Old March 2nd, 2016, 08:08 AM   #1
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
What to expect going from race 250 to stock 300 on track?
My 250 is basically a pile of rubble, so I'm taking out the 300 (bone stock) for this weekends trackday. I know to take it easy cause the suspension and brakes won't be as good, but will I be able to pull as fast times around the track?
Also are rearsets for the 250/300 the same? I might stick those on the 300 for a little ground clearance.
Floki is offline   Reply With Quote
Old March 2nd, 2016, 09:10 AM   #2
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
would it be too much work for you to test the rear sets yourself?
How different are the bikes suspension wise?
TEAM ALFALFA
www.apexassassins.com
Old March 2nd, 2016, 09:15 AM   #3
Floki
Motorcycle Nurse?
Floki's Avatar
The bolts are bent as well as the frame tabs so it'll be tricky getting them on after. Have a gsxr shock, springs and emulators, lowered front and raised rear
Old March 2nd, 2016, 09:23 AM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
10 more HP right out of the gate, stock to stock. Should be able to go just as fast or faster.
Goin' fast on slow bikes!
Old March 2nd, 2016, 09:26 AM   #5
Biggest differences will be you, ergos and the tires. The lil bit of extra power shouldn't be something you can't handle right from the start.
Old March 14th, 2016, 06:55 AM   #6
Captain Caveman
Motorcycle(s): ZX6R, NINJA300R
The aftermarket rearsets are interchangeable. The clip ons are as well.
I found the front suspension far springier than the 250's, just replaced the OEM springs with Race Tech internals, what a difference
I put a TYGA - Performance full Maggot system on with a Dynotune fuel controller, now chasing a map for this setup, using the yoshi one for now.
Captain Caveman is offline   Reply With Quote
pre gen 250 stock at the track rubber side down Ninjettes At Speed 7 September 26th, 2014 03:26 PM
race/track 300 stock shock thoughts JasonG134 Ninjettes At Speed 9 April 11th, 2014 09:33 AM
300 stock pipe vs 250 Phoenix767 2013 - 2017 Ninja 300 General Discussion 7 October 31st, 2012 11:27 AM
Dyno Results: Stock 300 vs. Stock 250 vs. Race 250 gt_turbo 2013 - 2017 Ninja 300 General Discussion 26 October 8th, 2012 10:03 PM
What to expect on track days Blackwidow Ninjettes At Speed 34 September 2nd, 2010 04:41 PM
