Old April 8th, 2015, 07:06 AM   #1
Shinigami
Motorcycle(s): Ninja 250R
250@300 cc swap
Here is my (hard to call it) teaser of an engine swap. Sorry for quality. I did post some description.
https://www.youtube.com/watch?v=yLDMyqfRRAA
Shinigami is offline   Reply With Quote
Old April 8th, 2015, 07:41 AM   #2
nice. what all did you swap over?
Old April 8th, 2015, 07:41 AM   #3
cuong-nutz
cuong-nutz's Avatar
Good job. How much did the whole swap cost you? Were you already fuel injected?
HalfFast Racing Team
Old April 8th, 2015, 08:14 AM   #4
Shinigami
Around 750$ total according to today's currency. I'm from Poland so we did get FI ninja stock. The stock map in ecu needs some adjustments but even in current form it's usable.
@alex.s - Not much, Engine with sprocket cover, stick coils, header, starter and breather hose.
Old April 8th, 2015, 10:12 AM   #5
garth285
KAWASAKI GURU
garth285's Avatar
That 250 ECU actually has a bit more aggressive timing curve AND 250 more RPM, all you would need to do is adjust the fuel which you can do with a power commander if needed.
Looks good!
Old April 8th, 2015, 10:24 AM   #6
Shinigami
Yeah, i did my homework on swap so I am aware of diffrent ignition timing. I will throw some piggyback in there coz it's 1- reversible 2- easier to retune multiple times.
Old April 8th, 2015, 10:25 AM   #7
garth285
KAWASAKI GURU
garth285's Avatar
Yeah I'd keep that good timing unless you have bad fuel where you live.
Tune it up and rip it up!
Old April 8th, 2015, 10:29 AM   #8
has anyone done a carbed 300? thinking about it, it should be okay to just swap the motor and keep the 250 carbs and ignition and everything else... right? obviously some tuning required... how far different is the timing for the 300?
Old April 8th, 2015, 10:43 AM   #9
Shinigami
Well if You have already carbed bike then You can swap engines, ditch sprocket speed sensor, o2 sensor (or slap in standalone wideband). But 300 has bigger intake diameter than 250, it's not a problem in my case, but You will probably feel that carbs are to small or not responsive enaugh.
EDIT: I don't anything about US separate ignition coils so I am thinking about stickcoil conversion which most likely has other conections.
The difference in ignition timing for FI models goes like this:
250: From 10° BTDC @1 300 r/min (rpm)
38° BTDC @6 000 r/min (rpm)
300: From 10° BTDC @1 300 r/min (rpm)
31° BTDC @7 000 r/min (rpm)
EDIT, the 250 carb spec:From 10° BTDC @1 300 r/min (rpm)
35° BTDC @4 000 r/min (rpm)
Old April 8th, 2015, 03:36 PM   #10
cuong-nutz
cuong-nutz's Avatar
There's a guy or two on here that did the swap. maybe in the pregen area, if you may recall. Last closest thing was Bruce in his frankenstein swap.
Old April 8th, 2015, 09:39 PM   #11
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Originally Posted by garth285 View Post
... AND 250 more RPM...
Shawn, please keep in mind that the 300 engine is more long-stroke than the 250, what means it doesn't like that high revs like the 250 does.
Old April 9th, 2015, 03:24 AM   #12
Somchai
Freedom for Germany
brilliant idea Alex,
get the cams from Beet and the carbs from the link http://www.yoshimura-rd.com/prodcat/...dual-stack.asp - if possible as 35 or 36...
Bring the ignition timing above 42 degree and then ---> HHMMMMMM
Old April 9th, 2015, 05:50 AM   #13
Shinigami
I am looking fro that pregen swap. Has anyone got a link ? BTW, reading this awesome material https://www.ninjette.org/forums/showthread.php?t=153624 gives me some fine ideas. I was thinking about 250cc 12,500 rpm supermoto since i got one spare. Last time I checked 500 ninja has the same mounting points and KLE500 was an enduro copy ^^ it's overweight though...
Old April 9th, 2015, 05:55 AM   #14
garth285
KAWASAKI GURU
garth285's Avatar
Very true but most bikes can handle a little more RPM's anyways, hell they rev the 1000's 1,000rpm over stock most of the time now!
With the weak valve springs the 250/300's have though I'd be cautious as well!
Old April 9th, 2015, 06:09 AM   #15
Shinigami
Both redline at 12'500 so it's not big of a deal since I never overrev
Old April 9th, 2015, 10:51 AM   #16
Shinigami
So I went to the garage with right fairing and this is what i found out.
1. It does interfere with header on the middle (the point were both fairing meet)
2. The bigger clutch cover fits on milimeters
3. Oil filler cap sits nicely but the oil change is a bit tougher now.
Old April 15th, 2015, 12:22 PM   #17
bruce71198
bruce71198's Avatar
The stock carbs bolt right on the 300 head. You'll probably find yourself right around 112 dyno Jet main.
Old April 15th, 2015, 02:00 PM   #18
EMSRacer07
EMSRacer07's Avatar
One was mine. I swapped the efi system and the stock 300 ecu. Pretty much a full swap. Still running strong on a 90' pregen.
The other guy never posted results but he was doing the carb swap and the electrical system so the ignition points would work from the older pregen motor
Old April 27th, 2015, 12:40 PM   #19
Shinigami
I already did 1200km+ and so far my headers bent back to the state were I bought them of ebay equivalent and the damn trany has humors.
Sometimes the sloppyest shift goes bang on, no problem while the most carefull end up in miss shift and drop back to lower gear. Sometimes 4k rev shifting with passenger goes smooth, other times WOT clutchless shifts are ok. Plus it tends to do what 250cc did after about 50'000km. Downshifting from 4th to 3rd feels like gear engages than disengages for split second and then it's ok. Mainly I got problems from 1st>2nd 2rd>4th and rarely rest of combinations. On downshifts it's most of the time good. Clutch, no clutch, slow, fast, clunck, seamless. I think this gearbox deserves a photo in dictionary under "Intermittent".
I have few theorys
1 Smaller inlet diameter causes poor throttle response
2 250 fuel map for subthrottle is bad for 300cc
3 Something got loose in shifting mechanism
Old May 27th, 2015, 12:00 PM   #20
Shinigami
So, the fairings do fit over 300 engine with some file and saw massaging.
I will take some better shots on the weekend
By now I ahve done 70'000km/43'750mil with:
around 4'400km with new engine
around 2'000km with fairings on. They do buzz from time to time but it might be because the right one does touch clutch cover.
https://www.bikepics.com/pics/2015/0...43089-full.jpg
Old May 27th, 2015, 12:16 PM   #21
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Nice man! Isn't it possible to swap in a 500 motor into a 250? I thought I read that somewhere.
Be careful. Remember you are
invisible
Old May 27th, 2015, 12:23 PM   #22
Shinigami
There are 2 or 3 topics 'bout that and one or two YT videos but it's not a plug and play type of fun.
Ninja 300 big brake kit $/swap old3 Motorcycle-related 16 September 10th, 2015 06:25 AM
Would 300 headers be a good swap? beniblanco 2008 - 2012 Ninja 250R Tech Talk 16 March 15th, 2015 06:38 AM
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
Indonesian NINJA 250r (Aprilia RS 250 legs swap) munandar Pictures 73 November 23rd, 2011 01:52 PM
