Old April 11th, 2017, 08:42 AM   #1
sickopsycho
One ugly son of a gun.
Motorcycle(s): 2012 250
Buzzing on decel
Is this normal? My engine seems to have a pretty distinct buzz on deceleration, mostly on higher rpms. Wondered if this was normal or some sign that a bearing is going to give out or something. My engine only has 3k miles on it-
sickopsycho is offline   Reply With Quote
Old April 11th, 2017, 08:44 AM   #2
Are you sure it's the engine? My 250 has a couple minor buzzes at different speeds. One is the headlight shell vibrating.
Old April 11th, 2017, 09:46 AM   #3
sickopsycho
It kind of feels like its coming from the engine, but I suppose it could be elsewhere. I have all my plastic off right now and it's still there, but the headlight shell is still on. How would I go about finding out?
Old April 11th, 2017, 10:54 AM   #4
Our 2004 also had an annoying buzz in the front end at times. I'll check with my son, but it may have been something with the wire cover on the front brake line hitting the fender - or something in that area. Not sure if they still use that on your (newer) model though.
Considering you have the fairings off, it should be a lot easier to locate.
You may be able to slowly rev-up the engine and see if you can get the same frequency as you did on decel to recreate the buzzing in the garage.
Old April 11th, 2017, 11:07 AM   #5
Yeah, about all you can do is try feeling around when it's happening and see if pushing on different things stops it, all while trying to avoid running into a tree or something.
Old April 11th, 2017, 11:27 AM   #6
Clutch lever?
Old April 11th, 2017, 12:36 PM   #7
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Video will be really helpful in situations like this.
Riding it like I financed it.
Old April 11th, 2017, 12:57 PM   #8
sickopsycho
This is actually a really good idea, I didnt think of that. =)
This is what I was trying to aviod, lol. I went on a ride at lunch and was trying to grab the front end... but it's most prevelant in higher rpms so it gets a little hairy.
Clutch lever?
Do you mean the clutch lever is vibrating? I dont think so, my hand is on it- I would know. Now that you mention it, though, it seems like I'm only noticing it while I'm decelling in gear. If I pull the clutch, I dont think I notice it.
I would do this, but I dont think you'd hear it on the video. My new exhaust kind of drowns out the sound, but I can still feel it in the handlebars, my butt and the foot pegs.
Old April 11th, 2017, 02:34 PM   #9
If the chain is excessively loose, the top of it could be hitting the swingarm when the rear wheel is forcing the engine to rev up.
If not, I would verify torque of the three bolts and nuts clamping the engine against the frame.
Old April 11th, 2017, 03:33 PM   #10
Clutch lever?
That's what my son said also. I thought it was something else...
Old April 11th, 2017, 03:36 PM   #11
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
What kind of condition is your chain in?
Old April 11th, 2017, 04:15 PM   #12
CrazyCanuckGoat
Motorcycle(s): 2003 ZX12R (sold), 2012 250R, 1975 Honda XL250, 1980 XJ650
Yup........dry change = noise
CrazyCanuckGoat is offline   Reply With Quote
Old April 11th, 2017, 04:24 PM   #13
That's why I keep a quarter cup of grease in my pocket.
Old April 11th, 2017, 04:52 PM   #14
CrazyCanuckGoat
I found that out after a 1200km trip one day. For longer trips I bring my can of spray with me.
Moral of the story: Always take lube with you on trips
My bike also had a buzzy front fender at certain rpms from vibrating against the metal bracket underneath. Little bit of foam fixed that.
My front brake hose does make a noise as well in the retainer only on suspension oscillation.
You can quickley rule out the chain if you go for a ride and pull the clutch in and let the rpms drop. If the buzz is gone, then you are looking at engine/rpm related.
Old April 12th, 2017, 09:36 AM   #15
sickopsycho
My chain is loose, but not THAT loose. I would imagine I'd see evidence of it hitting up there, and I don't. I will verify the torque of the engine mount bolts- that's a good idea. I got the bike with ~1000 miles and I found 5 fairing screws that were missing already and a couple more that had become loose. I assume the PO never went through at 500 miles and checked everything for tightness. Those engine mount bolts could be backing out. That would certainly explain it. =)
This is a good point- I do need to tighten my chain- probably lube it too.
I double checked this. When I pull the clutch, the vibe is still there. Seems to be engine/rpm related.
Old April 12th, 2017, 11:17 AM   #16
(SNIP) When I pull the clutch, the vibe is still there. Seems to be engine/rpm related.
That would lead you to look at things effected by road speed and not engine speed as the engine would drop back to idle with the clutch in and coasting.
Old April 12th, 2017, 12:48 PM   #17
sickopsycho
Sorry- I wasnt clear in my response. When I pull the clutch, the vibration WAS still there but related to engine in the sense that once the RPMs dropped it went away. Regardless... it was the chain after all. Didn't realize it was as loose as it was. I was outside looking at it and when I push it up from underneath, it actually could touch the swingarm. I tightened the chain and the vibration is gone. Thanks for the good tips, guys! I still need to go over my engine mount bolts- even though I fixed the problem, they could still use a check.
Old April 12th, 2017, 07:40 PM   #18
Looks like DmbShn41 gets the win.
Old April 12th, 2017, 08:31 PM   #19
Yes, he does. I guess I'm not ashamed to say that I don't have experience with a loose chain causing odd noises. Andrew, I'm glad you found the problem!
Old April 13th, 2017, 07:09 AM   #20
sickopsycho
Well, obviously I didnt find it lol but i fixed it! =) Thanks guys!
My flasher is buzzing why Mikemsc21 New Members 13 January 31st, 2017 07:19 AM
Fuse removal and buzzing Jiggles 2013 - 2017 Ninja 300 Tech Talk 13 April 3rd, 2013 09:38 PM
Pop on decel... so what's changed? adouglas 2008 - 2012 Ninja 250R Tech Talk 23 March 21st, 2012 07:18 PM
decel+clutch+up shift at same time? n4v1n 2008 - 2012 Ninja 250R Tech Talk 10 October 18th, 2011 07:26 AM
bike gurus needed (popping on decel) sombo 1986 - 2007 Ninja 250R Tech Talk 21 February 23rd, 2011 10:35 AM
