Old June 3rd, 2013, 04:29 PM   #1
nick5446
Motorcycle(s): Too many
Carb diaphragm install
Who's got the trick to installing these? I've done it on a handful of other bikes and it's always tricky, but never this bad. I've got it over the first lip (I think about 1/3 of the way).
It's been sitting in the sun to soften it up and it's also got some lube on it. No luck.
nick5446 is offline   Reply With Quote
Old June 4th, 2013, 06:40 AM   #2
What seems to be the problem? They should seat just fine in their hole and lie in the recessed lip around the top. Should be a no brainer if you take your time.
Old June 4th, 2013, 07:29 AM   #3
If your hands cannot make them slide smoothly, little changes of vacuum won't.
Check this how-to for pre-gens:
http://faq.ninja250.org/wiki/How_do_...n_correctly%3F
Old June 4th, 2013, 08:12 AM   #4
nick5446
Thanks. I agree with your sentiment about slight vacuum changes not being an issue if I can't get them in. They're overlapped past the first lip, but I can't get them any farther. I started trying to push it in with miscellaneous thin objects, but it didn't seem like a good idea.
Old June 4th, 2013, 09:49 AM   #5
cuong-nutz
cuong-nutz's Avatar
So you were able to remove the old diaphragm from the slide without it ripping?
Now you are trying to install the diaphragm back into the side?
This is what I had to do.
http://www.ninjette.org/forums/showthread.php?t=123535
I think I may have figured another way for you. In a tube of hot soapy water, try adjusting the diaphragm rotating and tugging on it and hopefully the lips to "pop" into the groves in the cap of the slide. Make sure you wash off all the soap too.
HalfFast Racing Team
Old June 4th, 2013, 02:50 PM   #6
nick5446
Yup, old one came off fine (had a tear on the OD) and now the new one is being difficult going back on. Like I said, I've got it about 1/3 of the way on. I'm going to try running it like that and see if there are any air leaks.
I saw that thread of yours while searching around and determined you were nuts!
The method you're suggesting now is essentially what I was doing, except it was warm WD-40.
Quick ? regarding carb diaphragm SDx 1986 - 2007 Ninja 250R Tech Talk 4 March 23rd, 2015 10:05 AM
carb diaphragm triumphtriple Items Wanted 1 May 1st, 2014 06:42 PM
Carb Diaphragm Accident! Trainsk8 2008 - 2012 Ninja 250R Tech Talk 2 May 19th, 2012 12:08 PM
Sounds (Testing) of Good & Bad CV Carb Diaphragm g21-30 2008 - 2012 Ninja 250R Tech Talk 4 September 28th, 2011 08:35 AM
Carb Diaphragm Melted NaughtyusMaximus 2008 - 2012 Ninja 250R Tech Talk 17 July 25th, 2009 11:45 AM
