Old November 14th, 2012, 01:56 PM   #1
SabreValkyrn
Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy)
Running rich?
After doing forum research I think my bike is running rich. However, it doesn't seem quite right, it's like a mix of too rich or too lean? I've listed symptoms as well as I can.
Has to have almost max choke on to start: lean?
Smells really gassy at idle with choke off: rich?
Engine dies unless RPMs kept above 3.5k for the first 5 minutes of riding: normal?
RPMs drop to almost nothing, then slowly drift up to 1200: rich?
Engine bogs below 5.5k until very warmed up, with and without choke: rich?
Really poor gas mileage, partially from choke duration: rich?
Runs way better when warm: lean?
Can take almost full throttle within 10s of starting, with no choke: rich?
Sometimes stalls after getting off freeway from a 10m ride: rich?
What steps do I take to confirm or fix the problem?
I think looking at the spark plugs is the simplest?
SabreValkyrn is offline   Reply With Quote
Old November 14th, 2012, 02:41 PM   #2
Cleaning the carbs is in your future... I feel.
Old November 14th, 2012, 03:27 PM   #3
flynjay
flynjay's Avatar
Stock Exhaust, airbox, jetting?
Old November 14th, 2012, 04:38 PM   #4
SabreValkyrn
Ah, my bike did sit for about a month while I looked for a new engine. Seafoam is in my immediate future I think. Totally forgot about carbs.
Stock everything except cosmetic.
Thank you for the responses
Old November 15th, 2012, 08:36 AM   #5
DaBlue1
DaBlue1's Avatar
Originally Posted by SabreValkyrn View Post
.... Seafoam is in my immediate future :
Also consider Star Tron fuel treatment. Be sure to increase your idle speed as well if the outside temps have dropped.
Running Lean or Rich? need help mkulchar 2008 - 2012 Ninja 250R Tech Talk 105 October 3rd, 2021 01:13 PM
am i running rich? willtrimble 1986 - 2007 Ninja 250R Tech Talk 19 April 18th, 2014 01:20 PM
Running rich, any help? hillbilly86 General Motorcycling Discussion 15 June 5th, 2013 05:32 AM
Bike is running WAY too rich. CZroe 2008 - 2012 Ninja 250R Tech Talk 5 April 5th, 2010 12:32 PM
Problems running, seems very rich? maxedpenny 2008 - 2012 Ninja 250R Tech Talk 7 June 30th, 2009 08:51 PM
