Old October 3rd, 2012, 07:56 PM   #1
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Oil Filter Wrench
So I just tried to do an oil change on my 1000 which uses cartridge spin on filters like the 300, only, the stock one doesn't have a way to come off. You need an oil filter wrench in order to get the stock one off. The 300 also uses these spin ons right? Anyone want to check if they also require filter wrenches?
AFM #676
Supersports are for n00bs
Old October 3rd, 2012, 08:08 PM   #2
lgk
If its like a car you can use a rubber strap wrench.
Old October 3rd, 2012, 08:09 PM   #3
Surferboy120
Finding some curves....
Motorcycle(s): 2013 300 Ninja
I never really have to use an oil filter wrench but I have one of those plastic socket ones you use your ratchet with for my RSX and Toyota and it happens to fit the Ninja to. Use a little more elbow. Its not good if its that tight.
Surferboy120 is offline   Reply With Quote
Old October 3rd, 2012, 08:10 PM   #4
Surferboy120
I have two sizes of strap wrenches boy they are handy things to have around.
Old October 3rd, 2012, 08:13 PM   #5
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
There's no reason to have to tighten an oil filter to that point. If you can't get it off and don't have any kind of wrench to get a hold on it just stab a screwdriver into it and loosen it that way. I had to do that on my dad's bike because whoever changed the oil last time really cranked down the filter. I couldn't even loosen it with the oil filter wrench I have.
k-os is offline   Reply With Quote
Old October 3rd, 2012, 08:22 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Maybe I'm not being clear, I don't have a tool that fits this, you want me to do it by hand????
From the ground looking up view
From the front tire view
Explain stabbing a screwdriver into, because to me that sounds like a terrible idea
AFM #676
Old October 3rd, 2012, 08:27 PM   #7
Jiggles
Jiggles's Avatar
MOTM - Apr '13
My new filter has this nifty pifty bolt
AFM #676
Old October 3rd, 2012, 08:28 PM   #8
Surferboy120
I know what you are talking about and yes that very filter I unscrew by hand on my RSX and Tacoma and I am sure I will do it on my Ninja as well.
I have done the screw driver through the filter idea in the past when all else fails but it is messy. The oil filter is super thin so thats easy to do.
If you cant unscrew it by hand go to walmart and buy a cheap oil filter wrench. A lot of the socket types are plastic because it shouldnt take much effort to get the filter off. Of course there are heavy duty ones as well.
Some are plastic
Old October 3rd, 2012, 08:32 PM   #9
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I attempted it by hand and it wouldn't budge. Looked on a ninja 1000 forum and people said it seemed like a 500lb gorilla had tightened the oil filter on there. I'm guessing for the first oil change, by hand is not going to happen. For later oil changes I'll have the filters with the nut for ease of use.
I'm going to guess that the ninja 300 has the same type of oil filter on it and if its torqued on at the same rate that the 1000s are then its not going to be possible to do by hand. So, for the noobs, get an oil filter wrench if you don't have one
AFM #676
Old October 3rd, 2012, 08:35 PM   #10
Surferboy120
Good luck with that little gorilla I hope all goes well.
Old October 4th, 2012, 04:33 AM   #11
lgk
look like you got plenty of room after you put the bike on stands.
Old October 4th, 2012, 04:34 AM   #12
lgk
one of the best things harbor freight makes, lol.
Old October 4th, 2012, 04:38 AM   #13
Jiggles, always buy a K&M filter for your track/track use bikes. Or at least check to make sure it has the nut at the end of the filter. It makes safety wiring much easier.
Old October 4th, 2012, 07:31 AM   #14
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That's what I got
AFM #676
Old October 4th, 2012, 11:04 AM   #15
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
That's one very nervous-looking chihuahua.
Old October 4th, 2012, 11:16 AM   #16
dino74
dino74's Avatar
Who needs a wrench? This is what my oil filter look like after I take them off...
CVMA #55
Old October 4th, 2012, 11:22 AM   #17
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Take screwdriver, stab filter, twist, remove screw driver and take off old filter. Install new filter finger tight then 1/4 turn.
Old October 4th, 2012, 11:25 AM   #18
Jiggles
Jiggles's Avatar
MOTM - Apr '13
You must not know what a nervous chihuahua looks like. Besides shes only have so she isn't ugly like those disgusting full breeds.
AFM #676
Old October 4th, 2012, 12:33 PM   #19
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
+1 the stock filters suck ass, just use a screw driver and punk it through the upper side of the filter and rotate it off. Then only buy K&N after that and problem solved
----> My Youtube! <----
Old October 4th, 2012, 01:07 PM   #20
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I love the destroyed filter resting on the oil filter wrench.
