October 21st, 2014, 01:16 PM | #1 |
Join Date: Jul 2013 Motorcycle(s): 2012 ninja 250r Posts: 49
popping noise
My bike makes a single pop when it starts cranking usually after its been sitting a while. I'm curious is that because of valves or what
October 21st, 2014, 01:18 PM | #2 |
A backfire?
October 21st, 2014, 01:42 PM | #3 |
I guess
October 21st, 2014, 01:55 PM | #4 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
It couldn't hurt to do a valve adjustment, when was the last time? Carb cleaning? Are there any mods on your bike?
My bike backfires too from time to time. Totally random, at different states of modifications, different temps, different waiting periods. |
October 21st, 2014, 02:02 PM | #5 |
Bike is stock except for k&n filter and I haven't cleaned the carbs and I'm at 14k so I'm going to get it checked out
October 21st, 2014, 02:04 PM | #6 |
No valve inspection/adjustment at that mileage? Definitely get that checked out.
October 21st, 2014, 02:12 PM | #7 |
Try a simple fix first;
Do you use the choke when cold starting? No? Try it next time. You might want to consider shimming your needles.
October 21st, 2014, 02:16 PM | #8 |
I had the valves inspected at 7.5k and. I do use the choke on cold starts
October 21st, 2014, 02:35 PM | #9 |
Inline 4!!!
My slipon "pops" when I decel, I love it ^_^
October 21st, 2014, 03:27 PM | #10 |
Ok cool, let's at least start by which area this pop comes from. Exhaust or carb? Does it pop from the tailpipe or does the sound come from under the seat/somewhere in the middle of the bike?
October 21st, 2014, 03:53 PM | #11 |
Sounds like the tailpipe
October 23rd, 2014, 09:46 AM | #12 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
Popping from the exhaust is unburned gas igniting in the pipe. Might sound cool- but it's indicative of a bad air fuel mix.
If it only happens at start up after sitting for a while my guess is that the carb bowls are filling up too much and fuel vapor is getting in to the cylinder and messes with the ratio only at start up. Clean or replace the needle valves in the carbs if the float level is within spec. |
October 23rd, 2014, 10:14 AM | #13 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
If it only happens once in a while (after sitting for weeks) at start-up and it's not an ear-shattering "kaboom", why even worry about it?
October 25th, 2014, 03:30 PM | #14 |
Popping the clutch | dcx4610 | Riding Skills | 14 | October 10th, 2012 06:08 PM |
Popping during deceleration | chikenstrips | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 25th, 2012 07:00 PM |
Popping noise out the exhaust | Kviper52 | 1986 - 2007 Ninja 250R Tech Talk | 1 | October 6th, 2011 07:07 AM |
Popping on deceleration... | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 26 | October 3rd, 2011 02:34 AM |
Backfiring and popping | Keenan84 | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 21st, 2010 09:01 PM |
