Old September 30th, 2015, 09:51 AM   #1
Advincula
New Rider
Advincula's Avatar
Question regarding Oil and longevity...
Hey all,
I'm not sure where to put this because the particular bike in question is a Yamaha R6, so I placed it here. Please move it if it's not meant to be here, thank you!
Context time: My girlfriend owns a 2004(?) Yamaha R6 with about 8,000 miles on it - 4,000 being hers. She bought it about June of last year. Here's the problem: She hasn't changed the oil on that thing since (EDIT: I'm not even sure if the oil was brand new when she purchased it). As of now, the same oil has been in that engine for at least 15 months. I've already lectured her heavily on the necessity of keeping such a high revving engine properly lubricated (or any engine, for that matter) and the irresponsibility of riding a mechanically compromised motorcycle (potential danger to herself, others around her).
My question is: What kind of problems should I look out for? I've read that the piston rings need proper lubrication during the break-in period of the engine to develop good seals, and that in extreme situations you can blow a piston from lack of lubrication, but that's all I really learned from research. Should I be on the lookout for advanced wear? Damage to the rings/rods/block?
I just want to be accurate in knowing exactly what issues that can arise from having such old oil in a relatively new engine like that, and so I can pass on that knowledge for the sake of safety for our hobby.
Thank you for your help!
"The only thing worse than the actions of evil men, is the inaction of good men."
Advincula is offline   Reply With Quote
Old September 30th, 2015, 09:59 AM   #2
Bigballsofpaint
I think you should do an oil change on it and then keep riding it....
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler
Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE
Old September 30th, 2015, 10:00 AM   #3
You aren't going to notice much by running bad/old oil. Frankly, it's hardly worth fretting about at this point - just change the oil!
If cost is a big factor, use Shell Rotella T6 5W-40. If not, there are a lot of good cycle-specific synthetic oil choices. With an engine of that type, good oil is important (it's important for any engine IMO).
It's up to her, but if you are a good boyfriend you will help round-up the necessary items (oil/filter) and schedule a deadline for her to do it (with your help of course).
Simple basic maintenance. Just like checking tire pressure, adjusting the chain, checking other fluids, etc...all of which may need attention at the same time.
Old September 30th, 2015, 10:09 AM   #4
Advincula
New Rider
Advincula's Avatar
Will do! Thank you for your quick responses; I just wanted to be sure of what we were looking at. Perhaps I overestimated the potential damage.
Safe riding, everyone!
Old September 30th, 2015, 10:44 AM   #5
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
The lubrication and bike maintenance recommendations in this thread are sound.
The relationship advice, however, is unwise. I recommend you avoid lecturing, deadlines, and ultimatums. Make this a bonding/teamwork experience! Best of luck.
Old September 30th, 2015, 11:03 AM   #6
There are a few r6 riders here that are very active, me being one of them.
Change the oil/filter
optional - Save a sample to send in to analysis if you want
Do the other normal scheduled maintenance before it causes other more expensive problems
If she has any interest, have her help you do the work yourself. If not... just take care of it yourself.
Old September 30th, 2015, 11:06 AM   #7
Also, 4k miles on a good quality synthetic oil isn't that big of a deal, unless you're riding track/racing, or they're really, really hard miles such as start and stop city traffic. $25 oil changes as needed is cheap engine insurance imho.
Old September 30th, 2015, 11:47 AM   #8
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
So true! NEVER demand of your significant other an oil change or anything else! Instead; your actions, words and attitude should create an atmosphere where it becomes something they want to do regularly!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old September 30th, 2015, 12:23 PM   #9
uh... just change the oil regularly from here on out? Maybe keep an eye on the odometer from time to time since she doesn't seem to know that she needs to?
while you're at it, check her car. 3,000 miles on my motorcycle is normal, I see no reason to panic about 4,000 miles. The car gets oil changes every 5,000 miles, but I've let it go to 6,500 miles before. No biggie.
here's the great thing. Any oil is better than no oil!