Old October 4th, 2012, 01:58 PM   #21
Jiggles
Jiggles's Avatar
MOTM - Apr '13
My oil changes are messy enough without destroying an oil filter. Besides I want to do the oil change without taking the fairings off and I don't think there is enough room for this particular "method"
Right tool for the wrong job or wrong tool for the right job?
AFM #676
Old October 8th, 2012, 09:29 PM   #22
Surferboy120
I just did my first oil change on the 300 and went with my handy plastic oil filter socket from walmart to take mine off the easy way. Like you said Jiggles the factory sure likes to put those filters on tight.
Old November 5th, 2012, 11:56 AM   #23
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Anyone know part # for KnN? @ cyclegear now
JBinSD is offline   Reply With Quote
Old November 6th, 2012, 07:20 PM   #24
DaveTheCanuck
Moo
DaveTheCanuck's Avatar
Motorcycle(s): 2013 Ninja 300
You need one of these ^
DaveTheCanuck is offline   Reply With Quote
Old November 7th, 2012, 12:24 AM   #25
KELPHYN
KELPHYN's Avatar
Try wearing a rubber glove, should let you grip a little better. Also if it it on that tight I would remove the fairing to remove it, just encase you/wrench slip. Don't want to risk breaking/cracking fairing. Have fun.
Old November 7th, 2012, 06:27 AM   #26
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
I did the first oil change on my 300 last week and the filter was indeed installed by king kong. I went to O'Reilly Auto Parts to buy a socket wrench. It just slipped on every ridge and wouldn't budge. I ended up having to remove the lower right fairing and use filter pliers to get it loosened. Unfortunately for me, I purchased three Kawi filters from the dealer when I bought the bike.
I'm assuming when the mileage is right, T6 is just as good for the 300 as my new-gen?
geeker is offline   Reply With Quote
Old December 13th, 2012, 04:20 PM   #27
GreenNinja
GreenNinja's Avatar
Name: I'm a ninja!
Motorcycle(s): 2009 Ninja 250
I know this is an old thread but try investing in one of these and see if it helps you out. I bought one when it was on sale for $5 and this is what I use for my car.
http://www.sears.com/shc/s/p_10153_12605_02820523000P
GreenNinja is offline   Reply With Quote
Old December 13th, 2012, 04:25 PM   #28
geeker
geeker's Avatar
I've seen those on the shelf before, but never gave them much attention. I bought a Fram filter socket cap from Wal-Mart a couple weeks ago and it's a 1000x better than the plastic crap I bought at the auto parts store. Worked like a charm and it was only $3.24.
Old June 2nd, 2013, 07:06 AM   #29
psych0hans
psych0hans's Avatar
Will THIS do?
Old June 2nd, 2013, 09:17 AM   #30
adouglas
adouglas's Avatar
I got the Harbor Freight version of that and it doesn't work worth crap. Slips.
I also picked up a filter wrench that looks like a giant pair of Vise Grips. Big jaws on locking pliers. It ROCKS and has yet to be defeated.
As often happens, on my GSXR the factory installed the oil filter tight enough that it defeated every wrench I had… fiber strap, metal strap and the useless three-fingered widget. Not this. It actually started to bend the can before the filter began to loosen. This tool handled it with aplomb. And it cost seven bucks.
Old June 2nd, 2013, 10:00 AM   #31
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
There's plenty of room, you only need to spin it a little bit to loosen it and then you can take it off by hand. Takes 3 seconds, don't bother going out to get a tool, it looks like you'd have a hard time getting a filter wrench in there.
Wipe up with a rag after, and if you're really anal get some brake/carb cleaner
Quit being lazy, you'd be done by now
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old June 2nd, 2013, 01:28 PM   #32
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I was done like 3 months ago
AFM #676
Old June 2nd, 2013, 02:57 PM   #33
Felipe the Ant
i blame the indian
Old June 2nd, 2013, 03:39 PM   #34
adouglas
adouglas's Avatar
Depends on how tight the filter is.
You can twist with your hand til the cows come home and that filter isn't going ANYWHERE if it's on too tight… which it almost always is from the factory.
Oil filter crosses over with Honda filter smokinsingle 2008 - 2012 Ninja 250R Tech Talk 4 April 19th, 2014 08:47 AM
Oil/Filter help? Eagle981 1986 - 2007 Ninja 250R Tech Talk 2 January 13th, 2013 07:23 PM
Loss of oil and Air filter soaked in Oil 08ninja250 2008 - 2012 Ninja 250R Tech Talk 19 August 9th, 2010 05:35 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
