#1 |
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Posts: 121
Got a bike! Now what?!
I finally picked me up a 250!
![]() 1. The right side fairing is trashed. (She laid it down once and dropped it once) I'm going to have to replace it. I've been looking on eBay for an used one. There's a couple of green ones, but not blue! 2. The turn signals are out of it. The black pieces that hold them are there and the wire, but the light and lens are gone. Can I buy just the lens and bulb or do I have to buy the whole assembly? 3. The chick I bought it from was pretty short so she had it lowered. She said she took it somewhere, 'and they used some wrenches and lowered it..' She pointed to something under the seat and said she thought it had something to do with it. But it is pretty low. The rear tire has rubbed a hole in the lining above it. It doesn't rub with me on it, but it's close. How do I raise it back up???? 4. She said it sat for a year ( which I believe from the build up of dust on it). It fired right up fine, but after it warmed up, I cranked the throttle and it bogged down for a bit then caught up. One time it completely stalled. This was while it was in neutral. Or if I slowly turned the throttle, like 2-3000 rpm it was like bogging down, then it was fine. It didn't do it when I was taking off in first gear. It was fine. I'm thinking maybe the carb needs cleaned? 5. The rear brake is really weak. It has pad left, but when you hit the rear brake, the piston just barely moves. It's almost like it needs bled. I might try that to see if it works. Just seems like no pressure. Any ideas? 6. She said someone told her she may need to pull a link out of the chain? ![]() It needs a few things, but it gives me something to do while I get my gear together! Any other suggestions or recommendations? |
#2 |
Gunna need a new fairing or to get it to someone with serious talent with fiberglass. But a new one is gunna be faster and cheaper
Get some flush mounts or flush mounts are easy to make from the stock parts from other bikes. Maybe someone has a set of stockers from a race build. Raise it back up! Either via the adjustable links or stock bones. I will have a set for sale soon. Put the stock shock preload on position 2 or 3 then adjust for your comfort. You can try some seafoam but since you have time..... might as well take em off and clean em up, shim the needles and desnorkle. Bleed them and check for glazing. Just clean and lube the chain, adjust to proper slack. If it will not adjust to proper slack and your can't pull it back any farther, then yea, a line or two may be removed. Change all fluids, pull the fairings off and check every bolt/nut/screw you can get a tool on. Then spit shine. Oh! Gratz too. EDIT: I might be able to help you out fixin' stuff since you are relatively close. I work for beer and pizza. lol
#3 |
Join Date: Jan 2009 Motorcycle(s): '13 Ninja 300 '09 Boulevard C50. '08 250r(TOTALED BY DEER) Posts: 467
^^ What he said ^^
and congratz on the new bike.
#4 |
IMHO, just suck it up and get a new fairing piece. It's going to be hell trying to get a glass job to look like anything but a disaster. False economy.
Definitely raise it back up BUT don't do just one end at a time, because that will affect the bike's handling (and not necessarily in a good way). The "thing she pointed to under the seat" is, assuming she was pointing at the right thing, a lowering link. It alters the suspension geometry on the back end, allowing the bike to sit lower. Some are adjustable, some are not. If adjustable you may be able to raise it back up using those pieces. If not you'll need a stock link (also sometimes called "dog bones" because that's what they look like). To do this you're going to need to support the bike so you can take the shock linkage apart. On the front end you simply loosen all the fork tube clamps and slide the forks back down to stock position. However, given that the stock handle bars are still on the bike, she may never have lowered the front (on a Ninjette, unlike many other bikes, the handlebars cover the top of the fork tubes which makes it pretty much impossible to lower the front end unless you also add risers or switch to clipons). If that's true, the altered handling with the rear lowered and the front not might possibly have contributed to her accident. I agree about the carbs… sea foam or other good carb cleaner should do you fine for now. You'll get better performance if you do take out the carbs and do as csmith suggested. You'll get MUCH better performance (assuming you've got the money) if you also install an AreaP full exhaust and jet kit. If you're going to pull the carbs anyway, might as well do it up right! ![]()
#5 | |
#6 | |
#7 |
congrats! i picked mines up 2weeks ago only driven it twice but im looking forward to riding again. I got lucky and found a red nose i was looking for got it used for $100 still looking for a right side fairing in red :/ seems like its going to be hard to find.
