April 16th, 2012, 01:32 PM | #1 |
Drdriftking007
Join Date: Apr 2012 Motorcycle(s): 2007 Ninja 250 Posts: 67
How to use Seafoam?
I was just wondering about this product and how to properly use it for our specific bikes.
I am new to all of this and all the help would be appreciated as always! |
April 16th, 2012, 01:39 PM | #2 |
Ms. Personality
How do you intend on using it? Remove carbon? Clean carbs? Clean crankcase? Each reason will involve a different way of applying the Seafoam.
Posted via Mobile Device |
April 16th, 2012, 01:39 PM | #3 |
Garage Monkey
Join Date: Apr 2011 Motorcycle(s): 03 Ninjette Posts: 166
You wouldn't eally have a use for it given your application...
it generally works by letting it soak into the carbon/hydrocarbon deposits in the intakemanifld on a vehicle with fuel injection and modern emissions equipment that floods the intake tract with carbon buildup. I do not endorse using it in your gas or oil, and it's meant for fuel injected applications, which you aren't. Ignore the vatozone cashier and put the seafoam bottle back down, it isn't for you |
April 16th, 2012, 01:39 PM | #4 |
It's as simple as following directions on the side of the can. Mix properly, on this product, more does not equal better.
April 16th, 2012, 01:41 PM | #5 | |||
Drdriftking007
Is that accurate? |
April 16th, 2012, 01:43 PM | #6 |
Some have had success yes.... Others have not. Like most of these type of products they cannot replace a good carb cleaning by hand. When mixed properly it "should" cause no harm and "might" fix your issue. But its no magic elixir like some make it out to be. Worst case is your 6-7 dollars short in your wallet and a bit of riding time.
April 16th, 2012, 01:45 PM | #7 |
Ms. Personality
That could be anything from tight valves to bad idle setting. Is it only when it is cold? It runs fine throughout the rest of the rpms? Miles on bike? Any mods, maintenance, etc...?
April 16th, 2012, 01:50 PM | #8 | |
Drdriftking007
It idels fine about 1300 and then randomly at a stop it shuts off. No mods, only 4710 miles on the bike. just changed oil on it. |
April 16th, 2012, 01:53 PM | #9 | |
However, if your starting issues (needing throttle to start) are caused by using full choke (which is what I'm assuming, correct me if I'm wrong), your problems will be solved by using a little less choke. We covered that in your other thread. Seafoam is good stuff though. It certainly won't hurt a thing to run some through with a tank of gas to clean the carbs a bit. |
April 16th, 2012, 01:56 PM | #10 | |
Drdriftking007
you seem to always save the day haha! Once I get home ill start the bike how you suggested. |
April 16th, 2012, 01:57 PM | #11 |
April 16th, 2012, 02:06 PM | #12 |
Drdriftking007
April 16th, 2012, 02:15 PM | #13 |
Gas tank is 4.8 gallons. And I think you add 1oz per gallon of gas. So if the tank is pretty much full I would just add 4oz.
April 16th, 2012, 02:55 PM | #14 |
Garage Monkey
Gas already comes with detergents in it... and probably isn't your problem at all. Seafoam will likely have no effect on this whatsoever, and I generally regard putting it in the gas/oil a waste at best, detrimental at worst (in the oil).
April 16th, 2012, 07:55 PM | #15 |
Drdriftking007
Hey,
So I got home and I started the bike like you suggested. Let the bike warm up for about 10 min and i started to take it for a spin to town. So everything was great for about 30 minute ride and all of the sudden my bike just slows down going 50mph and just dies. I tried starting it up and nothing it would turn on. I started pushing my bike and it turned on but would do the same thing. What's going on? |
April 16th, 2012, 08:02 PM | #16 |
Garage Monkey
Is your battery on its last legs?
April 16th, 2012, 08:05 PM | #17 |
Did you run out of gas?
April 16th, 2012, 08:05 PM | #18 |
Drdriftking007
April 16th, 2012, 08:06 PM | #19 |
Drdriftking007
April 16th, 2012, 08:09 PM | #20 |
Sounds like you and TheFranchise216 bought fraternal twins that are having similar problems! Sheesh.
Next time it happens, try opening the gas cap and leaving it open. See if the bike will start/run better with the cap open. |
April 16th, 2012, 08:18 PM | #21 |
Drdriftking007
Let me try that...will that damage the bike? I'll do that now
April 16th, 2012, 08:20 PM | #22 |
nope won't hurt a thing. Just wondering if there is a vacuum in the tank. Opening the gas cap gets rid of it if there is.
April 17th, 2012, 12:36 PM | #23 |
Drdriftking007
Seafoam is worth trying | chadh92 | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 4th, 2013 06:53 AM |
Seafoam help please | Jay72 | 2008 - 2012 Ninja 250R Tech Talk | 15 | August 3rd, 2012 09:37 PM |
seafoam.. | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 16 | June 18th, 2012 07:28 PM |
seafoam? | ReDnEcK | 1986 - 2007 Ninja 250R Tech Talk | 3 | September 1st, 2010 09:00 AM |
Seafoam is magical. | P1NDLESK1N | General Motorcycling Discussion | 41 | July 8th, 2009 11:29 AM |
