#1 |
Join Date: Oct 2014 Motorcycle(s): 2014 Ninja 300 Posts: 160
Clutch springs
Would anyone happen to have the dimensions for the OEM clutch springs? Much thanks!
#2 |
#3 |
Well, got the answers i needed when i purchased some Barnett springs. Same as a yamaha R1 spring. I wanted to see if there was a different spring I could use that we make that could be a heavier option than the Barnett. Sadly, it doesnt look like there is.
#4 | |
I'm not sure about the NewGen but here's a short write-up for PreGen Ninjette, you might get lucky,
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#5 |
Pre-gen and New-gen use the same spring. This spring fits *deep breath* :
EL250 Eliminator (4 pack) KZ400 (4 pack) KZ440 (4 pack) Z-1 900 (5 pack) KZ1000 (5 pack) KZ1000 J model (5 pack) KZ1000 Police model (same as J model) GPZ1100 (5 pack) KZ550 (5 pack) GPZ550 (5 pack) KZ650 (5 pack) KZ750 (5 pack) KZ900 (5 pack) 85-97 ZX600 (5 pack) 84-86 ZX900 (RARE bike) (5 pack) 750/900 Vulcan (5 pack) Ninja 650 (the new one) (5 pack) Apparently this is Kawasaki's workhorse spring... The 300 Spring fits: The 300 (3 pack) 05-06 ZX6R and RR (6 pack) 07-16 Honda CRF150 (?!?!?!?!?!) (4 pack (even more ?!?!?!?!?!?)) 06-15 ZX10R (6 pack) Pre-gen/New-Gen Spring size: ID .557" 14.1mm OD .789" 20.0mm Length 1.325" 33.6mm 300 spring size: ID .594" 15.0mm OD .768" 19.5mm Length 1.720" 43.71mm Comprehensive cross reference list! |
#6 |
Board Member
I have stronger springs, preloaded with washers in my new-gen. Along with a true Kevlar clutch. @Racer x and I went through this extensively as he had experienced slippage.
#7 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
yea, how is it possible to get a 250 to slip on the stock clutch if they used it in a KZ1000? I know the police bikes used to get 35-40K on a clutch easy!
Calling @RacerX What's going on here?
![]() My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
#8 |
Board Member
The OEM discs and the four spring clutch will not take over 35hp. That is why I upgraded to better discs and springs. If we had 5 or 6 springs, there would be much more holding pressure, but budget bikes don't get the fancy stuff.
#9 |
Doesn't the new 300 have 3 springs?
#10 |
MOTM - Sep '18, Feb '16
I use the Barnett springs and they are at coil bind when I pull the lever in. There is no room for more spring.
To get the stock clutch to burn up and turn the steels black in one mile ,just add enough power. About forty or fifty will do the stock clutch in. I have seen sixty on the Barnett and no slippage . But I would not like to ride it in a traffic jam.
#11 |
As I stated above and I've done this upgrade to both my Ninjette and EX500, and have no ill effects as of yet, the EX I've put 20k miles, and the Ninjette I've put 8k miles.
No matter wether you have a PreGen or NewGen, or 300 to OEM clutch springs are just barely up to the job, and over time they just give out. I would put the upgrade in the same category as suspension upgrades, and even preventive maintenance item. It's an easy and cheap upgrade.
#12 |
Freedom for Germany
Sorry but I can't believe this "The OEM discs and the four spring clutch will not take over 35hp."
As far as I know the Scuderia Platini use the oem clutch at their over 45 hp race bike. |
#13 |
Board Member
I would look into that. More than likely they change out the parts just like I did. You don't need major surgery. Just about $150 and some general knowledge for better feel and more holding power.
#14 |
Board Member
alright, so I cannot read this...but I see a sub cooler and a slipper clutch in their "racing" parts.
http://www.scuderiaplatini.it/250_racing.html |
#15 |
Board Member
Oh...and my springs are a lot like the ones on this page. the spacer is just a bit thicker than stock.
http://www.beet.co.jp/english/kawasaki/ninja250r/ |
#16 |
Just do the Barnett springs for less than $20 USD, you'll be just fine.
#17 | |
Freedom for Germany
![]() But that also hasn't anything to do with the slipper clutch, what I also have now and what's a great thing. |
#18 |
MOTM - Oct '15
So the weak point is the springs, not the friction plates, which, APEMike's post, is the same friction plates they used on many motorcycles up to the KZ1000? They just put in heavier springs on these bigger bikes, as I don't think they can fit a fifth spring inside those plates, no?
#19 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
I was getting slip too. The OEM plates were fine and still in spec. I swapped them out for Barnett kevlar plates and springs.
