July 16th, 2014, 05:30 PM | #1 |
Candy Lime Green
Join Date: Jun 2014 Motorcycle(s): 2012 Kawasaki Ninja 250R Posts: 27
Chain Lube!
I didn't see any recent threads on the topic so I thought I would bring it up for discussion.
I want to know what different types/brands of chain lube ya'll are using, pros and cons, how often using, applying tips/techniques, all that good stuff! I've had my Ninja for just over 6 weeks now and I've had to lube her chain like 3 or 4 times already. I went for the first 2 or 3 weeks without applying any, and then after that up to once a week when I wash it. It's not the end of the world that I have to re-lubricate my chain every week. But I can't help but wonder if there's a chain lube out there that will last longer without any extra mess or sling-off. I'm currently using Dupont Motorcycle Chain Degreaser (Cleaner) & Dupont Teflon Chain Saver (Lubricant) A lot of people spoke highly of this stuff so I went and got some. My process... (Can says "NO Water Rinsing Required"... That's horse **** haha, they only say that because they want you to use the entire can rinsing off excess grease so you have to go out and buy more of it!) 1. Coat the chain in degreaser, thoroughly scrub chain on all sides, Rinse 2. Repeat step 1 to clear any remaining grease off chain 3. Dry with a paper towel and allow 10-15 minutes for extra moisture to dry. (At this point I can literally wipe my finger on the chain and have a clean finger, no black) 4. Apply a thorough coat of lubricate while advancing the chain for anywhere from 10-20 seconds. 5. Allow at least a half hour to lubricant to settle/stick to chain Works pretty good, takes me about an hour including drying times. Lubricant sticks to chain great for 3-5 days with no dirt or gritty **** sticking. Then after a couple more days it's getting to be dry to the touch and it no longer feels lubricated. So I wash the whole bike and repeat the process over again. Making sure I detail my rims AFTER I apply chain lube Just wondering...am I doing everything right or could I do something differently to further increase healthy chain life? I wouldn't mind trying a different kind of lube but I don't want anything messy. Any tips or advice greatly appreciated! And sorry for posting boring stuffs. I'll get around to taking some cool pictures of my bike and **** soon! Ride on! |
July 16th, 2014, 05:33 PM | #2 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
I use Original Bike Spirits Chain Lube and it seems to work just fine. There's no fling off, and I put more on every 300-500 miles. It got great reviews, such as at Web Bike World, so it's what I went with.
July 16th, 2014, 06:08 PM | #3 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
http://www.motosport.com/dirtbike/MO...OAD-CHAIN-LUBE
I use this, along with the same brand of off-road chain cleaner. I always cleaned my chain before lubing it and I'd say I did it about every 500-700 miles. I just use WD40 or ^that Motul chain cleaner and scrub it a bit with a rag, then immediately apply chain lube and that's really about it... It takes me like 7 minutes... My chain has always been fine. What kind of chain do you have? I'd recommend DID X-ring. |
July 16th, 2014, 06:15 PM | #4 |
Candy Lime Green
500 mile chain lube sounds like a dream to me haha.
I haven't changed out my stock chain yet so it's whatever comes on a 2012 Ninja 250R from the factory. |
July 16th, 2014, 07:20 PM | #5 |
Join Date: May 2014 Motorcycle(s): 2005 Ninja 250R Posts: 60
I'm fairly new to the whole chain lubing thing myself, but it seems like you may be lubing too often. My understanding (and I could be wrong) is you are lubing the o-rings between the chain links, not the chain itself, so just because the chain feels dry doesn't mean it needs lube? Correct me if I'm wrong, right now I just do it every 500 miles.
July 16th, 2014, 07:21 PM | #6 |
i don't think there is such a thing as lubing too often
July 16th, 2014, 08:07 PM | #7 |
Join Date: Apr 2012 Motorcycle(s): 2012 Yamaha FZ6R, 2014 Suzuki GSX-R600 Posts: 299
I tried a few different ones and settled on Maxima chain wax. It resists rust much better than the others I have used and doesn't fling.
July 16th, 2014, 08:59 PM | #8 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
I had a habit of just lubing the chain every weekend as I usually rode around 200 miles per week, only takes a couple of minutes.
July 16th, 2014, 09:21 PM | #9 |
Join Date: Jul 2014 Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat) Posts: 404
July 16th, 2014, 09:22 PM | #11 |
July 16th, 2014, 11:42 PM | #12 |
Certified looney toon
MOTM Jul '13, Jul '14
I had my shop tell me I was applying too much as well, since all the gunk had built up behind the front sprocket cover. I was lubing the chain with Maxima Chain Wax about every 300-400 miles.
Found a better solution for my type of riding... Scottoiler
July 17th, 2014, 07:22 AM | #13 | |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
But for my 250 i just use the bel ray since its white and i can see where i have applied it. |
July 17th, 2014, 08:01 AM | #14 |
Stuff just works, a single application lasts as it should. Doesn't fling off so bad even if you over do it a bit.
July 18th, 2014, 03:55 PM | #15 | |
Just got one for the 675 today, trying to figure out where to fit it, it's pretty much horizontal if I put it on the subframe, I can get a bit of an angle on it if I attach it to the upper spar of the swingarm |
July 18th, 2014, 05:47 PM | #16 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
ever see my chain???
July 18th, 2014, 06:45 PM | #17 | |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
I use kerosene for cleaning. I used to use belray chain wax, but it gunked up everywhere (like all over the inner sideplates) and blahhh. Now I just apply a thin coat of gear oil while the chain is warm, and wipe off the excess. Seems to work well.
Though I'd imagine there's a point where near-constant lubing is unnecessary and won't lengthen the life of your chain any meaningful amount, like once every 200 miles would be a waste of effort. I do mine like every 500 miles. A little less if it's been rainy.
July 19th, 2014, 08:40 AM | #18 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
Motul. They make some of the best products in the market.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
July 20th, 2014, 03:18 AM | #19 |
Captain 2 Sexy
Join Date: Apr 2014 Motorcycle(s): Kwaka EX250 Posts: 241
We need pics of this installed.
July 20th, 2014, 04:33 AM | #20 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
You can get this Maxima chain wax care kit like me and be done with it. Works great.
http://www.motorcycle-superstore.com...n-wax-care-kit
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
July 20th, 2014, 07:07 AM | #21 |
Got some during the install: https://www.ninjette.org/forums/showthread.php?t=165071
Chain Lube | seth hall | General Motorcycling Discussion | 15 | August 23rd, 2014 01:07 PM |
Chain lube! | corksil | General Motorcycling Discussion | 27 | June 20th, 2014 06:27 PM |
Chain Lube | OzzyDevil | General Motorcycling Discussion | 3 | April 21st, 2012 07:41 AM |
Chain Lube!? | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 3rd, 2011 12:43 AM |
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2009 09:50 PM |
