September 4th, 2012, 10:43 AM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2003 Goldwing GL1800, 2002 Ninja 250, 2001 VFR800, 1999 Ducati 996 Posts: 107
all of a sudden the bike refuses to start....
As the thread title says, my bike refused to start this morning. I have been riding 50 miles a day, 5 days a week for the last 4 months. The bike hasn't given me an ounce of trouble in all this time. It started yesterday just perfectly, but when I tried today it simply wouldn't start.
It cranks over with good speed but will not fire up. The battery is healthy as it keeps good cranking speed over many attempts. Here is what I do know so far:- - Battery is good - All lights (neutral, oil pressure) come on with ignition in ON position - Bike shows no interest in trying to fire up I will obviously be checking the usual suspects of gas and spark. The tough one about this is that nothing has changed from one day to the next; it lives in a garage and I haven't done anything with the gas. I haven't spent any quality time with the bike as yet, and won't until tonight. Just trying to "armchair quarterback" this issue for now, and any suggestions would be very welcome. My wild guess right now (probably wrong) is that my CD Igniter unit may be knackered, and I will be testing tonight with my multimeter. TIA. |
September 4th, 2012, 10:52 AM | #2 |
Pop the fuel lid and try cranking again. Maybe it has a vacuum lock on it right now. Looks like your on the right path though. Start with the simple things GL!
September 4th, 2012, 10:53 AM | #3 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
It's hard to say based on the brief description but as long as the fuel tap is "On" and you actually have fuel maybe you should try to pop the clutch on hill? It would just help eliminate a lot of the starting circuit issues and narrow the issue more in the direction of the engine.....
September 4th, 2012, 10:59 AM | #4 | |
But I tried that and it's not the cause. This bike also never get s the squealing noises associated with tank vacuums. |
September 4th, 2012, 11:01 AM | #5 | |
I can try running up and down the street to bump-start it, but my old bones won't want to do much of this.... |
September 4th, 2012, 11:03 AM | #6 |
There's always this option:
http://www.youtube.com/watch?v=I63InOIKdkw |
September 4th, 2012, 11:05 AM | #7 | |
September 4th, 2012, 02:21 PM | #8 |
Join Date: Jun 2012 Motorcycle(s): 2010 Metalic Island Blue Ninja 250r Posts: 206
Is it possible that your fuel tap is leaking, causing the engine to flood. This happened to me and my bike would not start sometimes, even after cranking it for almost a minute. It was a very rough start to say the least but ran beautifully like nothing was wrong.
I had to hold the throttle wide open and crank the engine until it started before i replaced my fuel tap. Just a thought, good luck! |
September 4th, 2012, 08:49 PM | #9 |
Well, the bike is running again and I don't know why..!!
Checked that the clutch interlock system was functioning properly. Then checked that the neutral interlock system was functioning correctly. Pulled the plugs and found that both were firing, so the coils and the CDI are also OK. I could smell fuel, and there was even some on the spark plug thread when I pulled them. Still the bike wouldn't fire up. So, I gave the airbox a good dose of starting spray and the bike reluctantly coughed back into life. It is now purring at idle better than it ever has. What was wrong....no idea. I am stumped by mysterious fixes like this. I'm not complaining, but I do like to know what was wrong. The big test is if it will fire up in the morning on a cold engine after sitting all night.... |
September 5th, 2012, 05:12 AM | #10 |
Sounds like some debris in a jet or something that finally broke loose.
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
[cyclenews.com] - Jorge Lorenzo Refuses Comment on Clash | Ninjette Newsbot | Motorcycling News | 0 | May 5th, 2013 10:10 PM |
2012 Ninja 250 Refuses To Start | bad_bwoy007 | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 8th, 2013 05:28 PM |
Bike refuses cooperate, need help! | djvash | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 14th, 2012 01:59 PM |
I was driving along when all the sudden... | itsa250bro | !%@*#$%!)@#&!%@ I crashed! | 19 | September 15th, 2011 11:30 AM |
