Old July 2nd, 2016, 12:20 PM   #1
momoru
momoru's Avatar
Motorcycle(s): 2005 Ninja 250R
Beware of Tar Snakes
Went for a ride today on a twisty road I've ridden many times, and I kept feeling my tires slip in corners. I had just checked the tire pressure so I was sure it wasn't wrong pressure, but at first I thought maybe I had oil on my tires or maybe had a lapse where I wasn't giving enough throttle into the turn, yet some turns I had tons of grip and no problem. Eventually I realized the difference... tar snakes everywhere!
http://www.motorcycletraining.com/te...of-tar-snakes/
Didn't realize these little buggers would cause so much slippage on a dry, relatively cool day (70 degrees).
momoru is offline   Reply With Quote
Old July 2nd, 2016, 12:30 PM   #2
Hate those things!
Old July 2nd, 2016, 01:34 PM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Few weekends ago was up on Monitor Pas and watched as a bunch of new tar snakes were hatched by a CalTrans crew filling in the cracks.
Tis tar snake season and it only gets worse. Bleh
<-- Linky
Old July 2nd, 2016, 05:18 PM   #4
MrAtom
MOTM - July '15
I used to think that since it was a rubbery surface that it would have more grip. I hadn't considered that the wheels bite into the asphalt and just sorta press against the tar. That said, a sudden change in grip, positive or negative, is never good, but I learned better... The scary way. Didn't crash, but I did slide a little, enough to make me gasp. Got home and read up on them a little bit
Old July 2nd, 2016, 09:11 PM   #5
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Ugh. Yeah, I tend to try and avoid these. Haven't slipped yet, but I'm always ready for it.
Old July 2nd, 2016, 09:48 PM   #6
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
when they are new they are slick in all condition. after a few rains the oils will raise out and wash away giving them a bit more traction in the dry but they are always to be respected in the wet.
Old July 2nd, 2016, 11:26 PM   #7
EternalNewb
EternalNewb's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar
I haven't had any terrible experiences with these things yet, but I'm always on the lookout.
EternalNewb is offline   Reply With Quote
Old July 2nd, 2016, 11:46 PM   #8
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
I drove through some fresh ones on my way to work the other day. I was riding along at a constant 50ish MPH on a straight road. Instantly started to spin up the rear triggering the TCS on my FJ. Still got all sorts of out of shape. I have started taking another route until the oil gets washed off.
empire00 is offline   Reply With Quote
Old July 3rd, 2016, 05:36 AM   #9
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
The oil does not get washed out for the ones near my house for some reason. They filled some cracks in the residential neighborhood (25mph limit) with these tar snakes in March (3 months ago). The bad thing is that it's a pretty winding road and these snakes are parallel to the road. On days where it's below 70 degrees, it's just a tiny bump. But once the temps hit 80+, you really feel the bike sliding around.
I purposely hit them at a higher lean angle than necessary to get used to the feel. The secret (and I feel this applies to almost all things) is to be very loose on the handlebars.
Because traffic is very light in this residential neighborhood (no thru traffic), it's taking a long time for the tar snakes to be pressed in and be flat with the asphalt.
Riding it like I financed it.
Old September 13th, 2016, 09:08 PM   #10
Hoons54
Hoons54's Avatar
Motorcycle(s): 09 Ninja 250r
I've had some close calls, now I pay more attention when riding
Hoons54 is offline   Reply With Quote
Old September 13th, 2016, 09:44 PM   #11
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
ahhh.. so that is what you call it.
Had a few close calls too with that bugger. I personally call it "holy sh*t".
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old September 14th, 2016, 09:45 AM   #12
jBazz
jBazz's Avatar
Motorcycle(s): 300
This intersection has so many tar snakes you can see it from space! I often get on the main road from the snake covered ramp on top of the image, that is also an off camber and incline, with a yield sign. Great combo!
jBazz is offline   Reply With Quote
Old September 14th, 2016, 08:06 PM   #13
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Attachment 41553
This is no small snake. This is an Anaconda.
Old September 14th, 2016, 08:07 PM   #14
Imma take a few pics of my road. It's like a road map of LA... soooooo many tar snakes
Old September 21st, 2016, 08:40 AM   #15
ally99
Ninja chick
ally99's Avatar
MOTM - Dec '13, Feb '15
I don't think I've ever heard of them causing a crash, but the tar strips that go in the direction of travel definitely cause slippage. I've played with it on the ride home and experimented. The rear slips right across them. If one were leaned at max, hypothetically, and hit a wide tar strip, it seems it could eat up that last percentage of traction. Stay loose, y'all, and let the bike do its thing.
Postwhores are COOL! ~Allyson
Old September 21st, 2016, 05:57 PM   #16
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Have you taken the pics Chris?
