May 17th, 2012, 04:44 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2012 Ninja 250 SE Posts: 42
Speed wobbles on Highway
So a couple of days ago I was cruising along the highway, Long story short I wanted to see what was going to happen if i "wiggled" the steering (Yeah I know) anyways of course a bit of a "speed wobble" occurred. Nothing bad followed and i simply corrected it but what worried me the most was how "easy" I managed to do it... And it made me wonder if i kept going would it turn uncontrollable and into a real tank slapper? And if that happened are you pretty much effed?
May 17th, 2012, 04:47 PM | #2 |
Which pedal is the gas?
Join Date: Mar 2012 Motorcycle(s): '09 Ninja 250R SE Posts: 192
May 17th, 2012, 04:49 PM | #3 |
about equivalent of asking "i wonder what happens when i crank the steering wheel" in a car
May 17th, 2012, 04:50 PM | #4 |
Join Date: Mar 2012 Motorcycle(s): 2010 Kawasaki Ninja 250r special edition Posts: 286
May 17th, 2012, 04:54 PM | #5 |
Man I hate dying. The stocko tyres are pretty slippery anyway, feels like I cant trust them for anything in a lean. Or maybe I just don't trust myself
May 17th, 2012, 04:58 PM | #6 |
Yep, Im a n00b
Join Date: Jan 2012 Motorcycle(s): Red 2010 Ninja 250 Posts: 12
I don't think you'd be completely effed, I've heated stories of some guys surviving some pretty crazy tank slappers. You can also look some pretty crazy ones up on YouTube. I'm no expert or anything but I believe they say you should NOT try to correct it if you find yourself in one. I think they say that if you try to hold the handle bars still it will only cause the bike to start to wiggle beneath you possible causing you to wipe out. I would just try my best to wait it out and the bike should correct itself. |
May 17th, 2012, 05:01 PM | #7 |
So I have heard "Having a loose grip" on the handlebars is the key
May 17th, 2012, 05:05 PM | #8 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Not sure about the speed wobbles, but riding in general definitely so. Especially, as I noticed, while riding on bad surfaces. Story: They are repaving the road on my way to work, and it is currently a horrendous grooved surface. Instead of fighting it, I just let the bike go where it goes (in my lane), swerving & what-not, and put my weight more towards the rear. |
May 17th, 2012, 05:31 PM | #9 |
So, where's the reverse?
May 18th, 2012, 12:41 PM | #10 |
Join Date: Nov 2010 Motorcycle(s): KTM 390 Duke Posts: 428
I had one, and then some others had it, too. Search, it's all here.
September 13th, 2012, 07:06 PM | #11 |
September 13th, 2012, 07:35 PM | #12 |
If your riding techniques are not causing this wobble; tight grip on the bars, loose arms, nothing else funky, then we can can look at your hardware.
Check the following; Tires in good shape? Tires at proper psi or your preference psi? Tires balanced? Rotor warped? Brakes dragging? Wheel straight? Fork stem nuts to torque specs? Also it's a 250, seams in the road or areas of pavement where they have used the stripper can cause a wobble among other things like bumps and such. KKim, a legend here had them, there is a huge thread on his where everything was explored. It would serve you well to search and find that thread. Also, if you have a full blown tank slapper, don't fight it. Do you best to roll off the throttle and let the bike settle down. Good luck finding your issue.
September 13th, 2012, 10:32 PM | #13 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
September 14th, 2012, 04:16 AM | #14 |
I have had one on the track, let's just say it's easier said than done.
September 14th, 2012, 10:17 PM | #15 |
hates stupid people
My thoughts exactly. I realize you were just testing it but not sure why the results surprised you.
My vlogging channel: Ma1iciousLogic |
What is the AVG speed you do on the Highway | reroka | General Motorcycling Discussion | 45 | June 11th, 2014 05:41 AM |
Speed Wobbles | parox91 | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 25th, 2013 08:35 AM |
Highway speed in relation to rpm.. | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 5th, 2013 04:10 PM |
Low speed drop on highway | nliu314 | !%@*#$%!)@#&!%@ I crashed! | 10 | June 25th, 2012 07:19 AM |
Highway cruising speed and RPMs | Archerzz | General Motorcycling Discussion | 27 | July 7th, 2011 06:29 AM |
