Old April 24th, 2020, 04:55 AM   #1
NinjaNelly
NinjaNelly
Motorcycle(s): 12 ninja 250, 74 Honda cb360
Slight idle issue
Hey guys, so i recently installed a k&n air filter and a slip on exhaust and When i took the bike out it was even more gutless than usual but i did some research on this forum and some others and found that shimming the needles should help my problem out quite a bit so yesterday i shimmed each needle with 2 washers 0.020 in thickness and the bike ran amazingly very responsive in the midrange and throughout with no power loss the only thing is now the bike comes back to idle very slowly and sometimes will jump around down there between 1.2k to 1.5 any ideas guys?
NinjaNelly is offline   Reply With Quote
Old April 24th, 2020, 05:48 AM   #2
That normally points to either an air leak or a too-lean idle setting. If you're sure the carbs are seated in the rubber boots and the boots aren't cracked and leaking, see if an idle mixture adjustment cures it. Adjust the idle mixture screws for the highest idle speed.
Welcome to the board, Nelson!
Old April 24th, 2020, 06:50 AM   #3
ducatiman
ducatiman's Avatar
@Triple Jim right on the money, pilot screw adjust next on the hit parade
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 24th, 2020, 06:56 AM   #4
As TJ and ducatiman suggested - adjust your idle mixture screws.
Old April 24th, 2020, 11:28 AM   #5
NinjaNelly
NinjaNelly
Ok Im sure i dont have an air leak and i know the boots and slides are in good condition so i will give this a try tonight and let y’all know the outcome thank you all very much for the info and thanks for the welcome glad to be apart of this great community!!
Old April 24th, 2020, 12:33 PM   #6
The general idea for setting the Idle Mixture screws is to get the highest hot idle speed as possible, even if both adjustments are not set exactly the same. Syncing the carbs is a good idea as well.
After getting the highest idle speed, I personally like to go about 1/8-turn out/richer, which seems to help smooth the transition to part-throttle metering.
Old April 28th, 2020, 02:37 PM   #7
NinjaNelly
NinjaNelly
Hey guys so after drilling out those damn plugs that cover the idle mixture screws from factory and adjusting them as stated above by all of you i must say my idle issue has disappeared and the bike runs great now thank you all for your help!, and if i have anymore issues in the future i know where to go!
Old April 29th, 2020, 06:29 AM   #8
Good to hear!
Seems they set them randomly from the factory.
As temps fluctuate you may need to make slight adjustments. Colder temps require a richer (more turns out) setting than warmer temps.
Always make your adjustments on a hot engine. You'll get good at keeping your hands off of the hot case as you make the adjustment. A properly sized screwdriver helps.
Old May 9th, 2020, 01:55 AM   #9
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Originally Posted by jkv45 View Post
Good to hear!
For me they were set at 1 1/2 left and 1 1/4 right from factory. ��
I need help with idle issue blanzer 1986 - 2007 Ninja 250R Tech Talk 9 April 6th, 2020 06:20 AM
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
Just noticed a slight issue with my tail light, need some advice. beta7 2008 - 2012 Ninja 250R Tech Talk 7 July 9th, 2013 06:43 PM
idle issue PEN25 1986 - 2007 Ninja 250R Tech Talk 10 June 30th, 2013 02:14 PM
slight choke cable issue scorpio_vette 1986 - 2007 Ninja 250R Tech Talk 6 July 20th, 2009 11:43 AM
