Old March 3rd, 2015, 01:19 PM   #1
wankerboy
Motorcycle(s): many
Will Newgen crankshaft fit in my pregen?
Anybody know if it will fit?
wankerboy is offline   Reply With Quote
Old March 3rd, 2015, 02:28 PM   #2
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Naw..most likely not.
The Bike | The Truck
Old March 3rd, 2015, 04:03 PM   #3
wankerboy
Motorcycle(s): many
Has anybody tried or just thinking it won't.
Old March 3rd, 2015, 05:35 PM   #4
cuong-nutz
cuong-nutz's Avatar
It should as long as everything is balanced with it. I'm just making an educated assumption.
HalfFast Racing Team
Old March 4th, 2015, 12:24 PM   #5
ninjunk
Lostcause enthusiast
Motorcycle(s): 2000 EX250F
afaik, the bottom end wasn't changed between years. Obviously you mean a J/K model as opposed to a F model. The 'pregen/newgen' thing is pretty ambiguous.
not sure how well these are balanced from the factory but i'd be sure that you either use the pistons and rods that come with the crank, or get them balanced.
start by checking the part numbers, did ya do that yet?
ninjunk is offline   Reply With Quote
Old March 4th, 2015, 04:23 PM   #6
Obviously you don't see which section this is in.
Obviously. also, I'm not sure that the bottom end comes as a kitwith crank+rods+Pistons like with 2-stroke dirt bikes. This may have to be done with individual parts rather than a kit.
OP, if you're asking questions like this, I hope you know what you're doing. If you know what you're doing before asking questions like this, you should know enough to go forth and do it. Bruce(random set of numbers) has done a stroker setup on his newgen using internal engine parts from the 300. He might be your best bet as a reference point, but I'm not sure how familiar he is with the internals of the pregen.
Old March 4th, 2015, 04:31 PM   #7
i've heard the pregen and newgens use the same crank and rods but the 300 is stroked out. different heads though.
Old March 4th, 2015, 07:13 PM   #8
micoulisninja
modaholic junkie
Bottom end is identical for the pregen and newgen models(as well as other models such as the ZZR250, Gpz250, eliminator etc)...the crank is internally balanced (which means by itself first, then with other moving parts) and a swap can be made...however the pistons are different on the newgen (lower dome resulting in lower compression)
major difference is head design, carb size, front engine mounts, some electric stuff etc...
for increased reliability I would suggest a whole lower bottom transplant if a whole engine is off your financial potential because all the measuring, unbolting, cleaning and bolting back + gaskets, seals, new rod bolts (imperative to use new ones) etc stuff will eventually cost pretty much the same...
I must assure you that going for the 300 bottom will give a nice performance boost but takes a lot of work and knowledge to fit with either the pregen or the newgen 250 head and apart from that keep in mind its chambers and other (mechanical) parts have been designed to work with FI delivery...the 250 are more "indifferent" to that factor...
Old March 4th, 2015, 07:27 PM   #9
i wonder has anyone thrown pregen pistons on a newgen bottom/head combo? does it fit and clear? would this be an "easy" compression increase? i wonder which would gain more CR, thinner gasket or pregen dome piston?
Old March 5th, 2015, 06:25 AM   #10
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Never thought about it. But I think the crank and rods would work. The Pistons are different. BUT they might be good for a turbo. They should drop compresson. I will check that. They are cast so it would not be a good idea just a cheap idea
Worlds fastest 250 ninja
Old March 5th, 2015, 06:37 AM   #11
micoulisninja
modaholic junkie
Alex it is impossible to use a thinner head gasket on either of them...
it is a very thin 0,15mm single layer of metal....
So there are 3 ways to increase compression
a) head milling (which will also bring valves closer to pistons)
b) removing base gasket and use special gasket sealant in its place (which will decrease squish band, that is head to piston clearance and valve-to-piston clearance and practically change the whole shape of the combustion chamber)
c) switch to "plug and play" pistons from newgen to pregen or even better to zzr250's which are optimum for that case and cheap...
stock pistons are always cast...have been proved good enough for low-level natural aspirated mods and comparing newgen to pregen, the later are better if looking for increased performance
a couple of things to keep in mind...
1)when splitting a head from the rest of the engine, a minor milling process must take place for proper surface mating when placing back
2)pistons of higher dome do not have the best flame travel characteristics and require extra advance timing which -in theory- leads to requirements of higher grade of fuel to save from pinging and increased levels of heat on the top of the piston dome
on my previous 250 FI engine I had a combo of all of the above for a base CR of 13,9:1
so I had the ignition curve altered and monitored constantly AFR values which is imperative when practicing such extremes...
Old March 5th, 2015, 06:38 AM   #12
garth285
KAWASAKI GURU
garth285's Avatar
Just a little info:
The 83-87 has 12.0:1 compression
The 88-07 has 12.4:1 compression
The 08-12 has 11.6:1 compression
The piston pin is the same from 88-12
Old March 5th, 2015, 06:46 AM   #13
micoulisninja
modaholic junkie
Originally Posted by garth285 View Post
Just a little info:
that is indeed accurate, Shawn !
Old March 5th, 2015, 07:01 AM   #14
Racer x
Racer x's Avatar
The compresson ratio is determined by piston shape AND head shape. The first gen head has bigger valves and I funny shape around them. The Pistons are pretty flat compaired to new gen. I am headed out to the shop to check this out.
I cut .010 off the top of the block. I did not want to remove anything from the head as this will go toward the combustion chamber. The head has a 019 service limit, so taking half that from te block worked great. Best thing is JE Pistons
Old March 5th, 2015, 07:16 AM   #15
Racer x
Racer x's Avatar
This is a old don't know the year I suspect 80s-90s on the left and a 2008 on the right. Notice the edges are tight on the older head.
Old March 5th, 2015, 07:31 AM   #16
Racer x
Racer x's Avatar
The old on the left has large pronounced valve reliefs. The lack of material around the side would lower pressure but I think it would make strange squish areas
Old March 5th, 2015, 03:39 PM   #17
ninjunk
point taken.
so are we calling 2013 to present 'new-er gen'
we're going to be in a real pickle if they redesign it again and we have a 'new new gen' and an 'old new gen' ... or does the J model become 'new pregen'?
Old March 5th, 2015, 04:17 PM   #18
wankerboy
Motorcycle(s): many
Thanks for all the info guys, just go by Gen 1, 2 and 300 done should be easy to remember.
Does the newgen water pump fit the pregen bike? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 6 August 25th, 2013 09:49 PM
NewGen rear brake pedal fit on PreGen? lolibater 1986 - 2007 Ninja 250R Tech Talk 11 September 30th, 2012 09:38 PM
Pregen vs. Newgen ambudriver General Motorcycling Discussion 7 May 7th, 2011 07:36 PM
Pregen kickstand fit on a newgen? demp 2008 - 2012 Ninja 250R Tech Talk 0 February 11th, 2011 07:20 AM
PreGen Shock..fit NewGen? gamma500 2008 - 2012 Ninja 250R Tech Talk 13 October 19th, 2009 10:12 AM