Old September 23rd, 2016, 10:55 AM   #17
Sorry, here is what they did to me.
Litterally, they tared and chipped my side road to my house and then when I get to what WAS decent pavement, they come along and do this crap.
I am pretty frustrated with the county road department.
Old September 23rd, 2016, 10:56 AM   #18
I literally have have 4 miles of this crap on top of the 1 mile of gravel.
Old September 23rd, 2016, 10:57 AM   #19
On the positive side, I have been looking for words written in the tar snakes. I figger it would be funny if the road crew put hidden messages in there somewhere. hahahhahahaha
Old September 23rd, 2016, 11:26 AM   #20
CaliGrrl
CaliGrrl's Avatar
Maybe you should add a few hidden words! Black spray paint? Is it illegal to spray black paint onto a black surface?
Old September 23rd, 2016, 11:31 AM   #21
From my track riding at Nelson Ledges (worlds only paved mx course lol), I am ok with the bike moving around under me. Cold, hot, wet or dry you can feel these under the tires (even in the car/truck). It mostly sucks... the bike is talking to you all the time and you have to figger out what is traction vs noise.
Old September 23rd, 2016, 02:08 PM   #22
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
My work parking lot has a windy entrance way. Was fun. Now it's tar snake city. Hope they get better soon.
Old September 23rd, 2016, 05:17 PM   #23
sparklenation
sparklenation's Avatar
Motorcycle(s): Kawasaki Ninjette ex 250
Wow, where do you live, it looks amazing there. I am like 3 min from Disneyland crazy all year round, I would love a view like this.
The Second protects the First!
sparklenation is offline   Reply With Quote
Old September 23rd, 2016, 06:28 PM   #24
I live in northern KY, some of the roads here rival the dragon in TN except much, much, much longer. For example; this is the road I take to go virtually anywhere.
http://www.motorcycleroads.us/roads/ky22.html 107 miles, about 1000 curves of various types but about 3k steering inputs.
Old September 26th, 2016, 12:44 PM   #25
Sulman
Sulman's Avatar
Motorcycle(s): Ninja 300
They are usually no great problem, but I very nearly came undone in Summer on some fresh ones that had been laid right at the turning point of an intersection, in a transverse pattern.
I knew they were there, but what surprised me was how slick they were. I actually dropped the bike by kicking out my leg and caught it as the front wheel completely stepped out when I passed over them.
Sulman is offline   Reply With Quote
Old September 26th, 2016, 05:53 PM   #26
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
well, at least the good side of this is that your road is even. In Malaysia, they do this tar snakes on uneven roads and on roads which are slippery (due to oil spill).
Idiots.
Old October 3rd, 2016, 06:37 AM   #27
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Noobs!
Originally Posted by InvisiBill View Post
In related news... #PureMichigan
PIC OF THE DAY: This photo of a road that has been sealed - a lot, has been trending on social media with the caption "Pure Michigan road fix." Nick Bouma tells us he took the photo in Hudsonville, MI outside of Grand Rapids.
Where I personally ride, I've never seen it that bad. They just seem to be in the worst places, like on a blind uphill curve near an intersection.
Chipseal (which is what that thread was about) is becoming the bigger problem around here. With the Volt, I've discovered just how much louder it is and how much more fuel it consumes to drive on a rough chipsealed road. I'm sure it does wonders for tire life too. It's not too horrible a surface to ride on once it's done, but on a recent ride I actually ran into the construction crew. I got to ride over wet tar and deal with loose gravel all over too. It used to be a nice out-of-the-way, wooded, curvy road along the river. =(
Old October 3rd, 2016, 03:09 PM   #28
Koala
Koala's Avatar
Motorcycle(s): 2017 Ninja 300 Winter Test Edition
MOTM - May '18
Noobs!
holy poop on a stick mr hat!!!! I thought the roads in Akron, Oh were bad.....
Koala is offline   Reply With Quote
Old October 3rd, 2016, 04:34 PM   #29
NevadaWolf
NevadaWolf's Avatar
Strangely, sort of reminds me of this:
<-- Linky
[RoadRUNNER] - Snakes Ninjette Newsbot Motorcycling News 0 August 26th, 2013 05:00 AM
Road snakes (tar strips) riding question funky_beatz Riding Skills 10 July 1st, 2013 12:57 PM
[WARNING] Snakes have found a new habitat, our bikes! EthioKnight Videos 20 July 1st, 2013 11:01 AM
Cleaning tar? ai4px General Motorcycling Discussion 10 June 25th, 2012 07:26 PM
Cleaning Tar from Rim Tape patw General Motorcycling Discussion 15 July 22nd, 2009 01:08 PM
