Old October 5th, 2009, 09:15 AM   #1
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Has anyone completely removed their Evap Canister?
Thought I'd tinker with the bike a little: I took out the Evap canister off my Honda CBR600RR so I got to thinking, "Why not the 250?"
Looking at the lines, it just didn't make sense to me because the newer & older 250 engines are basically the same. But the older 250s didn't have the evap.
So, I took off the evap, plugged 3 lines and I'm hoping for the best. Sucker weighs a ton and there's a lot of junk.
Old October 5th, 2009, 09:26 AM   #2
cifex
cifex's Avatar
Motorcycle(s): 2009 Ninja 250R (sold)
cifex is offline   Reply With Quote
Old October 5th, 2009, 09:29 AM   #3
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Originally Posted by cifex View Post
Why is ?
Don't you know what your evap looks like? If not, I guess you have something to do today, don't you?
Old October 5th, 2009, 10:32 AM   #4
cifex
cifex's Avatar
Guilty......but I wouldn't have something to do if this thread had pics!
Old October 5th, 2009, 10:35 AM   #5
I believe you need to leave one of those lines vented (can't remember which one) or the bike will stall from fuel starvation when run at high speeds for a length of time. If that happens to you, in the meantime, pop the gas tank cover open and the bike will run for a while until it starves out of fuel again. PM Vex to see which line you need to vent.
Old October 5th, 2009, 10:50 AM   #6
cifex
cifex's Avatar
I see. I Google'd it. What's the benefit aside from the loss of 2-3lbs? My boat used to be like that, periodically I'd have to unscrew the tank cap a bit to let some pressure in.
Old October 5th, 2009, 11:04 AM   #7
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Did vex remove his canister too? I'll ask him. Thx!
Posted via Mobile Device
Old October 5th, 2009, 11:05 AM   #8
Yes, he did.
Old October 5th, 2009, 11:16 AM   #9
HKr1
IC2(SW)
HKr1's Avatar
4 Lines to deal with on the evap. Think they were all plugged off but #2, it was vented.
Good idea to check with vex thou, Iam just going by my old memory.......
Old October 5th, 2009, 11:24 AM   #10
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
The only line I left unplugged is the overflow gas line from the gas tank.
Posted via Mobile Device. I'll post a pic later
Old October 5th, 2009, 11:28 AM   #11
http://www.kawiforums.com/ninja-250r...s-08-250r.html
start w/ post #29
Old October 5th, 2009, 12:02 PM   #12
randomwalk101
self wrencher
randomwalk101's Avatar
Must be a Cali model only thing?
Old October 5th, 2009, 12:14 PM   #13
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Thx KKim.
Looks like I was on the right trail. And based on my educated hypothesis I plugged and unplugged the correct lines.
Old October 5th, 2009, 12:28 PM   #14
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Yanked mine a long time ago. No problems whatsoever.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old October 5th, 2009, 12:31 PM   #15
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Did you plug/unplug exactly the same?
I just want to make sure I'm doing this right.
Old October 5th, 2009, 04:33 PM   #16
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
yes
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old October 5th, 2009, 04:47 PM   #17
Hedge36
SooperChikkin.
Hedge36's Avatar
Motorcycle(s): BMW R1200GS Adventure, '07 250 Ninja
The biggest danger in mistakenly plugging the tank vent is that - in extreme circumstances - you can create such a vacuum as to partially collapse the tank itself.
Don't ask me how I know this
With the canister still installed, a lot of times if you really top off the tank, you can vent into the charcoal bucket and flood it - rendering it useless for environmental purposes and making your bike run like crap, if at all.
Hedge36 is offline   Reply With Quote
Old October 6th, 2009, 08:09 AM   #18
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I did a test run yesterday and man did the bike feel better. Strangely, the throttle response felt smoother. And the exhaust note sounded different. Different in the sense that the exhaust notes were closer than further apart. It's hard for me to explain but know that the bike felt better.
I'm lovin' it!
Old June 17th, 2020, 05:49 PM   #19
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
What will it do to your Cats when you delete the Evap Canister?
arthury is offline   Reply With Quote
Old June 17th, 2020, 06:40 PM   #20
ducatiman
ducatiman's Avatar
coincidentally....some similar "leftovers" here after doing a recent Ducati service
Junk created a serious impediment to service access.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 17th, 2020, 06:46 PM   #21
arthury
arthury's Avatar
coincidentally....some "leftovers" here after doing a recent Ducati service
I'd like to delete mine, too.
Old June 17th, 2020, 07:03 PM   #22
ducatiman
ducatiman's Avatar
perhaps member @DannoXYZ will chime in. I'm sure he's done a few and will provide accurate info on ramifications (if any) on the ninjette.
Though different application...too late for me (sorry Greta )
calling member @danno, come in @danno
Custom Carb Service
Old June 18th, 2020, 09:22 AM   #23
HI ducatiman!!!
Nothing, if anything it would make your cats last longer. Here's how the EVAP works:
1. when sitting, petrol in gas-tank evaporates naturally. Actual amount will vary depending upon ambient temp and humidity. Normally, this evaporated petrol just vents to atmosphere, typically through gas-cap and drain hose. On warm days when you walk into garage, faint smell of petrol is this vapour evaporated from tank.
2. EVAP system provides vent-path for evaporated petrol and collects and condenses it into canister. This is additional hose-nipple coming out of tank. It's actually connected to inside of tank rather than outside under gas-cap like drain hose.
3. EVAP canister is connected to air-box through vacuum-operated purge valve. This valve is normally closed, at idle and low-load operations with low vacuum.
4. Under high-load/high-rpm when there's higher vacuum in intake. This vacuum activates purge-valve and opens pathway from EVAP canister to airbox (which also has vacuum). More modern systems use electronics and ECU to activate purge-valve.
5. Vacuum in air-box suck out collected petrol from EVAP canister.
It's nifty system that recycles petrol that would normally be lost through evaporation and less of it ends up as smog in our atmosphere causing all sorts of issues. Rates of asthma in kids has skyrocketed in past couple decades, wonder if it's related?
Anyway, removing EVAP canister will result in lower AFR (leaner mixtures under high-load). Leaner mixtures means LESS unburnt fuel hitting your catalytic, and it would run at lower-tempertures and last longer.
Another related system is PAIR which pumps extra air into your exhaust to help cat burn up excess petrol.
Removing both would result in no changes to your bike's operation, just more polution in air. Although factory jetting for high-load is super-rich, more than 10:1 AFR. So leaning out mixtures would actually give you more power (max-HP occurs at 13.5:1 on NA engines). I'm not sure of actual amounts contributed by EVAP canister, but I don't think it's enough to actually be measureable in engine-output.
Evap Removal.. Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 2 September 2nd, 2014 03:24 PM
Evap line full of fuel headshrink 2008 - 2012 Ninja 250R Tech Talk 10 June 18th, 2010 07:44 PM
