August 5th, 2015, 12:52 PM | #1 |
Track Clown
MOTM - Sep '15
Cheap GPS mount
went to walmart and bought some corner braces.
Garmin GPS Step 1: Saw ball off GPS mount, keep square. Step 2: Put ball in bracket with square side out. Step 3: Drill on square patch using 1/16 drill bit, careful not going all the way through the bracket. Step 4: Use 1 corner brace with supplied screw and screw onto ball/bracket do not fully tighten. Step 5: put some super glue on brace and ball finish tightening. Step 6: Remove reservoir screw Step 7: place open square brace hole lined up with hole on reservoir and reassemble. |
August 5th, 2015, 01:03 PM | #2 |
GPS speed on the cheap | diablos991 | 2008 - 2012 Ninja 250R Farkles | 22 | May 10th, 2012 05:15 PM |
FS: New TomTom EASE GPS - very cheap | muffinman | Miscellaneous | 0 | October 24th, 2010 10:43 AM |
[tilted horizons] - Cheap Fix for GPS Shut-Down | Ninjette Newsbot | Motorcycling News | 0 | October 20th, 2010 11:10 AM |
Cheap Simple Garmin Nuvi 200W GPS Above Dash Mount | setasai | 2008 - 2012 Ninja 250R Farkles | 1 | July 26th, 2010 06:38 PM |
Ram Mount Gps Mount | Plasmatoast | 2008 - 2012 Ninja 250R Farkles | 5 | May 28th, 2010 03:42 PM |
