Old April 16th, 2015, 09:38 AM   #1
Xata27
Xata27's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R
2010 Ninja Not Starting
I picked up a 250R that didn't start but the motor did turn over. When I got it home I noticed that almost every tube was unplugged and the spark plug boots were just dangling there. After plugging the lines back into the petcock and putting the spark plugs back in I tried starting it up again. The motor just turned over and it wasn't able to start. Something I've noticed was when the bike is in first gear and you try to start it, the bike pulls you as long as you hold your finger down on the start button.
Thing I've done:
- Plug the old spark plugs back in
- Drain the float bowls
- Removed janky ass paint from the fuel tank
Xata27 is offline   Reply With Quote
Old April 16th, 2015, 09:44 AM   #2
kdogg2077
kdogg2077's Avatar
Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold)
Clean the carbs maybe?
"Take it easy driving. The life you might save might be mine."
kdogg2077 is offline   Reply With Quote
Old April 16th, 2015, 10:09 AM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Thing I've done:
are you saying that you have the bike in first and you are starting it (assuming you have clutch lever pulled in) and as the bike tries to start it creeps forward as the counter shaft is turning and therefore turning the rear wheel????
If so check out the clutch stuff, start at the lever and work your way down into the clutch case searching for problems.
Bike wont start, god knows when it was run last, clean and check everything, I would probably start with fuel and fuel delivery then go from there as it seems you are getting spark
Old April 16th, 2015, 12:14 PM   #4
Xata27
Xata27's Avatar
Thanks for the clutch tip! The clutch cable was too tight, loosened it up and now its starts up just fine.
Old April 16th, 2015, 01:34 PM   #5
Old April 18th, 2015, 03:54 AM   #6
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
So the bike wasn't in neutral when you originally tried starting it?
Old April 18th, 2015, 06:05 AM   #7
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Nope. Sounds like he's in 1st with the clutch pulled in. And the clutch cable didn't have enough slack, so it wasn't fully disengaged from the motor.
Riding it like I financed it.
Starting issues, Ninja 2010 won't crank BlueDragon 2008 - 2012 Ninja 250R Tech Talk 6 March 12th, 2015 02:49 PM
2006 Ninja starting issues squrtlesride 1986 - 2007 Ninja 250R Tech Talk 5 July 20th, 2013 08:42 AM
06 Ninja 250- Starting Issues. Need help hazelberg 1986 - 2007 Ninja 250R Tech Talk 9 January 1st, 2012 08:57 AM
2007 250 Ninja Not Starting FrankChen07 1986 - 2007 Ninja 250R Tech Talk 2 October 24th, 2011 09:46 PM
Ninja not starting up. junsiang 2008 - 2012 Ninja 250R Tech Talk 2 May 8th, 2010 08:06 AM
