Old April 10th, 2013, 02:27 PM   #1
AGFE0914
AGFE0914's Avatar
2001 Ninja 250 - Won't start
Sat all winter, just put new battery in and it won't start. Any suggestions on what it might be? It was runnig fine last year, I'm so sad.
AGFE0914 is offline   Reply With Quote
Old April 10th, 2013, 02:36 PM   #2
quarterliter
Motorcycle(s): 2004 Ninja 250
Did you drain the gas out of the carburetors? Or put any stabil or seafoam in the gas? If not chances are you need to remove the carbs and clean them. And the gas in the tank is junk so you need to drain it and get some new stuff. 87 octane w/o ethanol is the best.
Old April 10th, 2013, 02:48 PM   #3
DaBlue1
DaBlue1's Avatar
Old April 10th, 2013, 04:42 PM   #4
AGFE0914
AGFE0914's Avatar
Thanks! Going to take it to the shop tomorrow so I can get it tuned up since I haven't done anything to it since I got it.
Old April 10th, 2013, 04:49 PM   #5
quarterliter
aghhh the stealership.....you should try doing it yourself. Its not bad at all. Just a little time consuming.
Old April 11th, 2013, 10:46 AM   #6
quicklooker
Motorcycle(s): Ninja 250R '07
I second doing it yourself. It's not as bad as you might think. I've cleaned an extra pair of carbs just for fun once.
The stealership will charge you upwards of $150 to clean it out. I don't think it's worth even $50.
quicklooker is offline   Reply With Quote
Old April 11th, 2013, 10:47 AM   #7
AGFE0914
AGFE0914's Avatar
The only thing is it is raining, I don't have a garage and I don't have that much time and I am in need of a tune up anyway.
I really want to get to know my bike and be able to fix these things myself but at the same time I want to ride ASAP and think taking it to a shop would make me get on quicker.
Old April 11th, 2013, 10:55 AM   #8
Lychee
sail away
Lychee's Avatar
have you tried a bump start? Just to be sure the "new" battery is actually charged.
Old April 11th, 2013, 11:02 AM   #9
quicklooker
I don't blame ya and can totally understand your position. I would just take it then if you don't mind the cost.
Old April 11th, 2013, 11:10 AM   #10
aeroblade
Doh!
aeroblade's Avatar
Can you hear the starting motor churn when you press the start button? If no, then dead battery or faulty wiring, if yes, then as many have already pointed it out to you, your carbs need cleaning.
aeroblade is offline   Reply With Quote
Old April 11th, 2013, 11:31 AM   #11
AGFE0914
AGFE0914's Avatar
Think it's the carbs, the battery is brand new fully charged. IT sounds like it wants to start, I feel so sad when she doesn't make it.
Like my baby is choking
Old April 11th, 2013, 11:39 AM   #12
AGFE0914
AGFE0914's Avatar
I'm rich so money is nothing I'm sooooooo joking right now.
I am more excited about getting on my bike and practicing A.S.A.P. so I am paying for the convenience and accept that I will be getting raped vs. being smart and doing it myself
Old April 11th, 2013, 11:42 AM   #13
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
B/f, isn't that what they are for?
Old April 11th, 2013, 12:04 PM   #14
AGFE0914
AGFE0914's Avatar
My fiance is new to bikes too and isn't feeling this weather. Now if it was a car different story.
Old April 11th, 2013, 12:07 PM   #15
CC Cowboy
CC Cowboy's Avatar
Change that to financier and problem solved.
Old April 11th, 2013, 01:41 PM   #16
SemperFudge
SemperFudge's Avatar
Motorcycle(s): 2001 Ninja 250R
my 01 ninja sat for 4 months with 6 month old gas (albeit with techron), accidentally left the petcock on, and not trickle charged or covered with a tarp and it started up like a champ.
i want to say dirty carbs its unlikely. i feel that the engine may not be getting fuel.
