX-2R BLOG
Old April 21st, 2022, 02:59 PM   #7
@Ghostt....good to see you here again! Owning a Gold Wing, I trust you'll use stabilizer frequently! Don't want a repeat of carb clean on that!
Owning 3 bikes, at times unpredictable as to when I'll be or not be using them, I'm constantly adding the 360 year round, even on my 2 FI bikes!
Old April 21st, 2022, 07:34 PM   #8
Dizzy
Motorcycle(s): 250r
Yup I'm gonna pull it off and go threw it this weekend maybe and get it going haven't rid it yet think maybe put high octane threw it like some pure fuel might clean the carb up running threw it?
Old April 21st, 2022, 11:26 PM   #9
Ghostt
Ghostt's Avatar
Most definitely, it's always in the Goldwing tank, if not that, then Seafoam., I do this to all bikes
Having 4 bikes myself, 3 of which are Carbie bikes
ZX-2R BLOG
Old April 21st, 2022, 11:41 PM   #10
Ghostt
Ghostt's Avatar
My 2¢,
No need for premium fuel, just be sure it's fresh, also add some Seafoam
Also I recommend sending them to @ducatiman.
There are countless threads of people, whom keep messing with theirs, with no luck, getting mad, and most importantly losing riding time for weeks, and sometimes months.
He has been doing all my carburetor work for many, many years. He just doesn't clean them, he restores them. He has the proper equipment, and knowledge. I have the knowledge, but not the tools to do the job right, but no need to invest a lot of money in the equipment needed to do the job right.
I never discourage others from learning how to work on their bikes, but sometimes one must realize when they are in too deep, mostly is a lack of proper tools.
ZX-2R BLOG
Old April 22nd, 2022, 02:28 PM   #11
Detergent levels in all fuels tend to be similar. Fuel's purpose is to combust. Higher-octane fuels tend to be more chemically stable, more difficult to ignite, making it less desirable as cleaner
What you want to use is product designed specifically to clean fuel-systems. Try some PEA-based fuel-system cleaners.
- Red Line SI-1
- Techron Concentrate Plus
- Gumout All-in-One
- 3M Max Strength Fuel System Cleaner #08814
- Royal Purple Max Atomizer 18000
Old April 23rd, 2022, 12:25 AM   #12
Ghostt
Ghostt's Avatar
My 2¢,
I vote for Chevron Techron Concentrate Plus, I've been using it since the 80s.
Chevron Techron Concentrate Plus Fuel System Cleaner - 20 oz. https://www.amazon.com/dp/B00092893E...F21RTJ4QGN01GM
ZX-2R BLOG
Old April 23rd, 2022, 03:29 AM   #13
NinjaFinally
Motorcycle(s): GPX250R 2006
Hi DannoXYZ,
The Red Line SI-1 (on ebay) claims to have a dosage of "Dosage: 1 (443ml) bottle treats 100 Gallons (378.54 Litres) of petrol".
So does this bottle will treat our 5 gallon tank 20 times over or is it actually used at a stronger strength?
NinjaFinally is offline   Reply With Quote
Old April 23rd, 2022, 03:55 AM   #14
NinjaFinally
The way that it is slow to accelerate from idle is a sign of the idle mixture being lean. That would mean cleaning the jets (and rest of carb).
Old April 23rd, 2022, 10:33 AM   #15
Originally Posted by NinjaFinally View Post
Hi DannoXYZ,
That amount is typically used to treat 10-15 gallons. I suppose it depends on usage. Treat 100-gallons as preventative treatment to keep engine clean.
Then use at higher strengths to remove clogs and build-up. In this case, i'd use 1/3rd-1/2 bottle per tank to clear out carbs.
Some analysis here: https://www.redlineoil.com/Content/f...Tech_6.20_.pdf
Old April 23rd, 2022, 03:30 PM   #16
Well, you have, but you haven't - in a way. Techron gets reformulated almost every year to account for changes in the gas and gas additives that it encounters over the years. Same brand name - different/improved product over time. It's worked well for me as also, and we always have a bottle or two in the garage.
Old April 23rd, 2022, 05:18 PM   #17
You sure that's not formulae in Chevron's pump petrol that gets re-forumulated depending upon season? REID vapour-pressure is adjusted for evaporation volatility depending upon season.
Bottles of Techron Concentrate and Concentrate Plus should remain same? Lemme check MSDS by year.
Old April 23rd, 2022, 09:16 PM   #18
NinjaFinally
Thanks for the great link.
Old April 24th, 2022, 08:00 AM   #19
I'm pretty sure. They make it down the hall from my wife. She's talked to them quite a bit over the years. The additive package included in fuel is essentially Techron at a very low concentration. Sold separately in bottles, it's at a much higher concentration.
No Start - but have fuel, air, compression & spark Bowtie2Bimmer 1986 - 2007 Ninja 250R Tech Talk 26 March 7th, 2016 05:20 AM
No Spark!!! 2009 Ninja 250 EX250 Fuel Injected ghutcheson 2008 - 2012 Ninja 250R Tech Talk 8 April 22nd, 2015 01:44 PM
[motorcyclistonline] - Fuel, Air, Compression, Spark: The Four Horsemen Of Motorcycli Ninjette Newsbot Motorcycling News 0 May 17th, 2009 01:00 PM
