June 11th, 2013, 12:04 PM | #1 |
Beginner Gear! Look ok?
Hey guys! Starting to look at some gear for when I get my bike! Now understand this gear is just for me to drive the bike around my neighborhood and some parking lots until I am comfortable enough to take the MSF! Let me know what you think!
Helmet: http://www.leatherup.com/p/Hawk-Helm...et/139417.html Visor: http://www.leatherup.com/p/Hawk-Helm...es/147815.html Jacket: http://www.leatherup.com/p/Mens-Moto...ric/64174.html Gloves: http://www.leatherup.com/p/Motorcycl...ves/56128.html I will eventually buy more gear once I get comfortable and am getting ready to take the bike out on the streets! Let me know what you think so far! |
June 11th, 2013, 12:24 PM | #2 |
/moved to gear area
June 11th, 2013, 12:30 PM | #3 |
You got 2 ways of looking at it.
Go minimum as you can to ensure you don't overbuy before getting into riding. You might not like it as much as the idea of riding. It can be the smart thing to do if you are somewhat unsure. If this is the case, then your selections are fine aside of the jacket. A jacket like that is just not required for the MSF. If your 100% sure you will be riding after the MSF then I honestly think you could do much better shopping the closeout deals on various sites. You should end up with much better gear for just a bit more $$ and not have to rebuy after your msf. Good luck either way.
June 11th, 2013, 02:23 PM | #4 |
Join Date: Jun 2013 Motorcycle(s): '04 Ninja 250R, WR400F Posts: 4
Go to a brick-and-morter store and try a bunch of helmets on. Even a helmet that is the correct size range might have fit issues. I have tried on some mid to high end lids and found that they pinch in funny places.
Get some real leather gloves. I second the opinion to skip the jacket for now. |
June 11th, 2013, 02:27 PM | #5 |
buy some boots. take the msf before you ride your own bike. its cheaper to crash someone else's bike.
June 11th, 2013, 02:33 PM | #6 |
You should not fall during the course, Joey.
And even if you do, working boots, jeans and any heavy jacket will be good. Try sturdy but flexible gloves and ask the provider if they lend helmets for the course, many do. You will have a better idea about this staff after your pass the tests.
June 11th, 2013, 03:15 PM | #7 |
Why buy sub-par stuff just because you're a noob? Is your personal safety less of a concern than it will be later on?
I strongly recommend doing the MSF BEFORE you start riding around your neighborhood. You will learn correct habits and won't have a chance to start doing things wrong that you will then have to un-learn. I agree with the "get the minimum to take the MSF" advice above. Chances are you already own everything required. They will give you a helmet to wear. Then, get good gear... the best you can afford. That way you won't have to replace it. There's a guy here at the office who just bought his first bike. He got a beater, on the premise that he'd drop it (and he has, already). But he also bought top-shelf leather gear... all his protective apparel is as good as it gets (Arai, A*, Held, etc.). His gear probably cost him half or more what the bike did. I think he's got his priorities straight. Fit and function are more important than name brand. There's a ton of info out there on proper fit and gear buying advice, but here's a short(ish) version: - Your helmet should fit snugly. When you have it on and move it around, the skin on your face should too. If it doesn't it's too lose. There are endless debates about helmet quality and ratings... suffice it to say that if it doesn't fit, it won't work properly no matter who made it. - Your jacket (and pants) should have good armor (CE rated) and should fit snugly enough that the armor will stay put in a crash. Consider replacing the lame back pad in the jacket with a CE-rated back protector. Wheelchairs suck. - You should strongly consider hi-viz gear, or at least light colors. All-black gear may look bada$$ but it makes you hard to see. Personally, I wear only neon-yellow helmets because your head is the single easiest-to-spot part of you. It's higher than anything else and the helmet makes it even bigger than it already is. - Leather is better than textile if you can afford it, from both a durability and a protection standpoint. A good leather jacket will last years. A textile jacket will probably wear out sooner. When I say "leather" I mean an actual riding jacket, with armor, not a "motorcycle jacket" from a clothing store.
June 11th, 2013, 03:16 PM | #8 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
no.
Ive never even heard of that brand.... At least get a well known cheaper brand like GMax. You can get one of their helmets for like $100. and what is that site? Gawd its worse than the cycle gear site. Speaking of cycle gear. See if there is one near you and go to their store.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
June 11th, 2013, 04:32 PM | #9 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
these are some realllllly good deals. wish id had the money for em atm.
http://www.revzilla.com/motorcycle/t...ro-mesh-jacket http://www.revzilla.com/motorcycle/t...leather-jacket just check out revzillas closeout section. a ton of helmets for under 150. |
June 11th, 2013, 05:08 PM | #10 |
Join Date: Sep 2012 Motorcycle(s): Suzuki GSX650F! Past: Kawasaki Ninja 300 (Sold); Triumph Street Triple (Sold); Kawasaki Ninja 250 (Sold) Posts: 664
Here you go, my friend: http://www.motorcyclecloseouts.com
sportbiketrackgear.com also has pretty epic closeouts regularly. Here are a few options for close to the prices you picked out: Helmet: http://www.motorcyclecloseouts.com/s...+-+solid+speed or ESPECIALLY this one -- this is a killer helmet: http://www.motorcyclecloseouts.com/s...ex+torn+helmet Jacket: http://www.motorcyclecloseouts.com/insanity/3225 http://www.motorcyclecloseouts.com/s...hter+ss+jacket Gloves: I can tell you're on a budget, but you couldn't pay me to wear those gloves you picked out. They would be very close to useless in a crash. Unfortunately, gloves and boots are the two places where it's very close to true that you get what you pay for. It's difficult to get gloves that are worth wearing for less than $100. If I were you, I'd look at the marketplace for some second-hand higher-end gloves. At the very least, I'd get something like this: http://www.motorcyclecloseouts.com/s...esh+long+glove. All IMHO, of course. Good luck! |
June 11th, 2013, 05:12 PM | #11 |
Nice Travis, those are the kinda deals I was referring to, about the same prices as the original selections. That bell is a bit heavy but will make a mighty fine first helmet.