View my log here.
you can tell a lot about how it was treated by how the previous owner looks - Joshorilla
SemperFudge is offline   Reply With Quote
Old April 11th, 2013, 02:45 PM   #17
AGFE0914
AGFE0914's Avatar
Thanks Paul. Only time will tell....and I am hoping that means I will know what's going, have it fixed, and riding be in the next few days.
Old April 11th, 2013, 02:46 PM   #18
AGFE0914
AGFE0914's Avatar
New battery - fully charged. :/
Old April 11th, 2013, 02:56 PM   #19
quarterliter
The jets are definitely gummed up. Stabil or seafoam might have saved you. But if anyone you know has a clue with tools you could put some new tires on your bike with the money youd save. I hope you don't still have the stockers on.
Old April 11th, 2013, 03:03 PM   #20
AGFE0914
AGFE0914's Avatar
Hi Kevin,
How long would this take (not trying at all to sound like an impatient bi-atch)? Isn't it good to get a tune up anyway? I am sure doing this myself is the best answer as all you experienced bikers have proven. I need to learn about my bike, I don't know what stockers are
Old April 11th, 2013, 03:03 PM   #21
quarterliter
Do you have fresh oil in your baby? Shell Rotella T6 is the way to go btw
Old April 11th, 2013, 03:06 PM   #22
AGFE0914
AGFE0914's Avatar
My baby has been sitting since October, I have neglected her and probably deserve this.
Nothing new except for a battery 2 days ago.
Old April 11th, 2013, 03:20 PM   #23
quarterliter
Its cheap too. Full synthetic and its only 5 bucks a quart at walmart. Its a blue bottle and can buy it by the gallon.
Old April 11th, 2013, 03:40 PM   #24
Lychee
sail away
Lychee's Avatar
Hi Kevin,
A competent mechanic would have the carburetors cleaned in a few hours. Much of the work in this job is removing the fairings to get the carburetor out. If you want them to do a full tune up, valve job, sync and all, maybe a whole day plus whatever time they need to clean out the queue in front of you.
Stockers = stock tires in this context.
Old April 11th, 2013, 05:29 PM   #25
quarterliter
Stock tires are junk.... don't ride on em. I have more confidence in the knobbies on my dirt bike in sand. And if there from 2001 don't even get me started haha.....
Old April 11th, 2013, 05:37 PM   #26
quarterliter
Also do you have gear? I would recommend taking your bike to a wide open parking lot and practicing stopping and starting with the clutch. Also practice stopping with the front brake. Any serious racer or street rider alike use the front almost exclusively.
Old April 11th, 2013, 05:40 PM   #27
AGFE0914
AGFE0914's Avatar
Yeah I have gear. Helmet, padded jacket and boots. last year I only got to go to the lot a few time but its close by. I'll be there for a few weeks practicing.
Old April 11th, 2013, 05:44 PM   #28
quarterliter
Hope ya got gloves too! Grinding through a wrist or finger is not fun. Neither is picking rocks out of the wound trust me on that
Old April 11th, 2013, 06:09 PM   #29
AGFE0914
AGFE0914's Avatar
Yup gloves too
05 Ninja 250 won't start on its own - help! AmyF 1986 - 2007 Ninja 250R Tech Talk 59 July 8th, 2014 11:46 AM
2004 250 ninja help -- won't start SON1C 1986 - 2007 Ninja 250R Tech Talk 6 March 24th, 2014 10:30 AM
2007 Ninja 250 won't start Time Mage 1986 - 2007 Ninja 250R Tech Talk 24 June 17th, 2013 10:14 PM
Ninja 250 won't start! please help me! Black knight 2008 - 2012 Ninja 250R Tech Talk 4 May 23rd, 2013 03:22 PM
06 ninja 250 won't start wolfpuss 1986 - 2007 Ninja 250R Tech Talk 7 February 21st, 2012 05:57 PM
