June 13th, 2013, 08:07 AM | #1 |
Join Date: Aug 2012 Motorcycle(s): 2014 Aprilia Dorsoduro 750, 2012 Ducati Monster 696 (sold), 2012 Ninja 250 (sold) Posts: 168
Describe a smooth shift
Ok guys, interested to hear your opinion. What do you consider a smooth shift? I am not talking about the technique in itself as I believe I got a fairly good grip on that, but rather just like to get a feel what you guys consider smooth.
As background, I have been back on two wheels for about 10 months now (after about 20 years away) and have put 3500 miles on the Ninjette and 3000 miles on the Ducati Monster 696, so I definitely still consider myself a newb. That said, while certainly not perfect, I would consider my shifting much improved (most of the time at least ) compared to when I started back out. No signfincant jerking or launching forward. What I do notice however, and especially when I can watch my headlight reflecting in a car ahead of me, is that the front does dip a bit when I shift. Not a whole lot, but noticeable. So my question to more experienced riders here; what do you consider smooth? Are you guys able to shift without changing load on the front at all, or is just the nature of shifting that there always will be that little amount of a dip? Again, I would not consider my current shiftin to be an issue when I ride and I know that it can only get better with more miles and practice, just trying to understand what the ideal shift feels like to you guys. Cheers! |
June 13th, 2013, 08:16 AM | #2 |
btw; as I was doing some research on this topic, I came across this, which I thought was a pretty cool demo of how a bike transmission works:
http://www.gadgetjq.com/transmission.htm |
June 13th, 2013, 09:04 AM | #3 | ||
. _ . Quote:
The time of that deceleration is what racers try to minimize, keeping the forward momentum of the bike as constant as possible. In that pursuit, they use clutch-less shifting (up and down). For street riding, smoothly using the clutch and timing the next couple of gears have worked well for me.
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; June 13th, 2013 at 10:34 AM. |
June 13th, 2013, 11:04 AM | #4 |
MOTM - Mar '13, Jun '14
brrrrrrrm,brrrrrrrm
June 13th, 2013, 11:10 AM | #5 |
Butter.
June 13th, 2013, 11:24 AM | #6 |
When shifting on the street, the goal for me is no jerkiness. Smooth engagement either upshifting or downshifting, without upsetting the bike. But if you're accelerating reasonable swiftly, the shift is going to pause that acceleration for a fraction of a second no matter how smooth you are, and the bike weight distribution will come forward a bit. The softer the suspension, both front and rear, the more noticeable that shift will be.
June 13th, 2013, 11:35 AM | #7 |
^^^ Alex knows what's up. If your front dives more than you are comfortable with maybe you should have your suspension set to your weight. Your duck should have all the adjustments required to set it to your liking assuming your fully geared weight is within the params of your equipment.
Also, it's the best mod that can ever be done to effect the rideability of your bike. It can be fairly cheap too. Like at a track day, even if you don't ride the track you can still visit the suspension tech that is there for the day. Make sure you get his shop info too.
June 13th, 2013, 01:09 PM | #8 |
upshift feels like somebody tapped the back of your chair
down shift feels like somebody tapped the bottom of your shoes.
June 13th, 2013, 02:19 PM | #9 | |
Join Date: Feb 2013 Motorcycle(s): 05 F4i.... Posts: 242
I have the same question also... I've just started doing everything extra smooth about 2 months ago, including shifting.. when I upshift from any other gear it feels really smooth, but from first to second gear especially from a dead stop I can hear the clanking sound... ninjette riders, has the transition from 1st to 2nd gear always this rocky? or is just me..? |
June 13th, 2013, 02:29 PM | #10 |
Some excellent explanations; you guys truly rock! Plus it sounds as if my shifting is not too bad in the grand scheme of things, so yeah to me too
June 13th, 2013, 09:36 PM | #11 | |
EDIT: My bad, I didn't really read the whole question. I was only referring to putting the transmission into gear.... the part that requires no skill or feel.
June 14th, 2013, 05:12 PM | #12 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
mmmm mmmmm mmmmm waaaa waaaa waaaa. Repeat.
June 15th, 2013, 06:37 AM | #13 |
MOTM - Sep '14
[crash.net - WSBK] - Sykes: Words cannot describe how I feelâ?¦ | Ninjette Newsbot | Motorcycling News | 0 | October 20th, 2013 09:40 AM |
Describe your physical build and... | subxero | General Motorcycling Discussion | 58 | September 24th, 2012 09:04 PM |
If you could describe your bike w/ only one word... | ally99 | General Motorcycling Discussion | 99 | October 24th, 2011 09:55 PM |
[roadracingworld.com] - Organizers Describe Thundersprint 2011 As "Biggest And Best E | Ninjette Newsbot | Motorcycling News | 0 | May 10th, 2011 11:50 AM |
RPM issues? Best way I could describe it. | jola | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 5th, 2009 03:54 PM |