June 13th, 2013, 08:37 PM | #12 |
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Posts: 121
Im guessing the downside to a heavy helmet would be a fatigued neck? If so, does that just happen on longer rides or would you notice it period?
June 13th, 2013, 09:02 PM | #13 |
Join Date: Oct 2012 Motorcycle(s): 2002 Ninja 250 Posts: 213
I bought all my first gear from leather up too. Google a coupon code and you should be able to find like a 10-15% off one. I might have a coupon in my email.
June 14th, 2013, 05:12 AM | #14 |
Yep, especially in the wind and after a day of riding. I notice it more because I have worn some really nice helmets that were light and some really crappy ones that are heavy. When you get into the really nice helmets the price shoots waaaaaaayyy up.
June 14th, 2013, 06:46 AM | #15 | |
But then, once you get hooked....... get ready to spend every cent you ever make! |
June 14th, 2013, 10:32 AM | #16 | |
June 14th, 2013, 10:57 AM | #17 |
Join Date: May 2010 Motorcycle(s): 1996 Kawasaki Ninja 250, 2000 Kawasaki Super Sherpa Posts: 79
I haven't seen it mentioned so I thought I would comment on:
http://www.motorcyclegear.com/ I know a lot of people who have been very happy dealing with them, and they have a good return policy too. Edit - they also have sections for people selling lightly used gear for some pretty incredible deals. |
June 14th, 2013, 12:33 PM | #18 |
leatherup sucks!
Stay away from leatherup. Horrible customer service and experience with them! You can find better stuff at other sites like www.rockymountainatvmc.com, www.motorycyclecloseouts.com, www.motorcycle-superstore.com, www.revzilla.com
June 14th, 2013, 02:17 PM | #19 |
^guess I got lucky with them! Or you were unlucky. I order a helmet, jacket and gloves..got it in central fla 2 days later. I even called before I ordered with a question about the jacket I wanted. They were very helpful.
June 14th, 2013, 03:38 PM | #20 |
Helmet 107:
http://www.motorcyclecloseouts.com/s...+-+solid+speed and also a mirrored visor. Jacket and Gloves combo - $109.95: http://www.motorcyclecloseouts.com/c...torrent-gloves |
June 14th, 2013, 04:15 PM | #21 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Just a quick tip, Motorcycle Superstore has always been great to me and they do free shipping on orders above $89 I believe and it is TWO DAY shipping + a couple of days for them to process the order. Just ordered new leathers from Revzilla because they had my size in the pants and I felt bad for using their reviews and not giving them my business and they also do free shipping, but it's standard... so gear I would have had a few days ago from Motorcycle Superstore won't be here until monday.
June 24th, 2013, 01:01 AM | #22 |
I took the MSF course 4 months before I even began looking at a bike to buy. I got my gear off craigslist, $90 for a leather jacket w/matching gloves and helmet (some off-brand). Eventually got rid of the helmet in favor of an icon (still keep the old one around just in case). jacket and gloves still had tags on them when I got them.
Point being, check your local listings. You can find some great stuff. |
June 26th, 2013, 12:09 AM | #23 |
I wouldn't exactly call off brand gear "great stuff." You want thick, quality leather or textile in impact areas, mesh in non impact areas is fine IMO but others opinions may be different. You also want CE rated armor in everywhere that's going to hit something solid. And for the love of God please do not use an off brand helmet.... You can get DOT, ECE, SNELL approved Scorpion EXO-400 for $100-150 brand new easily. Bell has helmets on sale all the time too, $70 for their entry level model that's infinitely better than some cheapo. How much do you really value your life?
June 26th, 2013, 12:28 AM | #24 | |
It doesn't have to be brand name to be good. My whole point was that it can pay off to check the local listings before you go out and pay hundreds of dollars more for similar quality. |
June 26th, 2013, 06:23 AM | #25 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Those gloves are a joke!!!
July 8th, 2013, 02:19 AM | #26 | |
Join Date: Jun 2013 Motorcycle(s): 2003 ninja 250 Posts: 8
July 15th, 2013, 04:54 PM | #27 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
This post isn't in regards to the gear, because I just started riding, and don't have valid input on that lol
But I'm sure you're more than ready for the MSF course. I had NEVER been on a motorcycle before the course (not even a dirtbike), and passed it fine. Hell, I hadn't even driven a manual car before it. |
RyderRider15's Beginner guide to motorcycle gear | RyderRider15 | Motorcycle Gear | 15 | July 17th, 2012 06:40 PM |
Suggestions on Beginner Gear? | TBC | Motorcycle Gear | 52 | April 7th, 2012 07:16 PM |
Beginner Jacket Help | Jmar24 | Motorcycle Gear | 52 | April 5th, 2012 05:19 AM |
Ok beginner gear? | akshay11 | Motorcycle Gear | 14 | March 1st, 2012 02:32 AM |
Opinions on gear and other things that a beginner needs to do or know. | R250R | General Motorcycling Discussion | 11 | November 6th, 2011 05:15 PM |
