April 29th, 2013, 09:03 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): Ninja250r 2010 SE Posts: 5
Michelin Pilot Power mixed with Stock IRC front? BAD because Bias w/Radial?
Hello I am planning to switch my stock tires rear to the 150-60-17.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 I have the stock dunlops in the front. If I put the michelin in the back is it bad because the front stocks are Bias-ply and rear is radial? Please advise! Thanks! |
April 29th, 2013, 09:16 AM | #2 |
It's not bad as long as you don't out ride the traction of the front. The radial may inspire a sense of traction that the front can't comply with. Your only as strong as your weakest link.
April 29th, 2013, 09:20 AM | #3 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
I would recommend just putting 2 new tires on. Trust me its the better choice.
April 29th, 2013, 09:46 AM | #4 |
maybe ill just hold off then and return this new tire for now. thanks
April 30th, 2013, 07:21 AM | #5 |
Kel,
As Chris has explained above, nothing catastrophic will happen, unless you really push the limits of traction and stability (something to never be tried in public streets). I have never rode a bike with a mix of radial and bias belted, but I have read that some stability handling may occur. http://www.totalmotorcycle.com/photo...e-TyreTech.htm http://www.motorcycle-usa.com/379/74...uct-Guide.aspx "Don't Mix and Match Bias and Radial Tires Bias and radial tires have significantly different dynamic properties. Bias, bias belted and radial tires have different construction types and therefore have different abilities to carry side and peripheral forces as well as having varied damping characteristics. The introduction of radial tires required changes to certain characteristics of the motorcycle. The development of the radial tire led to frame modifications, new steering geometries and suspensions. That's why it is recommended that a motorcycle be used with the type of tire construction that it came with originally. Do not mix bias ply and radial tires on the same motorcycle unless it has the approval of the motorcycle or tire manufacturer."
May 1st, 2013, 04:34 AM | #6 |
Board Member
It is not recommended but it should not be catastrophic if you do. Listen to what csmith and motofool wrote.
May 6th, 2013, 07:50 PM | #7 |
The 2 Stroke Ninja!!
Join Date: Feb 2012 Motorcycle(s): 2010 250R, 1977 RD400, 72&73 RD350 75 RD200 Posts: 79
Be careful. I ran out of time this weekend before a trip and only got to mount the rear Pilot on my bike. you could definitely feel it. It felt a little squirmy.I even pushed (slid) the front tire a few times in some of the 180 degree switchbacks I was riding on (Tail of the Dragon). The front time is the original IRC and my bike is a 2010.
May 6th, 2013, 10:23 PM | #8 |
thanks for the advice guys. I stuck with a 130.
Pilot Street Radial from Michelin - Review | afelotreyu | 2008 - 2012 Ninja 250R Tech Talk | 22 | September 5th, 2016 05:18 PM |
Michelin Pilot Street Radial rear tire review | rojoracing53 | General Motorcycling Discussion | 182 | August 2nd, 2016 12:19 PM |
Cool video on Bias-Ply vs Radial Tires by Michelin | c-dog | Videos | 14 | August 8th, 2014 08:03 PM |
[sportrider - latest stories] - New Michelin Pilot Power 3 And Power Supersport Tires | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
[topix.net] - Michelin Pilot Road 3 Sport-Touring Radial Tires | Ninjette Newsbot | Motorcycling News | 0 | August 9th, 2011 01:51 AM |
