Closed Thread
Old September 25th, 2011, 01:32 PM   #121
btw kc you should put a second front disc and rotor on your 250 like that guy in indonesia
alex.s is offline
Old September 25th, 2011, 02:51 PM   #122
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
KC, what is this rubber mount point for? the one right below your o2 sensor. is it the exhaust cover mount?
I'll guess for the fairing.
k-os is offline
Old September 25th, 2011, 10:34 PM   #123
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
It's just a fairing bumper. Nothing screws in there.
Haven't figured out what rim to use for a second disk.
Can't do it to my stock one.
I do have the reversed HH pads though, for what it's worth . lol
Now I just need the caliper and rim.
Then I'll just snap the forks off or finish bending the frame anyways.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline
Old September 29th, 2011, 11:39 PM   #124
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Did my first GSXR DIY for the GSXR forum.
Here's a copy since you guys would have to log in to see it yourselves I think?
It's how to fix the headset play.
A very common problem on a lot of bikes I ride that aren't mine!
I always have my headset in check.
Yeah I guess I didn't take as many pics as I thought.
I was able to complete the adjustment while eating some soft tacos for dinner.
First I popped the stem nut off with a breaker bar and noted it took 1/4 turn to loosen to finger turn-able.
Then I removed the front res.
Then I used a ratcheted allen to loosen the upper triple clamp bolts and the bolts to the clip-ons. You only see the ratchet on one of the bolts here while my tacos are slowly dissipating.
Here you can see the clip-ons have been loosened. I also took the airbox cover off after a step below..
You can pull these off and throw them away. We won't be needing them anymore.
They tried to turn the 2011 into a sports car but it failed miserably. (aka lift the hood)
Now once you have the ECU out..
and you're on the last Taco..
You grab that magic spanner wrench from the Ninja 250R to save the day so you don't ruin things and you tighten the lower bolt, only hand tight. A little bit at a time. You have to keep testing things and feeling it out.
A good bike mechanic can do it right by hand but it might take him two or three tries. (But he should know what RIGHT feels like when done)
then you tighten the bolt directly above it to lock the lower bolt in place.
Once you think you got the feel right, tighten the upper stem nut..
Screw it down finger tight, then tighten it 1/4 more turn with a breaker. No more.
Then you need to re-tighten the upper triple clamp bolts and the clip-on bolts while holding the clip-ons in place.
After which, you can bolt your front brake res back on, then polish up the bike and lube the chain.
Redo as necessary.
If it's too tight, it will feel funky to steer the bike. you'll know right away.
Get off and fix it immediately, do not ride with it too tight.
If it's too loose, you'll still get the noise and steering will be too easy.
It's a tricky adjustment to acquire the feel for.
Takes about an hour if you are good at mechanic work and eat a lot of food.
LMFAO!
Weaksauce
ninja250 is offline
Old September 29th, 2011, 11:58 PM   #125
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Haha I like the all important inclusion of food. This man knows how to do good work!
Trailerboy531 is offline
Old September 30th, 2011, 09:14 PM   #126
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Just finished a DIY Fender Eliminator tutorial for the L1 GSXR.
http://www.gixxer.com/forums/showthr...=1#post5347997
Wouldn't ya know it they already hate me over on that website too. lol
Too bad you're all stuck with me. =P
LMFAO!
Weaksauce
ninja250 is offline
Old October 4th, 2011, 01:17 PM   #127
Uhh... that doesn't look like my 250's spanner wrench at all. Mine is perfectly flat with no raised edge, no hole in the end, and it is made to slot into a short pipe with different-sized opening on either flattened side, which then acts as a sort of handle. One side of the pipe fits the spanner wrench, one side fits the included axle-nut wrench, and all three can be connected in one long tool for better leverage on the rear axle.
TheDuck made his own Castle/Crown nut/socket for the GSXR triple tree in his SV650:
Used a $4 Harbor Freight deep socket.
Last futzed with by CZroe; October 4th, 2011 at 02:26 PM.
CZroe is offline
Old October 5th, 2011, 02:02 PM   #128
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
That wrench definitely came in my 250R kit!
Don't know where else I Would have got it!
LMFAO!
Weaksauce
ninja250 is offline
Old October 8th, 2011, 09:46 AM   #129
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Really good extensive thread on suspension adjustment.
This is for you too, Honey Badger.
Careful playing with all those settings! Maybe this will help you.
http://www.gixxer.com/forums/showthread.php?t=60836
Make sure you heed all these warnings. Suspension adjustment can get scary quick if you do it wrong. Tank slappers and traction loss coming out of corners and such.