#8 | ||
#9 |
We can make a play date Darryl. lol PM me your schedule for the next few weeks and we can work something out.
Until then, you can research ask questions, give the bike a good look through and cleaning. I play it safe when washing the bike with the fairings off and use the hose with my finger over the opening to control water pressure when I need more than just water flow. With the fairings on, I use the wife's spray attachment, it's pretty good pressure but not as much as the car wash or pressure washer. BUT... nothing beats a good hand washing with a soft cloth, rinse and wax. Remember, no tire shine playa. ![]() If we can get together soon, I will answer all your questions as we go through your issues and hopefully I will not find any new ones. I will keep an eye out for a fairing for you too. Welcome to the happy world of bike ownership.
#10 | |
#11 |
Nice job Chris!!
Darryl, congrats on the bike! You're in good hands with Chris. ![]() ![]() |
#12 |
You'ins aint gunna be makin' fun of a right fine southern gentleman are yous? Yes sir, I gots me a strong southern draw, quick hillbilly whit and redneck way of doin' stuff. But I aint havin' it any udder ways, ya hear.
#13 | ||
#14 |
I know what you mean. I just got back from a trip to Lexington, KY. I had such a blast chatting with locals and checking out the town. I wish everyone was as pleasant and welcoming as people in Lexington. I really want to move south after college.
#15 |
I be fixin' it up for ya.
#16 | |
Hahahaha moonpies... the peanut butter ones are awesome! I just figured out what that 'thing' was the chick was pointing to under the seat.. It is the shock lol. I just pulled the right side fairing and could see it a lot better. The preload is set on 2. I'm guessing these are the dog bones? And what is this rubber hose hanging down? Looks like it goes into the top left of the tank... Ventilation? |
#17 |
Those are the aftermarket dog bones. They are at the lowest setting now. You can raise to the "3rd hole" until you got the stock pieces back, for some much needed clearance. Probably want someone to sit on the bike as you do this, to relieve the pressure.
The hose is ventilation/overflow. (I honestly don't remember if it was fuel tank or airbox) If she gave you the stock tool kit, there is a spanner wrench for adjusting the shock to your preference.
#18 |
No, those are actually on the highest setting. Longer dogbones = lower rear, shorter dogbones = higher rear.
dwright0723, I go to school at Ohio Northern University, but when I'm at school, I only bring my cage. So the motorcycle and I are a good ways from you. We're in between Cleveland and Akron for the summers. |
#19 |
Young Gun
Join Date: Feb 2010 Motorcycle(s): 2008 Passion Red Kawasaki Ninja 250 Posts: 5
One the subject of the fairing, make sure you get the right color. 2008 is Candy Plasma Blue as opposed to 09 (and i think 10) Candy Thunder Blue. Plasma blue is the best looking though, good choice on the bike!
#20 |
I did not know that, was just trying to decipher the picture and the fact that components were rubbing.
#21 |
No biggie!
The rear tire is rubbing because the bike is lowered. Temporarily you can try adding preload to get the bike to use less of the shock's travel, but it might make the ride a little hard. |
#22 | ||||
![]() ![]() Quote:
![]() Got the right side fairing off. Guess I'll keep it in case i need the heat shield off of it. Then I bled the brakes and that fixed that problem! How the hell do you get that much air in the lines?! Like the first 3 times I opened the bleeder I got air! I went and picked up some Rotella T6 5w-40, a fram filter, and plug earlier.. Should I run some Seafoam through the oil before I change it? I think i'll try to get the carbs removed after that.. I'm having fun and learning.. |
#23 | |
Join Date: Apr 2013 Motorcycle(s): 2011 Ninja 250r SE Posts: 61
#24 |
Join Date: Oct 2011 Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT Posts: 434
valve adjust?
Taker your time and go through the bike. While you have fairings off pull the tank and valve cover and check valve lash settings. I have a pre gen which I am told is easier to set.