Old September 30th, 2015, 12:24 PM   #10
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
^^^ +1 homie
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old September 30th, 2015, 07:52 PM   #11
Originally Posted by Advincula View Post
....... My question is: What kind of problems should I look out for? I've read that the piston rings need proper lubrication during the break-in period of the engine to develop good seals, and that in extreme situations you can blow a piston from lack of lubrication, but that's all I really learned from research. Should I be on the lookout for advanced wear? Damage to the rings/rods/block?
The wear of the engine happens during start ups, when not enough pressure of oil keeps moving metal parts separated.
Short trips at relatively low speeds and frequent start ups can kill any engine many times faster than old oil.
The lubrication system is fed by a pump; hence, as long as there is enough oil level in the crankcase for that pump to suck it up, oil will flow onto all intended parts (even if the filter is too dirty and clogged, because there is a built-in by-pass).
Besides accumulated dirt and carbon from combustion, other potential risk is decomposition of oil due to high temperatures and contamination with gasoline or coolant.
Please, read this:
http://faq.ninja250.org/wiki/Why_Synthetic_Oil%3F
These engines will assertively let you know when lubrication has been deficient, even for short periods of time: they can be either properly lubricated or blown apart.
Old October 1st, 2015, 02:53 AM   #12
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
making a mountain out of a molehill. If you're really concerned, order a testing kit from Blackstone Laboratories. They'll send it to you free of charge.
Collect a sample of the oil when you (make your gf) do the oil change, and send it in. It's not expensive at all. They will email you a nice report telling you all about the oil that was in the bike.
Riding it like I financed it.
Last futzed with by cadd; October 2nd, 2015 at 07:47 PM.
Old October 1st, 2015, 08:14 AM   #13
Originally Posted by cadd View Post
making a mountain out of a molehill. If you're really concerned, order a testing of the from Blackstone Laboratories. They'll send it to you free of charge.
I agree - not that big of a deal - and what are you going to do about it anyway?
I'm personally very concerned about the oil type and condition of the oil in my cycles. I don't hesitate to run them up to redline any time without concern.
I guess I don't really get the Used Oil Analysis (UOA) thing. What are you going to do if it's bad news, but the engine still runs well - pull it apart? I'd rather spend the cost of the test ($25) on top-notch oil.
Old October 1st, 2015, 07:44 PM   #14
Brother Michigan
Motorcycle(s): 2013 Ninja 300
This. I test the oil in my cars regularly just to keep up with what's going on with all those expensive bits inside.
DISCLAIMER: I generally have no idea what I'm talking about.
Old October 2nd, 2015, 02:12 PM   #15
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Yeah, right now it's pretty pointless to do the UOA, unless you're willing to rebuild the engine based on bad results. It would help point out if there's unusual wear or anything like that, but there's not really anything you can do about it. It's simply after-the-fact data. If the results are bad enough that you'd be willing to rebuild it, the problems should be evident in standard operation of the engine without paying for any special tests.
Ideally, you'd do UOAs as frequently as possible when you first get the bike, to get an idea of how quickly the oil wears and to see what's "normal" for your particular engine. Once the pattern is established, you can use that data to establish your maintenance routine and just do occasional UOA spot-checks to make sure nothing weird is going on.
Originally Posted by http://www.calsci.com/motorcycleinfo/Oils1.html
Here's the truth: modern Japanese engines are amazingly well engineered and can tolerate a surprising amount of abuse.
Your engine will not explode if you use Spiffo-Magic Superlube for 4,000 miles. Your engine will not explode if you never use synthetic oils. However, any of these choices puts additional strain on your engine.
Your engine now has a little extra wear on it. It'll probably only last 99,000 miles instead of 100,000. Like everyone else said, don't worry about it, just keep up on maintenance from now on.
[crash.net - MotoGP] - Dovi: Question mark over hard tyre longevity Ninjette Newsbot Motorcycling News 0 April 18th, 2015 03:40 PM
[crash.net - MotoGP] - Dovi: Question mark over hard tyre longevity Ninjette Newsbot Motorcycling News 0 April 18th, 2015 03:10 PM
fork oil question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 16 August 19th, 2014 06:40 PM
Oil question Maielstrom 2008 - 2012 Ninja 250R Tech Talk 1 August 10th, 2012 11:24 AM
Oil question SpYd3r05 1986 - 2007 Ninja 250R Tech Talk 4 May 10th, 2010 05:14 PM