I'm going to need help setting/measuring my three sags f & r
I think I can tweek the rest at the track or in the garage and mark the settings for each.
Also oil height may need to be adjusted.
I think my stock springs are ok for my weight.
They say when you have the suspension tuned by a shop it's like night and day difference.
There is also a video you can buy, and the text linked above was taken from the video or the guy who made it or something. Really good stuff. Even talks about having too loose steering stem etc.
I think my GSXR is a bit stiff rebound? in the rear for the freeway and I even think the preload could be backed off some too. I don't know how to do the other two adjustments on the rear.
My user's manual is trying to help me. lol
I've had this bike a few weeks and 1200 miles and it's still not adjusted 100% yet and I do a bit of work on it at least every other day. I'm trying to figure out if there is an end to the adjustments and maintenance on this bike but I can quickly see there is not!
IMO, half the fun. =)
By the time I got the oil changed it was time for 600mi service, now suspension setup and then finish the 600 mi service with throttle body synch and then back to suspension and safety wiring and another oil change..
There is always something to improve on the setup without even adding modifications.
I thought about putting new grips on it but the stock ones are grippy and good! No reason to replace anything!
I wanted to cut the levers shorter for my own reasons but that would be murder on the nice stock GSXR levers. No way will I go cheap ebay levers on this one. In that case, no reason to upgrade/modify those either!
LMFAO!
Weaksauce
ninja250 is offline
Old October 12th, 2011, 09:27 AM   #130
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Please dont do this
----> My Youtube! <----
Kevin2109 is offline
Old October 12th, 2011, 09:31 AM   #131
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by Kevin2109 View Post
Please dont do this
After seeing that picture I thought: Why the hell do people ride without full protective gear?
akima is offline
Old October 12th, 2011, 10:14 AM   #132
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
Please dont do this
highside :P?
VROOOM vrooom >.>
rusninja is offline
Old October 12th, 2011, 10:18 AM   #133
i bet the driver of that car needed a new pair of underwear
csmith12 is offline
Old October 12th, 2011, 10:20 AM   #134
Kevin2109
KThanksBye
Kevin2109's Avatar
Im still trying to figure out how the guy did that, thee is minimal damage to the front of the car
Old October 12th, 2011, 11:21 AM   #135
rusninja
Ninjette wanabe :D
rusninja's Avatar
possibly hit another car then flipped onto the vw. :S
VROOOM vrooom >.>
rusninja is offline
Old October 12th, 2011, 11:34 AM   #136
Most likely, considering that the front end is MIA.
CZroe is offline
Old October 13th, 2011, 06:22 PM   #137
Gurk
Done here.
Motorcycle(s): -
I was telling Kevin yesterday, I passed by that wreck! Brutal scene
Gurk is offline
Old October 14th, 2011, 12:50 PM   #138
Lil_Green_Demon
Winging It In Life
Lil_Green_Demon's Avatar
Motorcycle(s): 2010 250R; 2011 250R (sold)
Damn! For a second there, I thought that was KC!
It's not KC, right?
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015)
2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current)
Lil_Green_Demon is offline
Old October 14th, 2011, 01:29 PM   #139
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Some track days have a suspension guy there who will do a sag set, check your tire wear, and then fine tune after a session on the track for a reasonable price. Mine has been set by the eyeball and feel method, but hoping to get sag done by someone prior to monday track day. I do know how to do it but no one else lending a caring hand!!
backinthesaddleagain is offline
Old October 14th, 2011, 02:10 PM   #140
Gurk
Done here.
Motorcycle(s): -
It's not KC, right?
No haha. I think that crash happened before he bought his.
Gurk is offline
Old October 14th, 2011, 08:02 PM   #141
Heed
Heed's Avatar
Motorcycle(s): None yet, yet.
damn, that was a nice volkswagen too.
Heed is offline
Old January 11th, 2012, 12:22 PM   #142
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
You guys WISH you'd find me plastered to somebodies car.
Never going to happen. I don't mess around with cars or near them.
You'll more likely find me balled up in a guard rail or over the berm 200 feet down a canyon.
Happy new years from GMR ladies!
LMFAO!
Weaksauce
ninja250 is offline
Old January 11th, 2012, 12:34 PM   #143
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
Hey Casey! Glad to see you are still kicking it around and rocking the gixxer! Haven't heard from you in a while. Hope you had a good christmas and new year.
Havok is offline
Old January 11th, 2012, 11:13 PM   #144
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Doing better than ever my friend. Miss ya.
