Old July 31st, 2014, 06:00 AM   #1
momoru
momoru's Avatar
Motorcycle(s): 2005 Ninja 250R
Brakes
So I've noticed my front brakes feeling weaker lately, but only today did I realize I can't really stop the bike in a reasonable time at low speeds with just my front brake, so I'm thinking something is up with it.
Going to order new pads, but I also did change my tires about 500 miles ago, so it's possible I effed something up putting the caliper back on. As someone who hasn't done a lot of brake work in the past, what else should I be looking for, or is this most likely a pad issue?
momoru is offline   Reply With Quote
Old July 31st, 2014, 07:46 AM   #2
What color is your brake fluid? When's the last time it was bled?
Does the lever feel squishy? If so, can you make the firm lever return after squeezing the lever HARD a couple times?
When you do new pads, get sintered pads. I've had very good luck with Vesrah pads, both at track pace and street pace. They definitely work better once they have some heat in them though. Before installing new pads, be sure to use rubbing alcohol to clean the rotor to get all oils off of it. do not touch it with your bare hands, ever. If you do, clean it again.
The best you're going to do without major mods (larger rotor, different caliper/MC, etc) is going to be SS brake lines, good sintered pads, and a really good brake bleed with DOT5.1. If that's not good enough, just realize that there are limitations to the brakes on a 250. They will stop you just fine without fading issues, but they require some amount of the incredible hulk on the lever.
also try moving the MC as far in towards the triple as possible on the handlbar. This will make you grip the lever closer to the outside, giving you a slightly longer lever. Leverage is key when applying force. You'd be surprised how much more effective it is to squeeze the lever from the end than to try to go hulk on it from the middle.
Old July 31st, 2014, 08:23 AM   #3
momoru
momoru's Avatar
The lever doesn't really feel squishy I don't think, and there doesn't seem to be any noticeable difference after squeezing a bunch of times. It just feels like it doesn't provide much stopping until all the way in. When it's all the way in, the bike will stay stopped.
The fluid is orange I guess, I see something in the little sight glass over the handle bars. It hasn't been bled since I've owned it. Just bought it ~700 miles ago, so who knows if the pads or fluid has ever been changed.
Old July 31st, 2014, 09:41 AM   #4
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Fluid needs to be like a light yellow, definitely flush it.
M42 is offline   Reply With Quote
Old July 31st, 2014, 11:02 AM   #5
This depends on brand and type. My friend has blue brake fluid and mine is 100% clear. But yea, fresh run of the mill brake fluid has a yellow hue to it and darkens with age.
Old July 31st, 2014, 11:16 AM   #6
M42
Wrench wench
M42's Avatar
Whoa! What type is the blue brake fluid? Sounds trippy!
Old July 31st, 2014, 11:22 AM   #7
momoru
momoru's Avatar
Ok, well I'm going to do fresh fluid and pads and see if that fixes things!
Old August 10th, 2014, 07:26 AM   #8
momoru
momoru's Avatar
Just an update, the pads had a ton of life on them, but the fluid was definitely due to be replaced (probably the color of watered down cola). So I replaced that... feels about the same, maybe a bit smoother, so perhaps the original behavior was in my head. Thanks for your help, I had no idea I should be changing brake fluid that often.
Need new brakes! corksil 2008 - 2012 Ninja 250R Tech Talk 18 September 28th, 2014 11:36 PM
Better brakes?? LittleRedNinjette 2013 - 2017 Ninja 300 Tech Talk 39 July 11th, 2014 08:42 AM
Brakes marc_previtera 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2013 05:22 AM
Front Brakes checho323 2008 - 2012 Ninja 250R Tech Talk 5 February 25th, 2012 02:16 PM
Brakes Jesse8931 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2011 06:17 PM
