Old May 26th, 2022, 06:23 PM   #1
Deezg
Deezg's Avatar
Motorcycle(s): 1994 ninja 250
Have spark and fuel but no start 😭
Just got a 94 250 for rather cheap and rode it for 3 days. Then while out riding it just dies. Not locked up but dead. Thought it wasn't sparking but hooked it to a car battery and its sparking. Both plugs are wet with gas. Chem dipped and cleaned the carbs and fresh gas. New ngk plugs. Next is a comp test i guess. Besides compression would there be any other things to check? I can see all the valves move when I turn it over by hand. And it spins as freely as one would assume with the resistance from valve springs. Im stumped. Also if i buy a donor bike with a title would anyone near me want the frame and stuff for cheap? Any advice would be appreciated 👍
Deezg is offline   Reply With Quote
Old May 26th, 2022, 09:46 PM   #2
what colour is spark?
Wet with petrol is way too much! Would indicate your float-valves may not be doing their job and letting too much in and raising float levels. Unless you buy brand-new carburetors from authorised Kawasaki dealer, any carb you get will be used and need further cleaning like yours.
Need deeper cleaning by disassembling them down to every last nut, bolt and individual component. Then scrub every part along with hidden passages using brushes and PEA-based fuel-system cleaner. Here's guide to secret passages: http://n4mwd.blogspot.com/2013/10/se...-passages.html
Also do search here for "clean carbs ducatiman" other threads with photos on what needs to be done.
Old May 27th, 2022, 03:32 AM   #3
Deezg
Deezg's Avatar
Ive taken them all the way down to the primary jets and idle circuit jets and poked a bread tie through all the holes. Soaked for 24hrs then blown out with compressed air lol. The spark is white/blue and definitely will make you jump if you accidentally ground your wrist to the frame. (Ask me how i know) 🤣 ive even filled a spray bottle with fresh 87 and squirted it in the plug holes before putting them back in and not even a sputter. I would assume with spark and fuel i should at least get some sort of backfire or something
Old May 27th, 2022, 05:14 AM   #4
ducatiman
ducatiman's Avatar
"I can see all the valves move when I turn it over by hand."
But....are the clearances truly correct? Have YOU actually checked them (using feeler gauges) for correct clearances? Tight valves can have disastrous consequences, including hard starting.
SO IMPORTANT, DON'T BLOW IT OFF!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 27th, 2022, 06:26 AM   #5
Deezg
Deezg's Avatar
Intake is set at .005 and exhaust .006 🤷*♂️ that was my first thought too. They were way too loose so i adjusted them to spec. No changes. Possible the loose valves tore up valve seats? Im stumped. When it comes to engine building im usually spot on doing diagnostics. Been building sbc engines for years. I would think kawi engines are the same principle but im stuck scratching my head 🤣
Old May 27th, 2022, 06:28 AM   #6
Deezg
Deezg's Avatar
Hey thanks for chiming in with advice 👍 definitely appreciated
2001 ninja250 response/fuel/spark? Dizzy 1986 - 2007 Ninja 250R Tech Talk 18 April 24th, 2022 08:00 AM
Bike won't start- spark issues? StuntPuppy 2008 - 2012 Ninja 250R Tech Talk 13 April 15th, 2017 09:47 AM
No Start - but have fuel, air, compression & spark Bowtie2Bimmer 1986 - 2007 Ninja 250R Tech Talk 26 March 7th, 2016 05:20 AM
No Spark!!! 2009 Ninja 250 EX250 Fuel Injected ghutcheson 2008 - 2012 Ninja 250R Tech Talk 8 April 22nd, 2015 01:44 PM
[motorcyclistonline] - Fuel, Air, Compression, Spark: The Four Horsemen Of Motorcycli Ninjette Newsbot Motorcycling News 0 May 17th, 2009 01:00 PM
