Old July 15th, 2011, 08:00 PM   #1
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
My temp and oil light came on??
So today I was sitting at a light between two cars going to make a left (two left turn lanes) when the light turned green I ripped around the corner and didnt shift until I straightened back out, at which point I was just about to rit redline. Shifted to second and used that gear till ~11k ~12k, then had to slam on the brakes because the next light just changed to yellow and I knew I wasnt going to make it. I used all my front brake and it skipped a little (no big deal, its happed many of times) when I looked down at my gauges I noticed both lights were on just for a second or two. My only though was all the oil shifted to the front of the bike because of the stop? I really dont think the bike was actually over heating because it wasnt that hot out and I've been much harder on her before. What do you guys think
sorry for the long post!!
Long story short, I used only the front brake really hard, came to a stop and the temp light and oil light came on for a second or two
----> My Youtube! <----
Old July 15th, 2011, 08:10 PM   #2
Happens with the oil light from time to time under hard stops. Check your oil level just to confirm it's up where it needs to be, but it's likely fine. Don't know why the temp light would come on as well though, I can't remember seeing that.
Old July 15th, 2011, 08:10 PM   #3
/moved to new-gen tech
Old July 15th, 2011, 08:14 PM   #4
Kevin2109
KThanksBye
Kevin2109's Avatar
Thanks oh and oil was changed less then 1000 ago
And yeah, the temp light was the only thing that caught me off gaurd
Posted via Mobile Device
Old July 15th, 2011, 08:56 PM   #5
bdavison
Wartown, USA
bdavison's Avatar
Normally when you start the bike the lights come on, and they also come on if you hit the kill switch and stop the engine with the key still on. Im thinking when you hit the breaks, the engine stuttered, and it sent the signal to light em up.
Old July 15th, 2011, 09:02 PM   #6
Kevin2109
KThanksBye
Kevin2109's Avatar
Clutch was fully in
Old July 15th, 2011, 11:15 PM   #7
dang kevin, speed racer
one time i had to e-brake to avoid a truck cutting me off and it stoppied a bit... it threw all kinds of lights at me but they went away... didn't seem to do anything. when i first had her i mucked up a shift into 2rd pretty bad and it did the same thing... i think as long as they turn back off its fine...
i mean... your bikes screwed, you're better off bring it to me for... retraining. :-P
Old July 16th, 2011, 10:48 AM   #8
adri99an
adri99an's Avatar
Motorcycle(s): "Is that a Ninjer 1000?"
GLAD- you're bike is back to normal!!!
I cannot believe ALEX not Alex S responded to your cry for help! You are a lucky man my friend. These days Alex rarely says anything to me- and we used to be such great friends. Say c'est la vie.... Man I miss that guy....good times Kevin good times....
adri99an is offline   Reply With Quote
Old July 16th, 2011, 10:50 AM   #9
Someone needs a hug.
Old July 16th, 2011, 10:51 AM   #10
HKr1
IC2(SW)
HKr1's Avatar
Been talked about before, its normal. Temp light is wired thru with the oil pressure switch. Poor mans way of a bulb check when key is first turned on.
Old July 16th, 2011, 10:53 AM   #11
adri99an
adri99an's Avatar
Just one of these is fine.....
Old July 17th, 2011, 01:07 AM   #12
Thx Kerry, you're right, it is already up in threads like these. I must have missed them the first time around.
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
oil temp vs coolant temp cuong-nutz General Motorcycling Discussion 11 January 23rd, 2013 05:44 PM
Oil and Water Temp Agger 2008 - 2012 Ninja 250R Tech Talk 2 March 18th, 2012 07:12 PM
Oil and Temp light on after low side dznuts 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2011 05:57 AM
Oil & Temp light staying on longer at start-up headshrink 2008 - 2012 Ninja 250R Tech Talk 5 June 19th, 2009 01:24 AM
