January 14th, 2016, 04:34 PM | #1 |
Join Date: Jan 2016 Motorcycle(s): 2008 ninja 250r Posts: 3
Left - hand control assembly for track bike
I am turning my 08 250 in a track bike. Since I have recently purchased some fairings I am curious about what happens with the control assembly because it includes; headlight, blinker, horn, AND the choke. Is there some piece I have to buy to go in place of all that for my race fairings or does that just have to stay and not be used? HELP
January 14th, 2016, 05:08 PM | #2 |
Welcome Hadley!
You don't have to do anything with the left controls if you don't want to. All of those switches (except choke) can be simply unplugged and secured away as needed. Now... for fun, you might want to leave the horn hooked up. Tooting your whistle at a passing rider in the straight is kinda fun.
January 14th, 2016, 05:22 PM | #3 |
sammich maker
MOTM - Apr '15
welcome.
Good luck.
https://www.brocksperformance.com/VZ...0035+C450.aspx |
January 15th, 2016, 07:19 AM | #4 | |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
January 15th, 2016, 03:24 PM | #5 |
^^^ lol
I am owned on that one...
January 16th, 2016, 11:43 AM | #6 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
I am going through the same process with my 09. I decided to eliminate the whole left hand cluster and just use some safety wire on the choke. After installing my Factory Pro jet kit, I haven't needed the choke to start the bike anyway!
January 16th, 2016, 12:06 PM | #7 |
Track Clown
MOTM - Sep '15
Prevents pesky shenanigans of people hitting kill switch. I have re-routed the choke under the clip-on since:
January 16th, 2016, 12:31 PM | #8 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
Delete! Thats dead weight.
Run a safety wire lanyard to the choke from the left side |
January 16th, 2016, 07:00 PM | #9 |
Before you got deleting everything. What if.... you want to do the track day before race day? I have never seen a track day org that didn't require you to have a functional kill switch.
January 16th, 2016, 07:57 PM | #10 |
Private Joker
MOTM - Mar '14
^ agreed, kill switches are a serious safety feature
I've even heard of orgs that want two, one on each side so that it can be hit regardless of the way the bike went down if the bike is still on
January 17th, 2016, 02:26 AM | #11 |
January 17th, 2016, 11:15 AM | #12 |
Lol... Seems I got who posted what all mixed up. My fault for not paying enough attention. Carry on...
January 19th, 2016, 05:22 PM | #13 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
2nd the safety wire choke cable, I did it to mine
January 30th, 2016, 02:09 AM | #14 |
I added a dirt bike clutch perch with hot start lever for the choke lever. but I like the safety wire idea. \
Housing Control Assembly issues | zhuuka | 2013 - 2017 Ninja 300 Tech Talk | 4 | November 27th, 2015 05:19 PM |
left hand controls 95 bike 05 controls | mapolley07 | 1986 - 2007 Ninja 250R Tech Talk | 12 | December 22nd, 2011 10:05 AM |
