Old May 15th, 2023, 12:45 PM   #1
ZackTheReaper
Unhappy Rebuilt my carb, now throttle bracket is getting stuck when pulling on throttle
Just rebuilt my carbs and reinstalled them. When I pull on the throttle the bracket holding the push and pull cables get caught. I can force it to break through. It does the same when you release the throttle. Any advice?
ZackTheReaper is offline   Reply With Quote
Old May 16th, 2023, 04:45 AM   #2
bracket has been broken/incorrectly repaired, should be 1 piece (enlarge photo, see yellow highlight) Get a new bracket, end of issue. .
Old May 16th, 2023, 11:54 AM   #3
Post photo of what you have.
Also make sure you don't have cables crossed or reversed.
Old May 16th, 2023, 01:02 PM   #4
@DannoXYZ the photo i posted is actually his, i copied it from his post on kawiforums
bracket has been modded or possibly swapped from another model
Old May 16th, 2023, 04:32 PM   #5
The inner wires also look very bent-up and frayed as well.
Here's video of working system:
Old May 17th, 2023, 10:14 PM   #6
ZackTheReaper
I took the carb out, re cleaned it and check everything over. And out I back in and it stopped getting caught. The bike starts and will idle just under 2k the choke open. If I close it, it goes up to 6k. If I give it any throttle ( choke open or closed) it bogs down and dies. I’m not sure if there is a vacuum leak or didn’t screw a jet in enough or something.
Old May 18th, 2023, 04:10 AM   #7
all carb internals:
*accounted for? (needle jets have a strange way of going missing)
*reassembled correctly using new orings where called for?
*pilot screws set correctly (2-2.5 turns out) for your application?
*orings present, in correct order?)
*on '09 jet needles are positioned correctly? (they differ L and R)
*jet needles assembled correctly....directly into slides?
*carbs inserted fully (forward) into their manifolds?
All common issues/errors i've seen
Old May 18th, 2023, 05:34 AM   #8
https://www.kawiforums.com/threads/r...rottle.387232/
starting yet another thread rather than responding/discussing?
Old May 18th, 2023, 08:41 AM   #9
ZackTheReaper
I was having troubling finding this one again cause the website runs likes crap on the phone. I’m also brand new to all this and have spent over 20 hrs trying to get this thing to run. I’m pretty sure I’m missing the Imulsion tubes. Hopefully putting those in will fix my problem. Is there anything else specifically I should look for other than cleaning the jets (for the 3rd time now). I have new fuel hoses on the way. I couldn’t find any vacuum leaks but that doesn’t mean there isn’t one. I also got a new fuel filter cause the old one is basically toast.
Old May 18th, 2023, 10:25 AM   #10
There are some difficult to clean passages that need to be clear.
https://n4mwd.blogspot.com/2013/10/s...-passages.html
Old May 18th, 2023, 10:36 AM   #11
all carb internals:
in that case, respond to the above allowing us at very least a baseline/beginning
Old May 20th, 2023, 06:15 PM   #12
ZackTheReaper
I took the carb out again and put in the missing pieces and doubled checked everything. It stared up and worked fine! It’s kinda bogging around 8-10k rpm. I’m gonna put more sea foam in there. The pilot jets hole was stripped so I had to thread repair it to get the new pilot jet in. It screw in tight like the other one. That could be the cause but I’m not sure. I may also need to the sync the carb or something. But I have no idea.
Old May 22nd, 2023, 05:27 AM   #13
WTF?
Old May 22nd, 2023, 08:34 AM   #14
ZackTheReaper
Well thanks someone on the other thread, he said it’s probably my idle screws. I have them at 2 turns right now. I also probably need to sync my carbs. Liek I said before already, I found the Imulsion tubes fell out so put them back in. It idles at 3k plus and bogs/ stutters at 8-10k.
Old May 22nd, 2023, 10:05 AM   #15
"I found the Imulsion tubes fell out"
as they are threaded in.....how could that happen?
IF you are actually referring to needle jets....they are captured underneath the threaded emulsion tubes.
Thus impossible for either to "fall out"....unless you installed needle jets incorrectly.
Old May 22nd, 2023, 12:33 PM   #16
ZackTheReaper
I probably called it the wrong name. It’s the little pins the go under the main jets or whatever. I have taken it out three times now and watched multiple videos on how to put it back together. I have quadruple checked everything before I put it in last. Like I said, the giy in the other forum said, it’s probably my idle jets. I also have a big yoshimura (fake) on there that might also be affecting the idle jets. I’m going to do some tweaking today. My friend who is also a car mechanic has been helping me out this whole time. We the carb has all new jets and needles so nothing should be clogged. We have cleaned the **** out of 3 times now, each cleaning better than the last. My only problem now is high idling and bogging at higher rpms. Can’t get it to red line really. Before I cleaned the carbs the bike would barely start and would only run with the choke closed. And it wouldn’t go over 2k rpms. I probably need to sync the carbs too. If you have any idea as to why it would bog at higher rpms, that would be great.
Old May 22nd, 2023, 04:03 PM   #17
Are these Keihin jets, in original orifice sizes?
Old May 24th, 2023, 03:24 PM   #18
ZackTheReaper
I got the Frezon Carb rebuild kit on Amazon
Old May 24th, 2023, 04:57 PM   #19
Carb kits are notorious for containing incorrect jets. So much so that it's recommended that they never be used for anything other than the gaskets, float needles, and seats. It's likely that if you were to thoroughly clean your originals and put them back in, it would run properly. Verify that they have the Keihin logo on them though, and the sizes are correct, in case a previous owner was messing around.
Old May 25th, 2023, 11:51 AM   #20
ZackTheReaper
Alright sweet! I’m gonna sync my carbs here soon then mess with my idle screws again. If it’s still bogging I’ll probably swap some of the new needles and jets out for the olds ones. I appreciate the help man! Any info helps. I’m still really new to all this. This forum has been a big help.
Handlebar bent/ Throttle stuck/ help a newbie naderzb 2008 - 2012 Ninja 250R Tech Talk 6 November 1st, 2016 04:25 AM
Stuck at the gas station. Dies when giving throttle spc2125 1986 - 2007 Ninja 250R Tech Talk 29 May 19th, 2016 08:23 PM
carb throttle bracket mount broke atxninjette 1986 - 2007 Ninja 250R Tech Talk 4 August 5th, 2014 07:22 AM
2009 Ninja 250R dies after adding throttle and pulling in clutch! meehow09 2008 - 2012 Ninja 250R Tech Talk 10 August 1st, 2011 12:21 PM
Stuck throttle after Area P install & new needles The Blue Rider 2008 - 2012 Ninja 250R Tech Talk 6 July 25th, 2011 09:01 PM
