Old October 18th, 2014, 01:54 PM   #1
joecool
Rear brake reservoir bent?
Hey guys,
After installing an adjustable rear set i notice that my brake reservoir tube is bent? Anyone have this issue? How do I fix it without cutting and resizing tube?
Thxs
joecool is offline   Reply With Quote
Old October 18th, 2014, 01:59 PM   #2
cuong-nutz
cuong-nutz's Avatar
If you don't want to cut, just get some flat stock, drill some holes and extend the reservoir higher.
HalfFast Racing Team
Old October 18th, 2014, 03:07 PM   #3
Originally Posted by joecool View Post
Hey guys,
Thxs
More tips; unless the hose could contact the tire and get some abrassion:
-Rotate the wire hanger clockwise and relocate hose.
-Slide a hose of bigger diameter or a tight spring over the kinked portion.
Old October 18th, 2014, 06:23 PM   #4
Being bent/crimped that much is only part of your problem. You will/may find out when you change the rear tire and can't pump up the rear brake again after compressing the caliper piston. You need to get it straighter using one of the methods above, or a more appropriate length line. I aint saying your brake will not work, just saying it will have a very hard time pumping back up. And for full disclosure; Mine has been crimped like that for 1.5yrs. lol
Old October 18th, 2014, 06:28 PM   #5
Total cost of fixes 0 dollars. A rear brake that works the way you expect it to, priceless.
Old October 18th, 2014, 06:54 PM   #6
joecool
Ill look into the fixes above thxs!
I think the best bet is to cut to size.
Im sure im not the only ones with adjustable rear sets, what does everyone else do?
Posted via Mobile Device
Old October 18th, 2014, 06:55 PM   #7
joecool
Thxs! Whats flat stock?
Old October 18th, 2014, 08:39 PM   #8
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Here's one I made with some aluminum.
k-os is offline   Reply With Quote
Old October 18th, 2014, 09:53 PM   #9
I am not sure if you have messed with brake lines before, but cutting it is not for the novice. There are many reasons brake lines are made the way there are.
Try the easy stuff first, and then go for the remount if needed. You will thank yourself later when you have no problems that were not there before.
Old October 19th, 2014, 07:37 AM   #10
joecool
Cool thxs!! That looks good
Old October 19th, 2014, 09:32 AM   #11
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
had a similar issue.
Old October 19th, 2014, 09:37 AM   #12
it's a oil safe rubber hose that costs like, $2 if you want to replace it... just cut an inch or two off of it and put it back on.
Old October 19th, 2014, 09:45 AM   #13
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
replace clips too
Old October 19th, 2014, 07:55 PM   #14
joecool
Gonna have to have a shop do it, I don't feel comfortable bleeding the brake after adjusting the hose.
Old October 20th, 2014, 06:39 AM   #15
You aren't dealing with the brake line - that's the reservoir line.
It's not under pressure, and it doesn't have special fittings on the ends.
In your case, the line is just too long. You can drain the line and reservoir without affecting the brakes - if you don't touch the pedal.
Drain it out and cut some off of the end. If the protective hose over the line won't move you may need to make cuts on both ends, and you need to leave some room for the original clamp.
No need to take it to a shop. If you can install the rearsets and get them adjusted properly you can make the alteration to the line.
Old October 20th, 2014, 08:54 PM   #16
joecool
Cool! Thxs a lot, I'll give it a try
Old October 20th, 2014, 08:55 PM   #17
joecool
Lol!
Relocation of The Rear Brake Reservoir (Pics) ladyrocket 2008 - 2012 Ninja 250R Tech Talk 12 May 16th, 2011 09:41 PM
DIY - Relocating the rear brake reservoir VeX 2008 - 2012 Ninja 250R Tech Talk 12 December 3rd, 2008 11:13 PM
