Old March 31st, 2023, 03:55 PM   #1
ducatiman
ducatiman's Avatar
SOLD REFURBED carbset #106
My #106 are carefully REFURBED to tweaked specs, Dyno Jet 98 main jets, factory 38 pilot jets, Dyno Jet needles, factory pilot screws set to 2.5 turns out, carefully synched
Perfect to offer a long service life for any "Pre-gen" employing stock or aftermarket exhaust EX250 from '88-'07
* REFURBED, split, totally disassembled and every component cleaned using standard combination of my usual, both machine and handiwork (note like-new condition of all brass components)
* all new orings all around, with new viton float valves (with dressed seats) installed
* new stainless steel hardware all around
* Dyno Jet kit installed, slide air pickup drilled to 7/64", needle clips set to #4 needle position, with my special spacers installed to prevent needle float
* perfect slide action
* carefully bench synched throttle plates
* all circuits cleared and confirmed clear
* wet tested, fuel levels perfect, no leaks
* bolt-on runners ready to rock, prepped to deliver a long service life
* note 1 stripped 4mm bowl screw has been drilled, re-threaded, utilizing an oversized 5mm screw (perfectly safe and secure)
SOLD
Please contact via PM here (or email gordon@customcarbservices.com) to discuss specifics, or with any further questions, for pics, etc. Members thanks for lookin'.
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; April 9th, 2023 at 06:47 PM.
Old April 8th, 2023, 12:52 PM   #2
jk3099
Motorcycle(s): 2006 Kawasaki Ninja 250
Hi ducatiman,
Sent you an email!
Best,
jk3099
jk3099 is offline   Reply With Quote
Old April 8th, 2023, 01:51 PM   #3
ducatiman
ducatiman's Avatar
responded minutes ago
#106 SOLD
Custom Carb Service
Last futzed with by ducatiman; April 9th, 2023 at 06:48 PM.
fs...08'-12' REFURBED carbset ducatiman Motorcycle-related 3 November 30th, 2018 07:59 PM
'08-'12 REFURBED CARBSET fs ducatiman Motorcycle-related 3 July 10th, 2017 03:15 PM
fs REFURBED CARBSET '08-'12 ducatiman Motorcycle-related 2 June 30th, 2016 11:39 AM
fs REFURBED CARBSET ducatiman Motorcycle-related 7 December 31st, 2015 01:55 PM
fs: '08-'12 REFURBED CARBSET ducatiman Motorcycle-related 5 November 5th, 2015 08:27 PM
