June 12th, 2017, 04:05 PM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
Larger pilot jet
I have a stock 08 ninja 250s
Was wondering what would happen if i went size larger on the pilot jets only..rather than go larger on main jet. Everything stock on my bike |
June 12th, 2017, 04:18 PM | #2 |
What's your goal? Pilot jets are active only down around idle, and your mixture screws should have enough range to get your idle mixture correct without changing the jets.
June 12th, 2017, 04:22 PM | #3 |
The factory main jet is actually too rich. With my Tyga exhaust, the DynoJet kit actually has a smaller-than-stock main jet for a 2-3hp gain. Remember that '60s hot-rodder slogan?
June 12th, 2017, 05:38 PM | #4 | |
Comparing actual specs (internal measurements) would give you a comparison, but that's the only way to know how much richer or leaner it is. That's why I prefer Factory Pro jet kits over Dynojet. |
June 12th, 2017, 05:42 PM | #5 | |
https://faq.ninja250.org/wiki/How_a_...arbs_explained |
June 13th, 2017, 12:52 PM | #6 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
I have a Keihin 95 main jet in mine with an AreaP full exhaust. Stock is 98, so stock is too rich on some specimens at least.
bike * miles = smiles smiles / bike = miles smiles / miles = bike |
June 13th, 2017, 03:40 PM | #7 | |
Only way to know actual AFR and when to go richer or leaner is with dyno or wideband-O2. So far from our empirical data, going to leaner mixture at WOT gives more power with factory and aftermarket exhaust. |
June 15th, 2017, 02:56 PM | #8 | |
https://www.ninjette.org/forums/showthread.php?t=50337 https://www.ninjette.org/forums/showthread.php?t=55927 |
June 15th, 2017, 03:15 PM | #9 |
I would perform a correctly done plug chop before going to leaner main jets.
Pilot jet | Ram Jet | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 6th, 2017 02:05 PM |
Pilot Jet Question | JonnyBlaze | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 11th, 2016 07:11 PM |
#40 Pilot Jet | mrscbw | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 11th, 2011 11:33 AM |
Re-questioning #40 Pilot Jet... | GiGs | 2008 - 2012 Ninja 250R Tech Talk | 38 | December 24th, 2010 08:30 AM |
pilot jet | drstimpy | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 26th, 2010 08:03 AM |
