Old January 8th, 2023, 05:30 PM   #1
jk3099
Motorcycle(s): 2006 Kawasaki Ninja 250
06 Kawasaki Ninja 250 Won't Start + Gunk in Carbs
Hi all,
This past summer, I bought a Ninja 250 that wouldn't start, but after cleaning the carbs, replacing the spark plugs, changing the coolant, and changing the battery (final step), I got it to run. Unfortunately, it only ran a week before breaking down. I finally got around to cleaning the carbs (all pilot jets, main jets, idle mixture screws, and replaced the rubber o-rings by the float valves) and tried starting it up, but it still won't start up. I checked and saw fuel circulating from the tank to the carbs, and I had the battery charging for a few hours before. When cleaning the carbs, I did notice some slimy gunk in the chamber holding the float valves (pictures attached at the end). I cleaned this out, but any idea what it is or where to go next? Thanks in advance!
jk3099 is offline   Reply With Quote
Old January 8th, 2023, 06:16 PM   #2
ducatiman
ducatiman's Avatar
trade in?
https://www.ninjette.org/forums/showthread.php?t=392318
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 8th, 2023, 06:24 PM   #3
That's a good deal. These carbs take quite a bit of knowledge and effort to get clean enough to run properly. Here's a site to give you an idea of what's needed:
http://n4mwd.blogspot.com/2013/10/se...-passages.html
06' Ninja 250 Won't Start Help ChaseSpicer 1986 - 2007 Ninja 250R Tech Talk 26 June 18th, 2020 05:36 PM
my kawasaki ninja 250 2005 won't start Yehia 1986 - 2007 Ninja 250R Tech Talk 15 August 5th, 2014 08:37 AM
Bike won't start, cleaned carbs, new gas, backfires whats next? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 7 July 26th, 2013 09:53 PM
Won't start after pulling carbs Insan3guy 1986 - 2007 Ninja 250R Tech Talk 10 July 17th, 2013 07:12 AM
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) Pocket Sprocket 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 11:13 AM
