Go Back   ninjette.org > General > Off-Topic
View Poll Results: What kind of razor do you use?
Safety Razor 7 17.07%
Straight Razor 7 17.07%
Cartridge Razor 15 36.59%
Electric Razor 12 29.27%
Voters: 41. You may not vote on this poll
Old August 20th, 2014, 10:50 AM   #1
salcuta88
salcuta88's Avatar
Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat)
What do you shave with?
Do you use a safety, straight, cartridge, or lazy razor ? Vote!
I use a parker safety razor.
salcuta88 is offline   Reply With Quote
Old August 20th, 2014, 11:11 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I actually don't fully shave 95% of my face/neck.
My skin doesn't do well with a close clean shave, so for last 12 years or so I use a beard trimmer with no cover thing so it is as close as it will go to shave everything on my face/neck, then I use an electric foil razor to get my upper lip and cheek area to give me a thick chin strap
Its quick easy and uber cheap. I have been using the same trimmer and electric razor for the past 9 yrs easy.
Sure I have some scruff all the time but I like it.
Old August 20th, 2014, 11:21 AM   #3
until just recently i was a disposable razor kind of person. but i decided to try electrics again and bought a sensitouch 3d... it was expensive... its the best shave i've ever had. can do it wet or dry... the battery lasts a long time... nice and close shave and you can do it without paying attention if you want.
Old August 20th, 2014, 11:52 AM   #4
Whiskey
Electric mostly but if i want a clean shave then this does the job
Used to use a mach 3 that would rip the face off me when i was in the army, a barber mate of mine suggested that a single very sharp blade would do a better job of it & was spot on.
Takes a bit of getting used to but does a very clean job, took off a month's beard in a couple of passes without a scratch.
Old September 4th, 2014, 11:14 AM   #5
Ytse Frobozz
Not dead yet!
Ytse Frobozz's Avatar
Cartridges for me. I'm in the Dollar Shave Club!
Ytse Frobozz is offline   Reply With Quote
Old September 4th, 2014, 12:24 PM   #6
i'm guessing it's very high carbon steel... you have to sharpen before each use? how long does it take to sharpen?
Old September 4th, 2014, 01:26 PM   #7
Flying
Motorcycle(s): 2010 Ninja 250
Used to go electric, then I switched to a single blade, single blade needs to be honed so now I'm using a bag of cheapo 30 cent razors that are good for only two shaves each.
Ideally one strops the blade (rubs against leather like in the movies) for one-two dozen strokes before and after use. If there is any sign of damage, tugging or failing the single hair test, you hone it on a sharpening stone with a polishing grit (3000 or so). How long you go between honing depends on your care of the tool: whether you keep the blade oiled, away from moisture, etc. Last time I sharpened my blade was 4-5 months.
Old September 4th, 2014, 01:39 PM   #8
allanoue
allanoue's Avatar
MOTM - Sep '14
Old September 4th, 2014, 02:11 PM   #9
Apex
Livin' the Minimoto Life
Apex's Avatar
Old September 4th, 2014, 02:41 PM   #10
Whiskey
50 strokes each side on the strop, it takes a couple of minutes at most
You want it properly stropped before putting it near your face, skimp on that & it will take the face off you piece by piece.
Old September 4th, 2014, 02:55 PM   #11
Whiskey
You can get the barbers version of the straight blade, it uses safety razor blades in a holder, one or two shaves & switch it out. I have a wiry beard that catches in multi blade razors & cuts the face off me, tried one of them for a while before going for the Dovo
Old September 4th, 2014, 03:53 PM   #12
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Usually a straight razor and double edge blade cut in half... Cheap, always sharp, always a clean shave
Old September 4th, 2014, 05:09 PM   #13
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
As a guy who shaves his head every morning am deeply interested in shave gear. I have five tools:
One of these for most of my head
One of these for head details, face and neck. Moved to it from a Mach 3 and like it much better.
These two things:
And last but not least.....
Hotel soap. Yep. Every time I travel I bring those little free bars of soap back with me and chuck 'em in a box. I haven't bought shaving cream in many years.
Old September 4th, 2014, 06:39 PM   #14
Snake
Snake's Avatar
For years I have been shaving with a disposable cartridge razor but I am going to switch to an old fashioned safety razor like my Pop used to use. Disposable cartridges are becoming more and more expensive and don't last long.
Old September 4th, 2014, 06:44 PM   #15
srob7001
Motorcycle(s): Ninja 300, Ebony, non-ABS
A razor hasn't touched my face in about 7 years. Beard man here.
If I do ever shave I will have it done old school with a strait razor. Always wanted to feel what that was like.
srob7001 is offline   Reply With Quote
Old September 10th, 2014, 11:08 AM   #16
salcuta88
salcuta88's Avatar
@Apex , loved your video.
Glad to hear that more people are into safety double edge razors. Cheap blades and nice shave. Once in a while I'll use the electric if I'm lazy.
Old September 10th, 2014, 02:19 PM   #17
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
I just use the fusion 5 blades. They're expensive but I'm lazy and tired when I have to wake up in the morning so I shave in the shower with no mirror. I also use them for several months each before replacing a cartrige lol. Basically until the thing is straight up pulling the hair out.
I have to shave every day btw so I think my skin is used to it cause I don't use shaving cream either haha.
Old September 11th, 2014, 07:34 AM   #18
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
That's actually Damascus steel. About the best steel that can be found for swords, knives.....and razors. Is it old? or did you get it recently.
