Old July 5th, 2013, 06:27 PM   #1
sunspots
sunspots's Avatar
Motorcycle(s): 08 Plasma Blue 250
Bike turns off at startup
Hey guys, so I picked up my 250 less than a week ago and I've had this issue twice. (I'm completely new to riding)
So I'll put my key in the ignition, flip the switch on and press the start button.
The bike will start like normal but then when I try to rev it up while its still in neutral, the engine just cuts off.
I feel like I'm doing something wrong here.
Can someone give me their take on it.
Edit: Also other times I start it, it starts up just fine and I am able to ride it with no problems.
sunspots is offline   Reply With Quote
Old July 5th, 2013, 06:36 PM   #2
Let's assume everything is fine first. To start the bike, pull the choke and start it up. Let it run until the idle revs up (normally around 3k rpm), then push the choke back. The idle should return to 1200-1700. Proceed riding only when the bike will accept throttle input without dying. Overall process takes about 1-2 minutes.
EDIT: On a hot day or if the bike is still warm from a previous ride, you may not need to use the choke. You will know because as soon as you start the bike, it will instantly rev to around 3k prm.
Assuming something is up.
I just fixed this problem on a bike today. Has the bike been sitting around for a long time? If so, your gunna have to clean the carbs and ensure the airbox and filter clean too.
Old July 5th, 2013, 06:42 PM   #3
sunspots
sunspots's Avatar
Are you always supposed to use the choke to start up the bike? (This is my first time hearing about this, sorry about my noobiness)
I'll take a look at the airbox and carbs in the morning.
Thanks csmith.
Old July 5th, 2013, 06:46 PM   #4
In case you missed my edit.
Also, cleaning the carbs is a pretty invasive task on the lil ninjas but is easy if you take your time. It's best to have some help from a friend your first time.
Old July 5th, 2013, 07:20 PM   #5
Are you always supposed to use the choke to start up the bike?.....
Each time that you start up a cold engine:
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
Old July 5th, 2013, 07:44 PM   #6
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Thanks csmith.
On most you do but some you never need it, mine never needs it.
So my bike turns off at an intersection Ninja Rob General Motorcycling Discussion 21 October 30th, 2014 06:25 PM
FI cold startup, my 2005 project bike greg737 Videos 15 April 4th, 2012 03:21 AM
2005 EX-250 FI project bike cold startup test. greg737 Videos 16 December 21st, 2011 12:03 PM
Bike dies @ startup and missing part? Bl4kkat 1986 - 2007 Ninja 250R Tech Talk 6 July 13th, 2011 07:32 AM
[topix.net] - The MIC Turns Up The Heat On Kid Bike Ban Ninjette Newsbot Motorcycling News 0 February 10th, 2010 04:20 PM
