Old July 9th, 2013, 10:01 AM   #1
bowlingballhead
bowlingballhead's Avatar
Motorcycle(s): 250 baby!
Did I just grenade my motor by going 1k over on the valve inspection?
I'm sure the answer is in the forum somewhere, but right now, too distraught to search. Bike won't move. Won't rev, choke does nothing, dies. Now, it won't even start. When it did start and run (kind of), engine definitely didn't sound right; ticking/clacking noise. Overheat light is not on, coolant is full. I've done all the oil and filter changes and bike is stock. I'm at about 1,000 miles over on the valve inspection/adjustment. My original dealer closed due to the economy right after I bought it in '08, and the other closest dealer (65 miles away) dropped Kawi this Spring, which I found out when I went in to inquire about the valve check. Been procrastinating on getting it done because the next closest Kawi service is 150 away in Mora, MN ().
Am I doomed? I have a bad feeling. ('08 250r owned since new with about 8500 on the clock).
bowlingballhead is offline   Reply With Quote
Old July 9th, 2013, 10:08 AM   #2
Hmmmm, I have went way past the scheduled checks for valves before and they didn't blow up or anything.
Have you been riding it recently?
When was the last oil change?
Old July 9th, 2013, 10:09 AM   #3
You tick clanking sound could be the cam chain as well.
Old July 9th, 2013, 10:10 AM   #4
bowlingballhead
Thanks for the quick reply. Yes, I have been riding it recently, and the last oil and filter change was back in November right before I garaged it for the Winter. it only has like 500 miles on the fresh oil.
Old July 9th, 2013, 10:26 AM   #5
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
so you walked up to your bike and suddenly...nothing. You didn't drop it, lay it down, leave it for a few days without riding, or anything before these issues started?
Also, no, it's not your valves.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old July 9th, 2013, 10:38 AM   #6
bowlingballhead
No drop, no fall, rode it just the other day. Last night coming back from the grocery store, i went to take off from a stop sign, and she didn't wanna go. I revved the **** out of it and barely made it home. In my wishful thinking mode, I just chalked it up to it being only 50 degrees here yesterday, but getting it warmed up to go down to the store today I could tell something was really not right, not just the cold.
Old July 9th, 2013, 10:43 AM   #7
bowlingballhead
Come to think of it though, my bike sits out on the street. When I went to take the black trim panels under the seat off to get a better look, i noticed that the screw on the clutch side of the bike was missing, and the panel seemed misaligned. Is there anything in there that can be tampered with that would cause this kind of problem? The fuel reserve switch seemed to be in the right place .
Old July 9th, 2013, 10:44 AM   #8
DaBlue1
DaBlue1's Avatar
Originally Posted by bowlingballhead View Post
I.... Bike won't move. Won't rev, choke does nothing, dies. Now, it won't even start. When it did start and run (kind of), engine definitely didn't sound right; ticking/clacking noise. Overheat light is not on, coolant is full.
....getting it warmed up to go down to the store today I could tell something was really not right, not just the cold.
What have you checked?
Air Filter?
Snorkel?
Gas?
Oil Level and condition?
Old July 9th, 2013, 10:57 AM   #9
bowlingballhead
Air Filter?
Snorkel?
Gas?
Gas is full. Filled it up at my regular Mobil station, so not thinking bad gas. Oil is right in the middle of the sight glass. No air filter or snorkel yet. When it quits raining, I'll get after it. Probably the plugs as well. Thanks for the replies.
Old July 9th, 2013, 10:58 AM   #10
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
There's all kinds of vacuum hoses under that cover that if any one of them is pulled off can cause all kinds of problems. But it seems odd it would just start running crappy on the way home while it was already running good.
Old July 9th, 2013, 11:22 AM   #11
DaBlue1
DaBlue1's Avatar
How long has the bike been sitting in the rain?
Your issues sound similar to this one. http://www.ninjette.org/forums/showt...ank#post705237
Old July 9th, 2013, 12:24 PM   #12
Trailerboy531
Did a spark plug cap come loose?
CVMA #531
Old July 9th, 2013, 06:50 PM   #13
bowlingballhead
Tomorrow she goes up on the stands and the fairings come off. I'll let you guys know what it looks like. Thanks for the replies.
Old July 9th, 2013, 10:42 PM   #14
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
My guess is your clutch is fuxored
AFM #676
Supersports are for n00bs
Old July 10th, 2013, 05:47 AM   #15
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Pet cock in the wrong position?
Old July 10th, 2013, 11:30 AM   #16
bowlingballhead
Exhaust side:
Clutch side:
Clutchy looks significantly lighter, but not bad. Any thoughts?
What next? Air filter is a little dirty but not that bad. Drain the gas tank? I'm coming to the end of me mechanical skillz .
Old July 10th, 2013, 11:41 AM   #17
bowlingballhead
A better look at the clutch side plug:
Not all that much different.
Old July 10th, 2013, 12:13 PM   #18
Your carbs need synced.
Old July 10th, 2013, 12:24 PM   #19
DaBlue1
DaBlue1's Avatar
What next?
Did you read thru this thread? http://www.ninjette.org/forums/showt...ank#post705237
Old July 10th, 2013, 12:36 PM   #20
bowlingballhead
My bike has sat outside (except for winter) since the day I got it (which is over five years ago). I've never had a problem like this before and it's been through torrential downpours. I will read the thread right now though, thanks.
Old July 10th, 2013, 09:01 PM   #21
bowlingballhead
In the end, you were right all along. I took off the tank, dumped the gas, drained the carb float bowls, rolled down to a different G-station, put two gallons in a gas can, poured it in, and boom . . . cooking with Crisco again.
I am still in disbelief that it turned out to be a fuel problem. I've been fueling at that station for years and have never had a problem. The Ninja has sat outside in the rain for years and it has never been a problem . . . but when you're right, you're right.
Thanks everyone for the replies. The Ninja is staying in a garage from now on it looks like.
Old July 11th, 2013, 08:17 AM   #22
DaBlue1
DaBlue1's Avatar
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
valve inspection jcsalazar 2008 - 2012 Ninja 250R Tech Talk 2 October 18th, 2014 04:37 PM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
[topix.net] - Testastretta 11A motor gives Multistrada 1200 15,000-mile valve inspect Ninjette Newsbot Motorcycling News 0 February 5th, 2010 08:50 PM
[hell for leather] - Testastretta 11° motor gives Multistrada 1200 15,000-mile valve Ninjette Newsbot Motorcycling News 0 February 5th, 2010 02:50 PM