I use electric, but I can't use the screen type, I have to use a rotary. Lazy, mostly.
Worldtraveller is offline   Reply With Quote
Old September 11th, 2014, 08:51 AM   #19
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
My wife's razor lol
Old September 11th, 2014, 08:54 AM   #20
Originally Posted by sharky nrk View Post
My wife's razor lol
-5 man card points.
Old September 11th, 2014, 09:00 AM   #21
sharky nrk
sharky nrk's Avatar
-5 man card points.
not the way I see it, I mean why wouldn't you want to share your face with something that spends its time rubbed up against her inner thighs lol
Old September 11th, 2014, 11:59 AM   #22
LNasty
Daily Jap rider
LNasty's Avatar
This is my feeling on the subject, and I actually look kind of like him
Old September 11th, 2014, 01:19 PM   #23
Flying
Damascus steel doesn't exist anymore, if you're referring to the pattern made by Whiskey's razor. Today, we've been able to get sort of close by copying Japanese methods of folding steel over repeatedly to make swords and other edges.
My razor is just a typical forged-stamped blade made by a German manufacturer I can't recall.
Old September 11th, 2014, 01:26 PM   #24
Worldtraveller
Doesn't exist anymore? I've seen quite a few sword makers that still use it. It has to be etched to make the pattern show like that, if I recall correctly.
Old September 16th, 2014, 10:08 AM   #25
salcuta88
salcuta88's Avatar
Anyone does the No-Shave November??
Old September 16th, 2014, 05:17 PM   #26
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Are you referring to "Movember", where guys sport mustaches to raise awareness for prostate cancer?
No. No I don't. But it is for a good cause!
Old September 16th, 2014, 05:49 PM   #27
MrAtom
MOTM - July '15
:-P
Or should I say, :{P
Last futzed with by Alex; September 16th, 2014 at 05:57 PM. Reason: fixed video. just put the ID itself between the tags, not the entire URL.
Old September 16th, 2014, 06:26 PM   #28
verboten1
verboten1's Avatar
MOTM - June '15
harrys razor and shave cream
or on bike trips/lazy days, I have a 3 blade panasonic that is acceptable for a few days
Ride more, worry less.
Old September 22nd, 2014, 12:39 PM   #29
salcuta88
salcuta88's Avatar
My wife's razor lol
Since I upgraded to the DE Safety Razor, my wife adopted my old 5 blade Gillette Fusion.
Old September 22nd, 2014, 01:07 PM   #30
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I shave at home w a disposable 3 blade razor (gillette) once a week.
I go to an old school barber shop once a month and get hot towel and straight razor shave (smooth like a baby's ass).
Old October 23rd, 2014, 06:06 PM   #31
JohnnyBravo
Pinaud = after shave
I love the smell of bayrum, an I usually have some rose stuff around for "those" days
Old October 23rd, 2014, 10:11 PM   #32
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
Saftey razor, Astra Premium Platinum. Blades are cheap and sharp. Haven't experimented with other blades, but cartridge sucks in comparison.
oblivion007 is offline   Reply With Quote
Old October 24th, 2014, 07:40 AM   #33
Tennessee Budd
Tennessee Budd's Avatar
Motorcycle(s): '79 CX500, '78 GS1000, '82 CB900F, '04 EX250F
A lightsaber.
Tennessee Budd is offline   Reply With Quote
Old October 26th, 2014, 12:35 PM   #34
JohnnyBravo
I use German blades at the moment... Gonna break into the usa made ones if I ever run out of these, but they last too long ( in a good way! )
Old October 26th, 2014, 04:29 PM   #35
Jono
Jono's Avatar
I wish I could just grow a beard so I didn't have to shave.
Old October 27th, 2014, 03:39 PM   #36
JohnnyBravo
It's make one out of yarn, or buy one at the after Halloween sale
Old October 9th, 2016, 02:27 PM   #37
MrAtom
MOTM - July '15
I'm looking into getting a straight razor. I wanted to go to a barber shop and have 'em try it on me to see if my skin likes it but nobody in my area does that? I thought it was reasonably common. That said, I gotta go in blind. What can I expect to spend for a good straight razor? I already have a strop for my knives.
Old October 9th, 2016, 03:53 PM   #38
dcj13
Participant
dcj13's Avatar
Originally Posted by MrAtom View Post
I'm looking into getting a straight razor. I wanted to go to a barber shop and have 'em try it on me to see if my skin likes it but nobody in my area does that...
Is this a California thing? My local barbershop will do it.
Old October 10th, 2016, 05:29 AM   #39
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Originally Posted by Tennessee Budd View Post
A lightsaber.
BADASS
I usually just grab the hair on the top of my head and pull really hard... The beard and mustache just shrink back in pretty much.
http://img.photobucket.com/albums/v620/Ricejocky/achievement.easy.bake.Rifleman_zpscllv4ryl.png
Rifleman is offline   Reply With Quote
Old October 10th, 2016, 06:22 AM   #40
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
It depends, I prefer straight razor shaving. However, I can't shave with it on a regular basis so I change between it an an electric razor. My skin requires moisturizer to be able to straight razor shave, other wise I get ingrown hairs, but I have sensitive skin so to much moisturizer gives me the complexion of a pubescent boy.
Spoiler for topic:
It might just be the [you] tag