Someone on here will have an 08+ and be able to advise on properly setting valves, synching carbs etc. Change fluids(coolant, oil/filter) and you're good to go!
wardie ![]() |
#25 | |
And yea, I keep all fairing parts, even the broken bits. My friend Kevin is a miracle worker with fairings. Like I was saying in a pm to you, if you would have had all the pieces to your current fairing, there would be a good chance he could put it back together. Yep, he is that good. I have been trying to get him to make molds for ninja's as a side job but he wont. He likes to sculpt the broken areas by hand and likes the variety of the different fairings on different bikes. You can buy new heat shielding at pep boys and cut it to the shape you need.
#26 | |
#27 |
Fast-Guy wannabe
MOTM - Jan '13
#28 |
Yes you can.
#29 |
#30 | |
No problem buddy! I'm having fun with it. At least now I know! I pulled the seat and tank today to get to the carb, and in my fuel line, it looked looks like there is a ziptie in there. Is that in there to keep it from collapsing or is it not supposed to be there? Also there was a nipple on the edge of the unit that the fuel gauge is connect to on the bottom of the fuel tank that wasn't connected to anything. Is that supposed to be like that? Last futzed with by dwright0723; June 17th, 2013 at 08:07 PM. Reason: Forgot something! |
#31 | |
Yes, sir. Nothing connects there.
#32 | |
#33 |
I pulled carbs and they were actually really clean inside.. No build up at all. I guess the plugs look ok.. Maybe a little rich?
Air filter looked like crap though. definitely going to replace that. What else would cause it to bog down around 2-3000 rpm when giving it lots of gas or rolling on very slowly... It only seems to do it while it was in neutral. It was fine when I rode it. It did sputter a little bit when I first test drive it, but I figured that was because it was cold. It didn't do it anymore beyond the initial first minute or so. Maybe the gas is crap? ![]() |
#34 |
Got everything back together and fired it back up.. It seems like it's fine if you moderately twist on the throttle, but it still bogs down if you crank the throttle hard. Also if you moderately give it throttle, it's fine till about 4000 rpm, then it starts bog down and sputter. If you give it more throttle while this is happening, it stalls out. Could it be getting too much fuel?
#35 |
Join Date: May 2013 Motorcycle(s): 2009 Ninja 250 Posts: 8
Hey Im from DAYTON too!!! haha north of down town actually
man i saw that thing on craigslist... i hope you didnt pay much for that... it looked trashed to me I was thinking about buyiung it... I wish i would have known you were in the market I just put my 2009 blue 250 on craigslist... bought it with mismatched tank and fender, its all blue and looking sexy! haha good deal on the purchse though! your bog down problem mine did the same thing, I changed the plugs in it and ran seafoam, then 100 miles later changed the plugs again along with an air filter... runs great now! if you're not letting it warm up enough it will bog down and stall, I know i let mine idle in the drive way for 5 minutes or longer than take it easy on it and it will still bog down till its completely warmed up... then once shes fully warmed up it runs flawless!!! |
#36 |
check your ilde postion adjustment... i know mine was idling at 2000 rpm then once I adjusted it down to 1200-1400 rpm and that seemed to help alot
#37 | ||
I'm wondering if maybe it just needs to be ran ![]() |
#38 |
Think I figured out my issue with the the bogging.. I adjusted my idle from 1300ish rpm to 14-1500 ish. Not sure if it was the problem or if I just masked it.
#39 | |
Fast-Guy wannabe
MOTM - Jan '13
#40 |
[motorcycledaily.com] - MD Bike of the Year: KTM 1190 Adventure (Bike Reports) (News) | Ninjette Newsbot | Motorcycling News | 0 | December 28th, 2014 06:50 PM |
[motorcycle-usa.com] - Harley Bike Week Ride-In Bike Show 2014 | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2014 12:10 PM |
[topix.net] - Honda Chopper Bike: A futuristic bike to complement the personality of | Ninjette Newsbot | Motorcycling News | 0 | November 29th, 2011 02:40 PM |
[superbikeplanet.com] - Finally a Bike That Fits Him? Sic Tests 1000cc Honda GP Bike | Ninjette Newsbot | Motorcycling News | 0 | October 4th, 2011 06:40 AM |
[roadracingworld.com] - Harley-Davidson Bringing 70-Bike Demo Fleet To Daytona Bike W | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2010 01:00 PM |