Cleared up a lot of crap I had going on.
It's going to be a great year.
Might have the 750 paid off any day now.
My partner in crime was out there too. Had a great time. I'm a little rusty though.
He wooped my butt like usual.
PS who need some valve jobs lol
LMFAO!
Weaksauce
ninja250 is offline
Old January 11th, 2012, 11:14 PM   #145
Kevin2109
KThanksBye
Kevin2109's Avatar
KC!!! Whats up, its been so long, glad your bike isnt in the front of a car
Old January 12th, 2012, 11:31 PM   #146
Trailerboy531
HOLY CRAP YOU'RE ALIVE!
We've been missing you man, maybe you can make tech day this weekend or make an appearance?
Also, I'll be needing a valve job soon
Old January 13th, 2012, 04:19 AM   #147
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Tech day?! What's a tech?! I don't see any techs around here.
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 04:20 AM   #148
Trailerboy531
Yeah they kind of disappeared for a while there...
We'd love to have you man!
Old January 13th, 2012, 04:24 AM   #149
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Sorry have to go fail the DMV physical a few times first otherwise I'm not allowed on freeways at night time or clowns will eat me.
(I currently have only half an M class license)
That may change later today though. lol
Trying to learn how to get this beast through the lilipop.
Anyone try that?
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 10:20 AM   #150
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I want to learn to get this course down on the GSXR.
It's not half as easy as it looks for some reason on my bike.
http://www.youtube.com/watch?v=z2ANQmF-huA
My bike will hardly turn the radius of the circle at my DMV.. you have to really know your stuff.
Half the people I know would not be able to do this for sure on my bike.
I don't want to have to resort to paying the MSF $250 because I can't complete the DMV circle.. so I need some more practice. Again it's extremely tricky on my 750 at my local DMV circle.
I have thought about re-registering my Ninjette just to get my license, but what fun would that be?
I want to learn to get the gsxr through the course.. and it's not easy.
When I try it, it looks a lot more like this..
http://www.youtube.com/watch?v=1PkQ5tM4I1g
Only I get a circle and a half in before I touch down instead of just a half circle.
Because I actually understand I have to counter lean.
See you guys at the DMV lolipop. Trying to fit a brick through the eye of a sewing needle.
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 01:56 PM   #151
Trailerboy531
I've heard the DMV test is massively difficult, in-part because of what you're referring to. Good luck to ya man but it might be wise to register the ninjette or go with the far-easier MSF BRC. Hope you can join us soon.
Old January 13th, 2012, 07:04 PM   #152
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Well I passed the lolipop test a few times today. Unfortunately the DMV guy was nowhere in sight. lol
I did get it on video.
It is very possible on my bike, just I don't think I could nail it every single time... enough to pass in front of a sheriff on command. Not on the 750. On the 250, yeah, easy.
I'm going to spend a few more days practicing it. Then I'll give it a whirl.
If I fail, then I'll take the MSF class.
I just want a week of practice at this first. I know I can do it.. I proved it yesterday, just need to get better at it. It's not easy at all on the 750..
There's like 10 things you have to do perfectly right to make it all happen exactly like it should and if forget or mess one thing up it won't work at all.
Fuggin' haaaaard. I had to buy the hardest bike to get through the DMV test didn't I?
Yesterday I found a bit better of a tip was to actually lean into the circle instead of counterbalance lean it.
Feels crappy though because you are going so slow. You could wash any second.
I think it can honestly be done either way. Lean into it or lean out of it. As long as you keep the bike up, in the lines and no feet down.
I had it yesterday. Maybe I'll put the video but it doesn't show my actual wheels so it's not proving much. It will take a bunch more practice to be able to do it every single time on command for the test. Even then a gust of wind could mess the whole thing up.
I'm a fairly skilled rider and this has proven to be really hard to do. Learning this has seen an improvement in my other riding though. It's a valuable lesson. When I get the brick through the needle eye in front of the sheriff, I shall be quite confident.
I heard somewhere you can go rent scooters and pass the test but I really want to do this in front of a sheriff on my bike to prove I know how to control my bike beyond the shadow of a doubt at low speed.
I heard sheriffs fail streetbikers just for being streetbikers. That's not gonna help any!
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 07:49 PM   #153
Trailerboy531
Well if he fails you then you can take his badge and tell him to catch you if he can
How's the 750 treating you by the way? I'm looking in to upping to a gixxer and I rode a 750 - absolutely loved it. Do you know of any major differences I should know about from the 08-09 models to your model? I know there's the brembo brakes and the showa forks and one less mode.