The OEM springs suck. That's all there is to it. You spend a lot of time on the clutch with the 250R because its up and down through the gears more than a larger bike. And all the compression and decompression of the springs just wears them out faster. When combined with only 4 springs, and low grade ones at that....they bail. |
#20 |
Another factor is type of oil, the wrong oil will cause slippage.
any 10w-40 to 20w50 rated JASO-MA/MA2 oil will do just fine. A popular choice is Shell Rotella synthetic T6 The springs are weaker for a reason, it's an entry level bike. Below are pictures showing the difference between OEM Vs aftermarket springs
#21 | |
Board Member
#22 |
Clutch springs determine the recoil of the clutch lever; how hard it is to pull the lever and, when the lever is released, how much force is holding the lever up against its stop. Weak clutch springs make it very easy to pull the lever, which is convenient for weak riders, but can result in some clutch slippage, as the engine is not fully engaged when the clutch is released. With stiffer clutch springs, the lever is harder to pull, but when the lever is released, the clutch is fully disengaged, and there will be no clutch slippage, so the engine is allowed to direct all of its power to the rear wheel. It is believed that, since many newbies and female riders are attracted to the Ninjette & EX-500, Kawasaki opted to use softer clutch spring that would allow easier disengagement of the engine.
Also the KZ1000 uses more plates and steels, almost 2x as the Ninjette. But given the power output of the Ninjette, the plates and steels are still a decent amount, if you change out the springs themselves. This is assuming you don't abuse the clutch itself, keep it adjusted properly, and of course use the right oil.
#23 | ||
MOTM - Oct '15
OK, so a KZ1000 puts out more than 80hp. It has the same springs as a ninja250, but 1 more, for a total of 5, instead of 4 - per APEMike's post up top. The claim is that the 250's clutch starts slipping above 35hp. So, this then leads to 1 additional spring allows the KZ1000 clutch to hold 45hp more? That's seem disproportionate to me... Some quick math, which might betray my lack of physics knowledge, but work with me. KZ1000 uses the same clutch springs as a Ninja 250. KZ1000 has 5 clutch springs @ 80hp = 16hp/spring. Ninja 250 has 4 clutch springs @ 35hp = 8.75hp/spring. How is then is it that the Ninja 250 starts slipping above 35hp and the KZ1000 does not at almost twice the HP/spring, using the same springs? Where am I getting confused?
#24 |
It has more plates and steels, than the Ninjette, which also has a large factor.
Clutch is a mixture of plates, steels, and springs.
#25 | |
MOTM - Oct '15
I never quite understood how stacking plates equals less, larger diameter plates. I do understand a bigger circle provides more torque, but not how stacking small diameter plates increases torque, if that makes any sense... Or am I on the wrong path here? Should I be thinking frictional coefficients? By adding more plates, the clutch is capable of more much friction, and so the squeezing power of a "weaker" spring is amplified? Help me relate the clamping force of the springs to the surface area more vs. less plates please.
#26 |
#27 |
More friction and steel plates = more power handling capabilities of a clutch. It all comes down to total surface area, the springs themselves apply the clamping force to the clutch pack.
#28 |
MOTM - Oct '15
love that dude! That's the equation I was after, and explained it perfectly! Thanks!
#29 |
A long time ago I knew that calculation, but I forgot it.
Glad I could find it, I love the 21st century.
#30 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 485
Plus I believe the 300 has a dual action cluth, both drag type & slipper, so under power it increases lockup rather than slip & under reverse torque, it slides out of engagement ala slipper clutch, hence the reason it only has 3 compression springs !
Does anyone know if the 300 clutch cover case fits on the 250 crankcase ? |
#31 |
Most likely not.
I ride because therapy is too expensive, and less fun. |
#32 |
This thread indicates the gasket area is the same https://www.ninjette.org/forums/show...ngine+compared
So in theory 300 clutch can be retrofitted to 250 but really needs the 300 clutch cover, as another thread shows the 250 reinforcing webs being cut away to make it fit ! http://s2.photobucket.com/user/cuong...28FB2.jpg.html http://s2.photobucket.com/user/cuong...D8519.jpg.html |
new springs, emulators, springs sound noisy? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 19th, 2014 04:14 AM |
clutch springs | John D | 2008 - 2012 Ninja 250R Tech Talk | 28 | May 24th, 2013 12:58 PM |
Barnett clutch springs...don't fit. | smokinsingle | Ninjettes At Speed | 6 | March 14th, 2013 04:33 PM |
Barnett Clutch Springs | scotty | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 17th, 2011 03:54 AM |
