Old August 13th, 2014, 10:21 AM   #1
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Whirring Noise
Not quite sure whether its only my chain or the transmission as well. In 6th gear at lower rpm's, my sex r makes a continuous noise that resembles a supercharger wanted to know if it's normal or if I should be concerned
Old August 13th, 2014, 10:37 AM   #2
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Transmissions usually have mechanical whirs.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old August 13th, 2014, 10:39 AM   #3
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
It's just much more readily apparent in 6th gear. I think it's because the rpm's don't get high enough at such a low speed, and the engine noise doesn't cover it up.
Old August 13th, 2014, 11:00 AM   #4
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
First, make sure it is not of the Dervish variety. If it is, open the oil filler cap and look inside for this:
250rr is offline   Reply With Quote
Old August 13th, 2014, 09:48 PM   #5
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I don't get it lol
Old August 13th, 2014, 11:46 PM   #6
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
http://en.wikipedia.org/wiki/Whirling_dervishes
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old August 14th, 2014, 07:30 AM   #7
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Ib checked it is not that
Old August 14th, 2014, 08:16 AM   #8
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Is it something new, or has it always made the noise?
Old August 14th, 2014, 08:20 AM   #9
Check your chain tension - it may be too tight. A tight chain can make a similar sound.
Chain adjustment video - http://canyonchasers.net/video/chain.php
Old August 14th, 2014, 08:47 AM   #10
250rr
250rr's Avatar
Good work.
Old August 14th, 2014, 09:52 AM   #11
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
If it's like mine, it's caused by the worms in your brain.
Old August 14th, 2014, 06:11 PM   #12
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
No idea. I think without the fairings noises are much more apparent. It does it in every gear now that I've been paying attention. The chain can't be too tight, because I adjusted it towards the looser side.
Old August 14th, 2014, 08:17 PM   #13
I am going to look on the positive side of things here. It sounds like you're getting in touch with your bike a lil more. I went through this same thing with my r6, stressing over every little sound until I vetted everything out. When everything is right, your bike is finely tuned instrument, and like most... they will have a sound representative of such precision.
Aside of that, there are sounds that spell trouble ahead of time, these normally have a distinct pattern and are repeatable under conditions. If you can repeat your sound, you will find your reason. Got a stand? Throw it up and run it. Do you hear it while not in motion?
And yes... without fairings, the unique sounds your bike makes will be louder.
Old August 15th, 2014, 12:31 AM   #14
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I recall a similar supercharger type sound with another zx6r. If I got it on video would that be of any use
Old August 16th, 2014, 01:03 PM   #15
KawiKid860
KawiKid860's Avatar
Most bikes have some tranny and clutch whines, you could be hearing it in 6th because you're at lower rpms or just something about that gear.
Old August 16th, 2014, 01:21 PM   #16
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
It happens in every gear. I can hear it much more with ear plugs (drowns out the exhaust).
Electrical Whirring Noise lostdaemon 2008 - 2012 Ninja 250R Tech Talk 4 July 26th, 2012 09:47 PM
looking for help - noise davila 2008 - 2012 Ninja 250R Tech Talk 13 June 30th, 2012 08:54 AM
Need help with a noise TeamGreen 2008 - 2012 Ninja 250R Tech Talk 10 August 28th, 2011 07:17 PM
'06 noise while upshifting Navyboy 1986 - 2007 Ninja 250R Tech Talk 10 October 23rd, 2010 02:26 PM
little noise when braking n4v1n 2008 - 2012 Ninja 250R Tech Talk 8 September 19th, 2009 12:06 PM