Old January 13th, 2012, 08:16 PM   #154
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
There was a lot changed. Over half of the bike.
The frame and swingarm had much more weight pulled.
They keep getting lighter and lighter.
Even the rims were lightened more. They are totally hollowed out. There's barely any rim
there holding the bike off the ground. All the bolts are hollowed out and machined for less weight.
This bike doesn't weight much. It's just wide and bulky and odd shaped compared to a ninja.
The power is pretty much unreal as anyone would expect. Engine and drive train are the smoothest I have felt on any motorcycle yet, but I've never owned something like a BMW shaft drive or a belt drive harley.
This thing is the well oiled machine I've always wanted for sure. Smooth as a babies behind. Fits my height perfectly, not too small, not too big, perfect. Like a glove. I actually need to raise the forks and rear suspension if I were to bring it to the track.
I have a funky little noise in the headset that others seemingly have on the forums too that I Can't get rid of, but I'm gonna call down to Suzuki Monday because I Should be under warranty if it is actually a problematic noise.
Everyone tells me it's not but I don't believe it..
Other than that..
Here I am on video completing the DMV test.
First time through, I put my foot down. You can tell I was going slow and inconsistent that time. Second time through you can see I went through much faster, you can't tell but I did not put my foot down, and I cleared the test as you are supposed to by the books. You even hear me apply a bit of throttle on the way out of the course because I got happy and excited I did it.
Third run through I attempted to do the last portion of the test and would have failed it immediately.
It's pretty much a given that you are going to fail this test on your 600 or larger unless you have tons of practice at doing it.
What's worse, is my DMV test is on a hill making the bike roll fast down one side of the circle and slow up the other side giving you two easy times to fall off the bike. You are absolutely working every muscle in your body, every control on your bike and every skill in your head to make it work.
Head turned, correct lean, tough balance, tough angles to handle the controls... just funky all around on this machine. This test is designed to make you fall.
http://www.youtube.com/watch?v=EMbrMVoCnP4
why is it I keep forgetting how to embed videos here?
Video care of iphone4/RAM
everyone who says they want a parking lot day with cones.. it's sitting there 24/7 at the DMV and they don't care if you go try it all you want.
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 08:42 PM   #155
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
More GSXR porn.
Look how huge the bike looks compared to the circle.. besides the fact that it's sitting in front of it.
They basically leave you with zero room for error.
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 09:21 PM   #156
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Doesn't matter what year they are. They're all good
That's why they don't go for cheap unless they are beat the hell up.
Hell, the older heavier ones are more comfortable. Just try for fuel injection at least.
The best looking ones were the old SRAD like the 99. This one ^ was a 2003.
You can just tell I was nice and comfy on that thing.
LMFAO!
Weaksauce
ninja250 is offline
Old January 13th, 2012, 10:47 PM   #157
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
[ youtube] [ /youtube]
nickjpass is offline
Old January 14th, 2012, 10:16 AM   #158
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
ooooooooooooooooooooooh yeahhhhhhhhhhhh
That's right. Thank ya sir.
Bit rusty.
Nice cookie.
LMFAO!
Weaksauce
ninja250 is offline
Old January 14th, 2012, 11:16 AM   #159
sixer
no joy
sixer's Avatar
Motorcycle(s): Ninja 2006 636
Just borrow a ninjette and pass the first time out...
can't borrow mine tho its sitting in the drive way with a dropped rod or something..Blah... gonna take it to a dealer someday...
sixer is offline
Old January 14th, 2012, 12:16 PM   #160
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Dropped rod?!
What happened?!
Anyone wanna meet at the DMV course for practice lol
Hey I still have my 250 in my garage want to turn them both into one?! haha
LMFAO!
Weaksauce
ninja250 is offline
Closed Thread
Ring-snap,47mm cuz Items Wanted 1 May 13th, 2013 03:35 PM
[superbikeplanet.com] - Snap Out Of It...And Slap A Sticker On It Ninjette Newsbot Motorcycling News 0 October 15th, 2012 11:30 AM
OH SNAP! Terabyte thumb drives? massacremasses Off-Topic 5 January 9th, 2012 03:43 PM
[topix.net] - Snap up a cheap Harley-Davidson this weekend Ninjette Newsbot Motorcycling News 0 August 31st, 2011 03:20 PM
Oh snap! Yo momma thread! Ninjabunny Off-Topic 30 June 30th, 2009 02:36 PM
