Old February 16th, 2014, 02:38 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
diy tire change equipment
I was wondering if anybody has used something similar to these, the reason why I am asking is the cost is cheaper than if the dealer work to do two tires,
I am just curious this is something I am looking into thank you very much,http://m.ebay.com/itm/330953268947?nav=SEARCH
I will be doing track days on my bike, and anticipate changing a few times, I have a couple sets of street tires, one set of track tires.
Last futzed with by mikedabike64; February 16th, 2014 at 04:33 PM.
mikedabike64 is offline   Reply With Quote
Old February 16th, 2014, 05:57 PM   #2
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
Have you considered getting a set of spare rims and putting the race tires on them? Would be faster than swapping tires on the same rim.
I just use tire irons and an old leather glove to protect the rim when changing tires. But the linked changer may be faster than irons.
flitecontrol is offline   Reply With Quote
Old February 16th, 2014, 06:41 PM   #3
mikedabike64
thanks Lee
Yes that's goal to get spare wheels,
Iam leading toward getting it I cannot justify $80 to have the shop do it when the piece of equipment that I could buy is cheaper than that,
and then I can do my own tires from,
which I would really like to do
, I just wanted to make sure that it was not a piece of junk that won't work, but since you are getting yours changed with tire irons (kudos btw) I am encouraged.
Old February 16th, 2014, 06:55 PM   #4
corksil
Motorcycle(s): A lot.
I just put new tires on my bike a few days ago.
It's the first time I've ever changed a tire.
Was easy. Used two tire irons. Cut up an old oil bottle to protect the rims from gouges. Took an hour start to finish. Front and rear, off the ground to back on the ground.
Youtube change motorcycle tire.
Also used windex for lube.
Old February 16th, 2014, 07:02 PM   #5
if you are going to the track, just bring your front and rear stands and have the tire guy at the track change them for you. it takes them all of 2 minutes
Old February 16th, 2014, 07:43 PM   #6
allanoue
allanoue's Avatar
MOTM - Sep '14
Rojo way
@rojoracing53
http://www.ninjette.org/forums/showthread.php?t=121625
Old February 16th, 2014, 08:19 PM   #7
mikedabike64
thanks Al Alex TC
I see the guys at the track going back & forth with tires all day. fortunately the torque monsters that we own are pretty good on tires well at least for me and the novice group,
I guess realistically I need stands spare wheels,
but I definitely want to learn how to change out my tires,
I'm going to stop by my next track day and see how they're doing the tires & and what the deal is with that like how much $$ etc.
Thanks guys
Old February 16th, 2014, 08:44 PM   #8
Originally Posted by mikedabike64 View Post
.............but I definitely want to learn how to change out my tires.............
Abundance of patience and rubber lube, plus a few tools is all you will need:
http://faq.ninja250.org/wiki/Mountin...tires_yourself
Old February 16th, 2014, 08:55 PM   #9
mikedabike64
ok moto
I have two out of three that's not too bad. Thanks for the link
Old February 16th, 2014, 10:12 PM   #10
rasta
Your face
rasta's Avatar
I can't comment on anything regarding the track. Buuuuuut I do have a tool just like that and it works like a charm. Breaks the bead in seconds. I saw videos of people hitting their wheels with shovels...using a 2x4 under their cars....all sorts of crazy stuff. I said **** it and got a bead breaker instead.
Now if only I changed enough tires to justify that purchase
DIY- Oil Change kkim 2008 - 2012 Ninja 250R Tech Talk 499 March 1st, 2019 09:31 AM
DIY: How To Change/Replace Your Coolant w/ Pictures gilmorec61 2008 - 2012 Ninja 250R Tech Talk 38 March 31st, 2015 01:34 PM
DIY Tire Mounting Stand by RojoRacing rojoracing53 General Motorcycling Discussion 32 January 8th, 2013 10:17 AM
Not a DIY OIL Change just a view and some info Surferboy120 2013 - 2017 Ninja 300 Tech Talk 4 October 8th, 2012 11:44 PM
Front sprocket change DIY? Reyno2ac 2008 - 2012 Ninja 250R Tech Talk 10 June 26th, 2012 05:33 PM
